Question about Typhoon Acoustic (128 MB) MP3 Player
Typhoon "My Mini Dj'' Hdd error S/N 0508004985
I have had this mp3 player for about a year now. When I plug it in it gives me a hdd error. Im assuming that the hardrive is corrupted or broken. is there any way to salvage this.
0 characters
1 Points
Dell Digital Jukebox
Anything unusual happen to the player before the problem started? Dropped it or perhaps unplugged it from pc while synchronising? The most likely fixable problem is a loose connector on the HDD/main board cable, or a failing battery/power adaptor giving the HDD a voltage too low. unfortunately however the HDD on these players is a bit vulnerable to rough treatment. When you connect it to a computer, does it still appear as normal or is it not recognised etc. What operating system PC are you using - perhaps formatting from the PC first before trying to install the firmware will help. Are you using the latest firmware from Dell or are you using a cd that came with the player? Is your player still under warranty or do you want to try and open it up and have a check yourself. Let me know more info and what you wish to try :)
Aug 17, 2007 | Dell DJ MP3 Player
I get an error that says HDD init failed connect to pc when my computer doesn't recognize it so I cannot format the HDD?
The main hd is unpluged. Unscrew the screws nezt to battery. Slide left the back cover just like the battery cover and plug the hd back in. piece of cake!
May 04, 2010 | Gateway Photo Jukebox GCM-4 MP3 Player
Sir i have my iriver mp3 player for more than 3 years it was working very fine but last year. when ever i start it it shows me file check error. and it runs the radio very flawlessly but there i cannopt...
Sounds like a corrupt file system. Assuming you are using Windows, If you can view the disk in My Computer, right click on the drive, select properties, tools tab, in the error checking option select check now.
You may also be able to format the drive by right clicking on the mp3 player's hdd and selecting format, then quick format. Copy any music you wish to keep though on a separate drive as format will erase it.
Mar 18, 2010 | MP3 & Digital Media Players
Problem in hdd drives
You may get a specific error msg, or the player may not power on at all. Are you having a specific problem?
Mar 28, 2008 | Philips GoGear HDD6330 MP3 Player
Kenwood HD20GA7 MP3
no system found on hdd error 00100060 p
Mar 21, 2008 | Kenwood HD20GA7 MP3 Player
Error number 00100060
Comment by MAHMOOD, posted on Oct 22, 2007 my younger brother plugged my megf20 gigabeat to pc and he formatted that using windows xp format disk utility now when i am turning on the gigabeat i just see an error and that is
error number is 00100060
if you can help me please
Oct 22, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
'Library Full' Error when transferring files to Zen.
the zen uses other areas for data storage and stuff.
best to reformat and not use so many folders.
Oct 21, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
HDD read error
I had the same problem with my mp3 player. The problem seems to be that the charge had been depleted - even though the screen said the charging was complete when I plugged it in. Disregard the screen, charge your machine for two hours, and if your player is like mine, it will be functioning properly afterwards. Hope that helps.
Aug 15, 2007 | Coby MP-C941 MP3 Player
Mp3 player
Try resetting it...or charge it fully
Mar 19, 2007 | Dell Pocket DJ MP3 Player
Typhoon Acoustic (128 MB) MP3 Player Logo
Top Typhoon MP3 & Digital Media Players Experts
Gyula Lacz
Are you a Typhoon MP3 and Digital Media Player Expert? Answer questions, earn points and help others
