Question about Intel S5000XVN Motherboard
Problem with installation and no display
System Confiquration:
CPU Model : dual xeon 5405 2.0 GHz
MB Model : intel s5000xvn
VGA Model : quadro fx1700
Memory Model : kingston kvr667d2d8f5/2g (16GB)
HDD Model : WD 7200rpm 1TB
PSU : Cooler master Real Power Pro 550W
Chassis : Cooler master stacker 810
I have just bought a workstation as spec above. But when i press the start button no video coming out.
The chassis don't have the front panel ssi 24 pin for my xeon workstation motherboard. It have the power led, power switch, reset switch and HDD led. From the pin no. below..
Front Panel SSI Standard 24-pin Connector Pin-out
1 P3V3_STBY_____________________2 P3V3_STBY
3 Key___________________________4 P5V_STBY
5 FP_PWR_LED_N ________________6 FP_ID_LED_BUF_N
7 P3V3__________________________8 FP_LED_STATUS_GREEN_N
9 LED_HDD_ACTIVITY_N__________10 FP_LED_STATUS_A MBER_N
11 FP_PWR_BTN_N____________ __12 NIC1_ACT_LED_N
13 GND________________________14 NIC1_LINK_LED_N
15 BMC_RST_BTN_N_____________16 SMB_SENSOR_3V3STB_DATA
17 GND________________________18 SMB_SENSOR_3V3STB_CLK
19 FP_ID_BTN_N________________20 FP_CHASSIS_INTRU
21 FM_SIO_TEMP_SENSOR________22 NIC2_ACT_LED_N
23 FP_NMI_BTN_N_______________24 NIC2_LINK_LED_N
I have make a connection as 5,7 = power led; 11,13 = power button; 15,17 = reset button.
Cooler master PSU didn't come with auxiliary power signal connector as well. Is it OK to run without auxiliary power signal connector?
rgds,
alvin
  • alvinkt Jan 27, 2008
    Now i able to start it but no display even i try with a low end PCIe card.
  • alvinkt Mar 13, 2008
    The problem for this motherboard is they didn't come with latest bios. When you using a latest processor, it wouldn't support. So you have to get a older version processor to update your motherboard bios or get your supplier to help you on this if you don't have the processor.
    As for the front panel ssi 24 pin connector, the setting is
    1,5 = Power LED
    7,9 = HDD LED
    11,13 = Power
    15,17 = Reset
    You can ignore the auxiliary power signal connector if you are not using redundent PSU.
    It is better to use a higher PSU. The 550W is just the minimum requirement. So I have changed it to 800W.
    Hope the info able to help you.
Hi alvinkt,
I am using 5450 and it gives me voltage mismatch error and does not boot up, goes straight to BIOS. Is your board revised version with R in the end or pre revision. Could you please help me resolving this error?
Posted on Mar 16, 2008
What is the (DMI)?
Posted on Dec 10, 2008
I am also having problem on this. so I am using 5420 CPU and S5000XVNSASR board. Just power up, not video. So, the solution is to use an old cpu first to flash the bois first before using the new processor? Really appreciate the help ray@me-web.net
Posted on Apr 26, 2008
If you are using a penryn Xeon, that is a 52xx or a 54xx series CPU, your motherboard must have an R suffix, eg S5000XVNSATAR, or S5000XVNSASR. Motherboards without the R suffix are incompatible with the new penryn xeons.
Hope this helps,
Regis
Posted on Mar 25, 2008
How did you solve this problem? I am hacing the same issues!! I am in desperate need to some help!
Posted on Mar 12, 2008
    Problem Solver:
  • 14 Answers
Yes its ok to run as long as you have a cooling fan on the cpu itself.
Posted on Jan 26, 2008
Can run windows 8 on IBM intellistation z pro ?
IBM IntelliStation zPro came with different CPU chips through 1997 to 2006. Depending on which year or type your machine is will determine if you can upgrade to Windows8.
The chips used were
IntelliStation Z Pro
Type 6899 (March 1997 to ??)
Type 6865 (October 1998 to April 2000)
Type 6866 (January 2000 to March 2002)
Type 6894 (May 2001 to June 2002)
Type 6221 (November 2002 to February 2005)
  • Dual Intel Xeon at 2.4, 2.67, 2.8 or 3.2 GHz
Type 6223 (August 2004 to March 2007)
  • Dual Intel Xeon with Intel 64 (formerly EM64T) at 3.0, 3.2, 3.4, 3.6 or 3.8 GHz
Type 9228 (June 2006)
  • Dual Intel Xeon Model 5130, 5140, 5150 or 5160
Windows 8 If you want to run Windows 8 on your PC, here's what it takes:
  • Processor: 1 gigahertz (GHz) or faster with support for PAE, NX, and SSE2 (more info)
  • RAM: 1 gigabyte (GB) (32-bit) or 2 GB (64-bit)
  • Hard disk space: 16 GB (32-bit) or 20 GB (64-bit)
  • Graphics card: Microsoft DirectX 9 graphics device with WDDM driver
As you have Type 6223 which a Xeon faster than 1GHz it should work with Windows 8 but not all Xeon processors are compatible depending on which one you have. See this Microsoft site after you check your Xeon chip family on the motherboard or through the Windows system command. Search for xeon.
Processors What processors support Windows 8
Aug 15, 2014 | IBM IntelliStation Z Pro 6223-42U PC...
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
Bios update
Hi, you can look for software here:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Server+Products&ProductLine=Intel%c2%ae+Workstation+Boards&ProductProduct=Intel%c2%ae+Workstation+Board+S5000XVN
Please select your operating system.
You can also run this utility:
http://www.intel.com/p/en_US/support/detect
It will find outdatet drivers.
I guess you have to try that first if you have software problems.
Take extremly care when upgrading the bios you have to make 100% sure
its the right bios or you will destroy the mainboard.
If there is no bios upgrade there is no need to do that.
Aug 26, 2011 | Intel S5000XVN/SATA Dual LGA771 Xeon/...
Dear sirs, I would like to upgrade the cpu`s of my Compaq Evo W6000 PC with the Motherboard Model 06D0h. Please let me know what are the strongest cpu`s I could use. Many thanks Murat
I suggest this to you.
Intel Xeon Processor, 1.4 GHz/100.0K
Intel Xeon Processor, 1.5 GHz/100.0K
Intel Xeon Processor, 1.7 GHz/100.0K
Intel Xeon Processor, 2.0 GHz/100.0K, L3
Intel Xeon Processor, 2.2 GHz
Intel Xeon Processor, 2.6 GHz/400
Processor, 1.8 GHz, 603FCPGA
Processor, 2.0 GHz, 603FCPGA
Processor, 2.2 GHz, 603FCPGA
Processor, PRST, 2.4 GHz/400, INT 261668-004 284645-001 source: ftp://ftp.compaq.com/pub/supportinformation/technotes/evo_w6000_workstation_rev6_us.pdf
Jun 29, 2011 | Compaq Evo Workstation W6000 PC Desktop
I can't install AUTOCAD 2009 in my windows XP computer.It asks to install direct 3D
Most probably your hardware ie graphic card do not support software requirements.
Autocad 2009 system requirements for Win XP.
32-bit AutoCAD 2009
Running under Windows XP:
•Microsoft Windows XP SP2 operating system
•Intel® Pentium® 4 processor or AMD Athlon®, 2.2 GHz or greater
or
Intel or AMD Dual Core processor, 1.6 GHz or greater
•1 GB RAM
•750 MB free hard disk space for installation
•1024x768 VGA with true color
•Microsoft Internet Explorer 6.0 (SP1 or higher)
If you are using AutoCAD for 3D modeling, you should bump up your system as follows:
•Intel Pentium 4 processor or AMD Athlon, 3.0 GHz or greater
or
Intel or AMD Dual Core processor, 2.0 GHz or greater
•2 GB RAM or greater
•2 GB of additional free hard disk space
•1,280 x 1,024 32-bit color video display adapter (true color) 128 MB or greater, OpenGL or Direct3D capable workstation class graphics card.
Hope it helps.
Mar 22, 2011 | Computers & Internet
Pasos para instalacion de web camvx2000
Hola amigo primero que nada devemos saber que systema operativo usa tu computador Windows Xp Vista or Windows 7
Esta Web cam es configura automaticamente per piensa tambien en los requerimientos del su systema. aqui algunos tips.
Habla en espanol y solo pregunta ok
Techbelkin
System Requirements Operating System For Windows®-based PC
Requires a PC that meets the requirements for and has installed one of these operating systems
Processor Windows® 7
Mmimimum: Intel Pentium 4 (3 GhZ), 1 GB of RAM; recommended: Intel Pentium (Dual-Core 1.8 GHz), 2 GB of RAM, 1250 MB free Windows Vista®
Windows® XP with Service Pack 2 (SP2) or later
Other CD-ROM
USB 1.1 (2.0 recommended)
16-bit color depth or higher, 2 MB or higher video memory
Windows-compatible speakers or headphones Internet Broadband Internet access may be required for certain features. Local and/or long-distance telephone toll charges may apply.
Internet functions also require Internet Explorer® 6/7 for installation; 25 MB hard-drive space typically required.
Nov 03, 2010 | Microsoft LifeCam VX2000 Webcam
Intel S5000XVN Memory Over heat
Are you using buffered, ECC RAM? This is a server board after all? Have you verified that the RAM is listed as compatible by Intel? Have you looked in your manual to make sure your memory layout is correct?
Jul 01, 2010 | Intel S5000XVN Motherboard
Dose nvidia 8800gtx work with xw8200
quadro fx 4500 512 mb-
look the card up and see if its AGP or Pci-e
Then you can see how much you can upgrade it.
If its AGP your options are limited, but still there are new cards made that will work with AGP.
Mar 04, 2009 | HP Quadro FX4500 (512 MB) PCI Express...
How much more memory cah I put in thei computer?
if you have that INTEL S5000XVN Motherboard in your pc. You need to buy PC2-4300 or PC2-5300ram. Intel say it can handle up to 32gb of ram. As it has 8 slots for ram i would say that could be possible but very very expensive. 1gb a slot would more than enough.
Feb 26, 2009 | Intel S5000XVN Motherboard
DIsplay Problem with Intel Dual-Core Xeon® 5050, 3.0 Ghz Problem
Try using a different graphics card or make sure that you even have one installed in your computer. If no display is present on boot up, then your graphics card might be corrupt.
Oct 10, 2008 | Intel Dual-Core Xeon® 5050, 3.0 Ghz
Intel S5000XVN Motherboard Logo
673 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
