Question about Lanzar VIBE266 Car Audio Amplifier
Lanzar vibe266 The light bar on the amp will come on but nothing else will. I dont know what happened but it wont do anything
  • mark2590 Jun 09, 2008
    I am having the same exact problem wiht my lanzar vibe, the light at the top of the amp is coming on but the power light on the side wont come on and i am getting no sound through the subs...has anyone figured this out?
    Problem Solver:
  • 4 Answers
This happened to me but i checked my lines and i changed all the fuses and it worked. To check put a wire from the acc to the power. I dont know if it'll work for u but i got the same amp and when i did that it worked
Posted on Apr 05, 2008
  • 3 Answers
Please write more how you have made connections. I need schemtaics to help you.
Posted on Jan 27, 2008
Lanzar vibe266 2000 watt stays in protect mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty .
.A thumbs up would be greatly appreciated if this answer is helpful to you. lanzar-vibe266-2000-watt-stays-in-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
Feb 05, 2013 | Lanzar VIBE266 Car Audio Amplifier
My lanzar 1600 watt amp wont turn on at all why
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . .A thumbs up would be greatly appreciated if this answer is helpful to you. Might be time to invest in a new amp. lanzar-1600-watt-amp-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
Jan 12, 2011 | Lanzar VIBE266 Car Audio Amplifier
I have 2 12" L7's
the kicker l7 will handle all that amp will put out .. bridge the amp and hold on
Feb 09, 2010 | Lanzar VIBE266 Car Audio Amplifier
Lanzar 800 watt amp protect mode stays on
protect mode usaully means that something has disrupted the power of feed lines to the subwoofer/speakers possibly fuse is blown in amp or amp is blown in which we hope not. see if you have a warrenty if blown and send back or bring it to where you purchased it from.
Aug 01, 2009 | Lanzar VIBE266 Car Audio Amplifier
2 ohm speakers wont work on a lanzar max pro 4000 watt
The 2 ohm stable rating on the amp is PER channel meaning that you could effectively hook up a 2 ohm speaker or a 2 ohm load to each channel without the amp getting f"d up-butin bridged mode it will only be 4 ohm stable. to achieve a 4 ohm load with your sub the type x wire the coils in series that will get you at 4 ohms to run in bridged mono .But you will get the exact same amount of power if you wire each coil to one channel of the amp as bridged mono sees the sum of your 2 ohm channels combined-Hope that helps.
Jun 08, 2009 | Lanzar VIBE266 Car Audio Amplifier
I need repair help. no schematics
Blown Mosfets
A thumbs up would be greatly appreciated if this answer is helpful to you. need-repair-help-no-schematics-zb4bomd1rt4qms0dqd12kkt2-5-0.jpg
Nov 08, 2008 | Lanzar VIBE266 Car Audio Amplifier
Annoying thump from two 15" kicker comps powered by a lanzar vibe 266 amp
It sounds like it may be oscillating. This can be caused by a broken ground in the signal line. You need to check the RCA shield on the head unit.You'll need an ohm meter. The following page has more details. If the head unit isn't damaged, the shield ground could be open in the amplifier.
Temporary Shield Repair
Apr 05, 2008 | Lanzar VIBE266 Car Audio Amplifier
Fried Amp
It's unlikely that anyone will have a schematic for this amp. Lanzar has refused to provide them in the past. What 'fried' in the amp?
Jan 10, 2008 | Lanzar VIBE266 Car Audio Amplifier
My vibe 286 4000 watt lanzar amp wont stay on..
Check your speaker load. It probably should be 4 ohms per channel. Also, if you are bridging then you must double your ohms load. It may be that your old amp could tolerate a lower impedence (ohms load) than the new amp. Do this now so you don't fry your amp. Good luck.
Mar 03, 2007 | Lanzar VIBE266 Car Audio Amplifier
Power light doesn't stay on...
Caps are NEVER a solution to ANYTHING in a car audio system. If your car is lacking in power, you need a high output alt. All caps do is mask the problem until eventually your car's charging system is toast. Check this out: http://www.techlore.com/article/14696/
Aug 09, 2006 | Lanzar VIBE266 Car Audio Amplifier
Lanzar VIBE266 Car Audio Amplifier Logo
73 people viewed this question
Top Lanzar Car Audio & Video Experts
Morne Olivier
Chris Ward
xxxxxx xxx
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
