Question about JVC GR-AXM1 VHS-C Analog Camcorder
The video still works fine on my camcorder, but the last time I used it, the only sound we taped was static. The camcorder had not been used in a long while. Could this mean that although the battery held a charge, that perhaps it's time to buy a new one? I don't want to go out an buy a new battery, if the whole camera needs an overhaul. It might be cheaper just to buy a new camera....
  • 2 more comments
  • Pete440 Sep 27, 2008
    I have the same problem. Can hear sound very faintly under the static noise
  • L-Rob Mar 12, 2009
    There are sound gaps during playback. It occurs every 4 - 5 seconds and lasts about 1 second. Don't know what is causing problem or how to troubleshoot..
  • agentimperia Apr 22, 2009
    The ambient sound is sometimes really messed up by some sort of static noise, not only on tape, but also in the real time audio monitor. So that should kind of rule out the dirt on the magnetic head... It comes and it goes. And when I use the hand-held microphone plugged in the camera's jack the sound is pristine. How can I fix this? Thanks!
  • Jose Cruz May 11, 2010
    Some days ago i puted a new batery in an long time unused camera vhs c gr-axm1. and start working ,it has a filmed tape inside but doesnt come out,and doesnt play,only in forward mode works like play mode,but today i tried to star it again and doesnt work nothing,never puts on.
    Problem Solver:
  • 19 Answers
Run a head cleaner through the unit, More than likely you simply have a clogged audio head. It may take a few passes to clear it out.
Posted on Jan 26, 2008
Do i need software for jvc mini camcorder model gr-d347u
If you are asking about software for transferring your tape to your computer, your computer should recognize when your camcorder is plugged into it and it will install the appropriate driver.
Attached is a link to the user manual. You will need to refer to the "editing" section. This should have all of the instructions that you need.
Hope this has helped you.
Sep 03, 2010 | JVC GR-D347U Camcorder
JVC gr-axm310u tape eater
you know what it could be a malfuntion in the circiut take it to future shop or something
JVC GR-AX640u VHS-C Eating Tapes
The capten belt slipped from the remoce the mechanisum and fix with a new one.
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Jun 26, 2008 | JVC GR-DVF21 Mini DV Digital Camcorder
Firstly check if a/v mode is on or..out.If it is on out then your ccd image sensor is faulty.
Mar 18, 2008 | JVC GR-D20EK Camcorder
No playback on JVC GR-D72
It souunds like the problem is in the Vid-PC connection. I suggest you start by downloading the latest version of whatever software you have used to capture and view.
Also - uninstall any hardware in the PC that is used to capture (just remove from system device list) and then restart the PC and let it detect and re-install.
If you don't know how to do these steps, then you'll need geek help.
Oct 28, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Oct 15, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 25, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Usually when the recording is started it takes around 10 to 15 seconds for the camera to recognise and display the duration of remaining tape, if you feel there is a problem, try using different brand tape.
Mar 17, 2007 | JVC GR-D370 Mini DV Digital Camcorder
JVC GR-D250 does not record properly
When playing the tape in the camera itself, do you hear sound? If so, its something with the connection cable... is not, you will need a professional repair, you can do nothing except the head clean which you did? Sorry.
Nov 23, 2005 | JVC GR-D250 Mini DV Digital Camcorder
Video Cameras Logo
216 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
