Question about Ricoh Aficio 1018D Copier
SC101 ERROR MESSAGE
I HAVE JUST BOUGHT A RECONDITIONED 1018C COPIER IT WONT PRINT MORE THAN ONE COPY AT A TIME, THE AUTO FEEDER DOSE NOT SEEM TO WORK AND IT KEEP SAYING FUNCTIONAL PROBLEM SC101 AND THE MACHINE CANNOT DETECT THE ORIGINAL SIZE.
  • Anonymous Mar 30, 2014
    in my copier code appear sc101
    Problem Solver:
  • 10 Answers
I'm not familiar with your exact model but for small ricohs....Sc101 means that the standard white level was not detected. When you first turn on your machine the scanner scans a white plate (you will find this plate under the glass or frame near the park position of the scanner (facing down towards the scanner).The scanner will try to take a quick scan of this white plate so it knows the difference between white and black.
You will get this error if anything is preventing the scanner from seeing this plate (exposure lamp not working, Blocked scanner, or more likely a dirty white plate.
Remove the glass, get a mirror and try to find the plate and then clean it with windex. When you turn on machine the scanner will try to scan this white plate( make sure scanner is not getting hung up on anything.
For original size your machine may use paper size sensors that look like small black boxes with two black eyes (under the glass looking up towards the original) make sure these eyes are clean.
Regarding your doc feeder I need more info ( does it attempt to work, etc) describe what it does when you try to use it.
Posted on Feb 02, 2008
Sc101-00
just check the exposure lamp maybe busted
Jan 05, 2010 | Ricoh Aficio 450 Copier
I have a message coming up that I don't know what it means.
ADF = Auto Document Feeder (Usually on top)
RADF = Rear Auto Document Feeder, (On the back)
Something is stuck in one of these, a piece of paper, foam, paperclip, twist tie . . . it could be anything. Follow the squealing sound and check the paper feeder rollers.
Find what is in the way and remove it.
Cheers.
Jun 22, 2009 | Toshiba e-Studio 161 Copier Copier
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
Hp laserjet 3050 - black line down the center of copies, everything elese works
If the lines only appear on copies from the auto feeder and printing is clean, then lift the auto feeder section and clean the scanner glass underneath.
If printing and copying have similar 'streaky' results you probably have a bad toner cartridge - try a replacement. If that doesn't work you have a fuser problem - which is quite a costly repair based on the replacement cost of your unit
Feb 26, 2009 | HP LaserJet 3050 All-In-One Printer
Will not "Print" copies.
It may be that you are putting the page face down in the paper feeder when it needs to be face up or the other way around.
Jan 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Gray lines on the copies
If the toner is low that would cause a problem. If the drum is damaged that would cause a problem too. If you have recently (past month) printed successfully than you might have issues with copy surface. Does the line come when using the auto feeder? Replace/ remove/reinstall the toner cartridge and clean the copy surface. Repost if this does not solve problem.
Nov 01, 2008 | Sharp AL 1631 Copier
Blank Copy when using Feeder
Are you making sure you are putting the origanls face up??? Also, are you getting any error codes at all? Will it do it only in the morning? Dose it happen with the copyboard glass at all? How about is it net worked? Or a Fax? Your hard drive may be crashing or is just about two. Dose it also pull one or more pages through..... Need more info..
Jul 10, 2008 | Office Equipment & Supplies
ERROR CODE SC101
SC101 indicates and exposure lamp problem. To try and correct, turn OFF the copier and then unplug from the wall. Wait 10 seconds and plug it back into the wall, then turn on the copier. Watch to see if the exposure lamp comes on - lift the document handler if you want. If the exposure lamp is working correctly, the scanner will briefly move to the right and the light will turn on then off after it moves to the left.
Jul 09, 2008 | Ricoh Aficio 1013F Copier
Error code Sc101
SC101 can be caused by a dirty WHITE LEADING EDGE STRIP. This is located under the left side plastic strip that holds down the exposure glass on the left side. Remove the screws, and flip over the glass holder. Clean the white strip with glass cleaner, and reassemble. If SC101 reappears, the scanner drive pulley screws are loose or broken off. A service technician is required for this repair.
Feb 20, 2008 | Lanier 1205 Copier
739 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
