Question about Optoma MovieTime DV10 Multimedia Projector
No access to half of menu
Brand new Optoma 1651 projector won't recognize PC with VGA connection. Can only access Setup & Options on the menu so I can't verify is VGA is switched on. Not my first projector, tried varies startup sequences, know about screen switch. So desparate I read entire manual.
  • dburkland Jan 26, 2008
    Got projector & menu to work on an old notebook running XP Pro, newer notebook that doesn't work running XP Media. Any other ideas as I want to utilize the better graphics on the newer notebook?
  • 167 Answers
Dry solder joints or bad input placement. Try jiggling the vga port on the projector or use a different projector
Posted on Jan 26, 2008
  • anonymous anonymous Jan 26, 2008
    i mean use a different vga cable
I use OPTOMA ex 532 with windows 7 32 os the projector working properly but in pc screen not displayed the projection screen
You have three option to view projection screen on your PC SCREEN:
1. Use "Y" cable to connect the projector and pc screen at a time.
2. Use "Video Splitter" to connect projector and pc screen at a time.
3. you can use a VGA cable to connect your pc screen with your projector VGA OUTPUT. here I show you the pictures.good_help_4.jpggood_help_5.jpggood_help_6.jpg
Jan 20, 2011 | Office Equipment & Supplies
How do you feed TV thru an Optoma DLP projector?
You need a tuner to tune in the tv channels. use a vcr that way you can change your channels
Jun 06, 2010 | Optoma EP739 Multimedia Projector
The projector is not recognizing the laptop, it says searching on the projector screen going through VGA, S video, etc.
Probably got the resolution on the laptop set too high for the projector. Go into your video control panel (accessed by right-clicking the desktop), set up the projector as a cloned monitor and make sure the screen resolution is low enough for the projector to handle.
Jan 27, 2010 | Optoma EP728 Beamer/Projektor Projector
It will not recognise my acer laptop
hy
a projector dosent need to recognize anything you just plug your (vga,hdmi,dvi,...) cable in to the laptop and the other half in the projector and it has to work . Did you switch the display from the laptops TFT to an external 'anything' its fuction(key on your laptop) + one of the F# buttons.
Or just explain with more details.
Good luck .
Jan 04, 2010 | Optoma HD70 DLP Projector
I've connected the projector to my laptop using the VGA cable as stated in the manual. The projector reflects as it should, i can access the menu and input options which i then select RGB scart (though...
Not with any RGB input options, computers are not compatible with these. The projector needs to be set up to receive VGA. There must be a toggle button or menu entry somewhere on your projector that lets you do this or why would it have a VGA input?
Dec 07, 2009 | Sanyo PLC-XW55 LCD Projector
New beamer optoma hd65,message: no source found
adjust the resolution to match. also, make sure the monitor port is activated.
Nov 04, 2009 | Optoma HD65 DLP Projector
Optoma EP716 source detection
It sounds like your module that controls the menu and the "cycling through" may not be in sync or may needs to be replaced. I had times have had to make sure the Optoma EP716 had to be first plugged in and "on" before the PC can communicate with it. Once the Optoma is "ON", then turn your PC/Notebook on. If there is no connection via USB, "S" cable and/or your VGA (be sure your PC/Notebook is set to have the external VGA "active"). Let me know if this works or not. Then we can try to move forward with other options for troubleshooting. BTW...how long have you had this multimedia and how many hours of use does it have?...JGUAM
Oct 21, 2007 | Optoma EP716 Multimedia Projector
Optoma MovieTime DV10 Multimedia Projector Logo
189 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
