Question about Linksys Instant 802.11b Wireless Network Access Point: WAP11 (NTWRLSXWAP11)
Netgear DG834PN v talktalk modem/router
I was with Orange broadband & bought the Netgear to make a laptop wireless - no problem -
I have changed to Talktalk & now can't get my Netgear to work - I have tried 'just' changing cables (they seem the same to me) but I lose my Internet connection & have to go back to the modem -
One early retired laptop unles someone can help please
Thanks
Anne (non tekkky- so please ...... keep it simple)
  • Louie  Role
    Louie Role May 11, 2010
    Hi Anne,
    I am assuming that by "have to go back to the modem
    " you are referring to the modem issued by Talktalk that connects your ISP/Internet through the telephone line. Further, this modem is connected to your laptop using Ethernet cable (networking). Pls confirm.
    If yes:
    1. Can you pls post back with details/specs of your modem. Normally they are underneath the modem printed on a sticker or name plate;
    2. Can you pls connect to the Internet by using this modem and determine the network configurations. This is done by going to Start, Run, type "CMD" (w/o the quotes), on the next black window type "IPCONFIG /ALL" (w/o the quotes), you need to get the info (of your Ethernet Adapter) on IP Address, Subnet Mask, Default Gateway and DNS Server(s);
    3. Was their a CD that came with this modem? and
    4. Do you still have the CD that came with the NetGear?
    Pls post back.
    If no:
    a. Can you pls detail how Talktalk Internet service goes in to your laptop.
    Good luck and kind regards.
    Brigadier General:
  • 6,966 Answers
Thank you srinicss for repeating my request for information as a solution.
Posted on Feb 12, 2008
    Problem Solver:
  • 10 Answers
-could u pls poost the model no. of the netgear product
-it wuld help me to guide u better
srini
Posted on Feb 09, 2008
6ya staff
SOURCE:
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
Setting up a wireless lan
The DG834PN is an easy to set-up, single box solution, it plugs straight into your ADSL line – there is no need for a separate modem. Once the DG834PN modem router is connected, configuration is also easy, via NETGEAR’s Smart Wizard™. The Smart Wizard™ automatically detects your ISP’s network settings, and then walks you through each step of the installation process. Or then Call ur ISP.
Thank You,
Your Tech Support,
Fixya.com
Manish Shirsikar
May 18, 2009 | Gigabyte GA-K8NS Motherboard
Connection with netgear to laptop
Helen, you should be able to connect from your laptop to your router wirelessly. From what I understood your router is hooked up to your PC directly. If that's the case from your PC connect to your router and enable wireless. Go to Netgear support web page to find out how to do it. Once enabled, you should see your router's name in the list of available wireless networks on your laptop
Feb 07, 2009 | NetGear DG834 Router
Laptop finding router but no internet connection
If you can connect directly to your virgin Media Broadband and get internet then your laptop and broadband router is fine.
The wireless router appears not to have a DNS entry and you will need to add that manually.
I suggest that you connect directly to the Broadband modem, be sure you can get onto the internet. Once you have confirmed you can get onto the internet you need to get the dns information from your Broadband modem for later.
once connected directly to the broadband modem, click start>run> then type "CMD" then click open. you will get a prompt type the following and record the DNS Server ip addresses.
"ipconfig /all" then hit enter
this will display your ipaddress information but mostly you need the DNS server ip addresses.
once you have recorded them rerun the install, but this time instead of at the end of the install where it shows the Wireless router information you can modify or change it and add the DNS server entries.
Also by default most wireless routers ip address is 192.168.1.1 and you can type that from a internet explorer and change it from there as well. I believe it's no ID or user name and the password is admin.
Good luck
Jan 28, 2009 | NetGear WGR614 Wireless Router
Netgear wireless router DG834PN wireless access local only I can get internet on my desktop which is connected to the router via ethernet but I can connect to the router wirelessly on my laptop but only...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To start with plug the LAN cable, type 192.168.0.1
into your browser, a netgear window should come
up name is (admin) PW is (password) default.
goto to wireless settings.
Tick Enable Wireless Access Point
Tick Allow Broadcast of Name (SSID, give it a name
Under security options, Tick none
Hit apply and exit
Setup your laptop up with no security to start with, the laptop
Should now see the Netgear SSID name you made.
After this find out your laptops MAC address, log back onto the
Netgear unit, add the MAC address to the allowed list, hit apply
And exit, now only your laptop will be able to get a wireless connection.
Hope this helps
Have a nice day
Aug 14, 2008 | NetGear WGR614 Wireless Router
Netgear DG834PN ADSL ROUTER AND HUB - PC dial-up connection
so your trying to use a dsl router as just a router -dsl with dialup?
Aug 06, 2008 | NetGear Computers & Internet
Zoom x6 model 5590 wireless router
Make sure the Connection Type is set to Static IP on the setup page of the router
Mar 10, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
Computers & Internet Logo
183 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
