Question about Cyberhome DVR 1600 DVD Recorder
The clock time is off, how can i change it?
When the unit is off the clock displays the incorrect time. how can i change it. I can't access the link to the pdf product manual :(
Thank you in advance.
The only way to change this is going thru the menu and you need the control remote. I had the same problem until I found my remote control to fix it
Posted on Jan 27, 2008
I have a jvc kd-s590 in my car & have no idea how to set the clock. It'd driving me crazy. Please help!
1 Press and hold SEL (Select) for more than 2 seconds. "CLOCK H", "CLOCK M", "SCM LINK" or "LEVEL" appears on the display. 2 Set the hour. 1 Select "CLOCK H" if not shown on the display. 2 Adjust the hour. 3 Set the minute. 1 Select "CLOCK M." 2 Adjust the minute. 4 Press SEL (select) to finish the setting. 1 2 During tuner operation: During CD operation: Frequency Clock To check the current clock time (changing the display mode) Press DISP repeatedly. Each time you press the button, the display mode changes as follows. To Cancel Advanced SCM You can cancel the Advanced SCM (Sound Control Memory), and unlink the sound modes and the playback sources. When shipped from the factory, a different sound mode can be stored in memory for each source so that you can change the sound modes simply by changing the sources. LINK ON: Advanced SCM (different SCM for different sources) LINK OFF: Conventional SCM (one SCM for all sources) 1 Press and hold SEL for more than 2 seconds. "CLOCK H", "CLOCK M", "SCM LINK" or "LEVEL" appears on the display. 2 Select "SCM LINK" if not shown on the display. 3 Select the desire mode - "LINK ON" or "LINK OFF". 4 Press SEL (select) to finish the setting. • If the unit is not in use when you press DISP, the power turns on, the clock time is shown for 5 seconds, then the power turns off. 1 2
Nov 03, 2010 | JVC KD-S590 CD Player
CANNOT RESET CLOCK
1) Press SOURCE and hold it until the unit turns off.
2) Press AUDIO and hold until clock appears in the display.
3) Press AUDIO again to display the setting u need to configure.
- when u found clock, press < or > to select the segment of the clock display you wish to set.
- press /\ or \/ to set the clock.
- press BAND or hold AUDIO when finish.
YBC (/\)
Apr 27, 2009 | Car Audio & Video
Jvc kds641 changing time display
Here ya go,
1.
Press and hold SEL (select) for more
than 2 seconds.
“CLOCK H,” “CLOCK M,” “SCM LINK,” or
“LEVEL” appears on the display.
2.
Set the hour.
1 Using the << / >> button, select “CLOCK H” (hour) or "CLOCK M"
Use the + / - button to adjust the hour/minute
3.
Press SEL to finish.
4.
To check the current clock time or change the
display mode
Press DISP (display)
repeatedly
During tuner operation it will show the frequency or time.
During CD playback it will show elapsed time or time.
Follow this link to download the manual for your unit in .PDF form.
Mar 30, 2009 | JVC AM FM CD DET FACE CAR STEREO
Put the clock
1.
than 2 seconds.
2.
Set the hour.
3.
4.
display mode
repeatedly
Change Clock - Logitech Pure-Fi Elite
hold the src button left of power along with button to the right power.a model number will appear once it does let it disappear and the unit will go into reset. set the language, 12/hr, 24hr etc and the time. :)
Dec 13, 2008 | Logitech Pure-Fi Elite High Performance...
Machine does not maintain correct date and time.
Are you powering it off by the power button on the unit? is the power button a rocker switch or a simple button? also are you powering it off by a power strip? Most electronic devices have a clock circuit that is powered from a battery when the unit is off. usually with modern electronics the power never completely goes off so the clock will stay functioning with less battery. Basically you either have a simple internal battery issue or a failing logic board. Try not using a power strip to power the unit off or take it in to be serviced by a qualified technician that has access to the parts needed.
May 17, 2008 | Brother MFC-7220 All-In-One Laser Printer
Don't know how to set the time/clock.
Setting the Clock
Before operating the unit any further, first set the clock built
in this unit.
• When the unit is turned on with CD or tuner selected, press
DISPLAY first to show the clock indication.
1 Press and hold PROGRAM/SET
The hour digits start flashing on the
display.
2 Press 4 or ¢ to adjust
the hour, then press
PROGRAM/SET.
The minute digits start flashing on the
display.
3 Press 4 or ¢ to adjust
the minute, then press
PROGRAM/SET.
If there is a power failure
The clock loses the setting and is reset to “AM 12:00.” You need to
set the clock again. If the batteries are inserted in the unit, this has
no effect on the memory.
To show the clock when CD or tuner is selected
Press DISPLAY.
• Each time you press the button, the display changes the clock
indication and the normal indication alternately. (Operating the
unit while clock indication is displayed change the display to the
normal indication.)
Feb 04, 2008 | JVC 10 Watt CD Boombox with AM/FM, Dual...
Changing the time
Here's a link to the manual Pioneer's web site.
Here's how you set the time (from page 16 in the manual):
1: press SOURCE and hold until the unit turns off.
2: Press AUDIO repeatedly until the clock appears in the display
3: Press (left arrow) or (right arrow) to select the segment of the clock display you wish to set (hours, minutes)
4: Press (up arrow) or (down arrow) to set the clock.
- To cancel clock settings, press BAND
- to save clock settings press AUDIO until the display stops blinking
Dec 25, 2007 | Pioneer DEH-1500 CD Player
Clock
Here is the link to the DEH-P3900 website page (sorry is the closest i could find, but changing the clock is the same); http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070337_337273636,00.html You can download the manual from there - you have to register, but it's free. if you want a quick way, pioneer says: "SETTING THE CLOCK How do I set the clock on my single CD player? For most Pioneer single CD players, you can set the clock using the following steps: Press and hold the SOURCE button until the unit turns off. Press SOURCE and hold again until the clock appears in the display. Press the left or right arrows to select the segment of the clock display you wish to set. (As you select the segments of the clock display the segment will blink.) Press the up or down arrows to either increase or decrease the numbers in the blinking segment. Once the clock is set correctly, press the SOURCE button to exit." Hope this helps - please post again if not :)
Apr 03, 2007 | Pioneer DEH-P3700MP CD Player
Cyberhome DVR 1600 DVD Recorder Logo
46 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
