Question about Kitchen Appliances - Others
Broken plastic knob Durabrand toaster oven
We got this toaster oven at wal-mart about 6 weeks ago. Last week thebottom knob (which turns the oven on) broke into several pieces, andnow we cannot use it! Can we get a replacement part (or two, in case itbreaks again?)
  • 2 more comments
  • NeedMyToast Mar 27, 2008
    Che bottom knob (which turns the oven on) broke into several pieces,on our 6 month old BETTY CROCKER TOASTER OVEN BC-1679. Now we cannot use it! Can we get a replacement part?
    Canadian Tire which sold it to us suggested we call "some 800 number." The product doesn't have one.
  • Anonymous May 28, 2008
    SAME KNOB BROKE ON OURS. I AM LOOKING TO SEE IF I CAN FIND ONE ON-LINE. FOR NOW WE USE A SCREWDRIVER IT WORKS BUT IS A PAIN!
  • Anonymous Oct 27, 2008
    same problem on ours - no solution yet!
  • Anonymous Jan 31, 2009
    Bottom Knob broke.
I have the same problem with my Euro-Pro. It's approximately 2 years old. The knob (off a round, slotted shaft) in my case was the timer knob. Was using a butter knife, but cut two pieces of sheet metal, one rectangular (steel) and the other smaller and thinner (aluminum) cut one into a pointer, shimmed together in the slot. bent the pointer piece to point to zero.
Posted on Nov 14, 2008
Are there multiple knobs that are the same size? If yes, then you could try pulling off one of the other knobs (gently) and putting it in the broken knob's place. You're probably just turning a metal piece under the knob, so you can switch the knobs back and forth.
Posted on Mar 07, 2008
Euro pro to241r
follow this steps and fix it. God bless you
If the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical panel and test the electrical cord.
If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse.
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostat .
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements
Oct 10, 2013 | Toaster Ovens
Fan motor quit. I need a replacement fan & motor unit. Where may I purchase this?
My Euro-pro to241r toaster-oven may have some electrical problems internally. I have owned it for over a year and a half and am now smelling something like burnt plastic or rubber coming from the vents on the right side near the control knobs. I am concerned it may cause an electrical fire. Has anyone else had this problem? I will take it to Wal-Mart where I bought it to see what they say.
My friend tried to look at it but said you need star shaped screw driver heads to take it apart. Look for an online manual to see if you can find information about a fan, but it may not be easy to get to with basic tools.
Did you try looking at there website www.Euro-pro.com which is posted by the model number?
Radioshack may be a possibility.
Good luck, Tom
Jan 17, 2013 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
Broken timer knob
I had the same problem where the time knob broke. I filled in a claim form on the Oster Website and they answered within 3 days saying the timer knob was discontinued and no longer available. They proposed to replace the whole toaster-oven with another model 6073-33 which I received last week. I've to say that their customer service was amazing.
May 04, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Kenmore toaster oven timer knob broken
I have the same toaster oven and my timer knob just broke 2 days ago. Go to SearsPartDirect.com website. They have a substitute timer knob.
Mar 18, 2009 | Kenmore KTES8 Toaster Oven with Convection...
Where can I purchase a G.E toaster oven mocel #168947
TRY THIS http://www.walmart.com/catalog/product.do?product_id=2189051
Dec 20, 2008 | GE 168947 Toaster Oven with Convection...
The knob on the bottom dial of the toaster oven has cracked and fallen off. Can i get a replacement knob so that I cAn turn the toaster oven on I need all three knobs (temp, function & timer) for my Euro...
You *can* order parts from the manufacturer directly, but good luck with that. The first time I called, and mind you their 1-800 # is a quagmire of numeric menu selections before you ever get to talk to someone, they said they would be happy to send me one but they were out/backordered and that I should call back in 2 weeks. Instead of putting me on some kind of list and sending me one when they got more...Grrr! Then I tried calling back and made it, again, through the menu maze only to find out they are in Eastern time. Super frustrating!
But I also discovered that the flat head screwdriver is the best temporary solution until I can get my hands on a replacement knob!
Dec 06, 2008 | Oster 6071 Toaster Oven with Convection...
Rotissere Toaster Oven Just Stopped Working
the problem is internal and it might be the fuse or the thermostat
Dec 05, 2008 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
Oster Toaster Oven Model # 6192-33
Aug 28, 2008 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Contact Phone number for Durabrand
I just found a phone number for another customer problem I was working on and it is 1 - 800- 242-7158 they will say funai corp but this is also the phone number for durabrand as well. I hope this helps.
Dec 11, 2007 | Durabrand 7" Dual-Screen Car DVD Player
Kitchen Appliances - Others Logo
1,073 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
