Question about Bissell 6900 DigiPro Bagged Canister Vacuum
Bissell 6900 stopped working how do I open the thing?
I have a Bissell 6900. Just stopped working. Not the house circuit breaker or an outlet. Just does not turn on. Want to open it and found and removed 5 screws but there's either a trick tab to depress or some hidden screws (under the wheels?) that I've not found. I can pry it up an inch from the bag compartment side but something is holding it together in back where the on/off and plug retract are (and yes I did remove the one screw in the deep recess on the top of the unit back there.
  • 4 Answers
Bissell 6900 Digipro ON OFF Power Switch failed. I found the wire connectors for the power switch were corroded. I fixed this by soldering the wires directly to the terminals leading to the motor. To access the circuit board and the on.off power switch I pryed off the cover for the on /off power switch and the cover for the cord retraction leaver. The covers are held on by two tabs that extend under the red cover on the top of the vacuum. Push the switch cover away from the red cover while prying the cover upwards, You may damage the two tabs on the switch cover, as I did, but afterwards, the cover went back in place and appears to work okay. WARNING: This is a home made repair of a 120 VAC circuit. If you are un qualifued to do this repair you face serious risk of a faulty solder and fire inside the vaccuum cleaner. Bissell 6900 stopped working how do I open the thi - 4fd9446.jpg78baa14.jpg
Posted on Nov 28, 2009
  • 126 Answers
I think you should leave this to a professional. There is a circuit board in there that is very sensitive. The problem could be there or in the cord rewind, but the first place I check is the plug on the end of the cord. Wiggle the prongs and see if one of them is loose. Plug the machine in and push the cord towards the plug as you click the switch on and off. If the wires inside the plug are at fault, the machine will start and stop. I've seen people (and technicians) rip a machine apart, assuming the worst, only to discover that it was a simple plug replacement that was required. Be very careful with the electronics. They can be expensive and you may end up damaging them unecessarily. If you do get it open, there are several wire harnesses that could be at fault. Sometimes, the pins they plug into on the circuit board, break at the solder point and will burn out. Be careful here. The board can usually be repaired, but only if the problem is not made worse.
Posted on Jan 27, 2008
Where is the reset button on the Bissell Powerforce helix upright ?
This unit does not have a reset button or fuse that is accessible or repairable. If you are referring to the manuals troubleshooting no power, the blown fuse or tripped breaker that is being referred to in the manual is your house hold breaker box and the fuse or breaker that handles the outlet the unit is using.
If your having power issues you should first inspect that all accessible parts are functioning. Such as hoses being closed, dials resting in the set positions, wand locking. Also if visible the sensors that are keeping tabs on each part. Another issue may be that the cord had been kinked and has shorted out, one possible way to check this issue is: if the unit powers up only when the cord rests in certain positions.
If this was recently purchased the warranty is for one year. A ship repair cab run $35 to $100+ you will have to call around. Or have a handy family member you with it.
Being these machines can be found $50 to $75 a replacement would probably be your best bet.
e72fb1da-2558-49cd-81a9-99825035337b.png e48073ba-4f6c-40a2-92a7-244dedbcfce5.png
Aug 03, 2014 | Bissell 6594 PowerForce Bagless Upright...
Digipro 6900
Find where the wire connects to the motor-2 leads. Place even the simplest of elect. testers 2 leads to those. If you get no reading, it's your cord. A reading of 110-120 volts means power is there, but motor needs work.
Apr 02, 2014 | Bissell 6900 DigiPro Bagged Canister...
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
My vacuum worked just fine... i went in another room to use it and now it won't turn on no matter what outlet i use!
If it works in the other room's outlets, I would think that it might be tripping the circuit breaker for the room it isn't working in. Check your circuit breakers.
Dec 07, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
My Bissell liftoff Revolution won't turn on. Is
Vacuums are not usually fused, but may have a circuit breaker--look for a small protruding button that when pressed, resets the breaker. The plug on the end of the cord may have a wire broken within the plug--replace it with one from a hardware or home center. Another common problem is the power switch may have failed. Order a new one from an appliance parts house. Good luck!
Apr 13, 2010 | Bissell LiftOff Revolution Pet Vac 37602...
My Sebo hoover trips the house mains sockets every time I switch it on, yet doesn't trip the kitchen mains. Have replaced filters/bag to reduce load but still no good. What should I be investigating in the...
It sounds like your vacuum is fine if it works when plugged in the kitchen outlet. It is tripping the breaker switch in the other room because the circuit is overloaded (too many things plugged in this circuit). Try unplugging some things in that room and try your vacuum again.
If it only trips when using one particular outlet, then the outlet should be replaced. I would recommend having an electrician check your wiring out.
Hope this helps
Feb 01, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
ON Off Power switch failed Bissell 6900
See this solution:
http://www.fixya.com/support/t371681-bissell_6900_stopped_working_open_thing
Nov 27, 2009 | Bissell 6900 DigiPro Bagged Canister...
Hoover EmPower 4600 keeps blowing circuit breaker. The number of outlets in the house that will allow me to run the vacuum is dropping quickly. It is a 4 year old house and all the circuit breakers are 20...
take it to a friends house and plug it in if it does the same thing then the problem is in the vacuum cleaner.check your cord and see if there are anny cuts in it.you can open the breaker box then plug in the vacuum and watch the breaker box.you might see a spark and narrow down the problem.
Mar 22, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Removal of the beater bar for digipro 6900
unscrew bottom and screws on top pull open beater bar just pulls out
Mar 06, 2009 | Bissell 6900 DigiPro Bagged Canister...
It keeps tripping the breakers or the GFI outlet.
try different outlets in another room to see if that dosent help you may have a shortin the cleaner but i think you may be overloading the breaker
Jan 17, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 6900 DigiPro Bagged Canister Vacuum Logo
272 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
