Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
DVD/CD ROM problem (Dimension 5150)
Hi, not sure if these problems are related, I recently had a problem with the start button flashing amber which made it impossible to boot up, this problem has been resolved by re'insertion of the battery, however, since this problem occured I have been unable to use my CD rom, after checking my Explore folder, I notice the DVD icon is no longer displayed, the CD rom drawer still opens and closes, the green light flashes on the DVD display as if trying to play the disk, I get the impression there could be a driver problem but I am only a will be greatly appreciated.
  • 3 more comments
  • tate69 Jan 27, 2008
    Hello, thank you for your help and advice, I hope you don't mind me contacting you again, just wanted to tell you what I found before attempting to make any changes (which I would need instruction for)
    In the boot sequence window...
    1. Onboard or USB floppy drive
    2. Onboard SATA hard drive
    3. Onboard or CD-Rom drive (not present)
    4. USB device (not present)
    5. Onboard IDE Hard drive (not present)
    Hoping that you may make some sense of this, the fact that it shows these drives as not present is quite worrying to me!
    Thanks again.
  • tate69 Jan 28, 2008
    Thank you so much for your help.....problem now resolved.
  • nbenson Dec 06, 2008
    I have a Dell Deminsion 5150 and it will not boot from CD Rom or Hard Drive. In the system setup is it showig
    CD Rom - present
    Onboard SATA HD (not present)
    Anyone have a solution to fix this?
  • vukasin Feb 24, 2009
    my problem is the same i gues. I dont see my CD drive in "My computer"
    and i don't see it in setup (F2) it is not present...i tried to instal a firmware for my cd drive. it' a GSA-H21N model but  nothing. i don't see it even in device manager.
    does anyone can help me with this?
  • aetvette Feb 25, 2009
    on button flashes amber , after 3 or 4 minutes it will stop flashing and we can turn it on . it will work all day you can shute it off and on but if it sits over night we have same problem
  • 1,554 Answers
You cleared the bios settings by removing the battery.
Go into the dell bios at startup F2
make sure it sees the cd rom drive
then save and exit
should fix the issue
Posted on Jan 26, 2008
  • Karl Whisenand
    Karl Whisenand Jan 27, 2008
    See this dell page
    go to page system setup screens
    see that they are enabled (hit enter to change)
    if you still cannot make it see the cd rom drive and as you were inside the case then reopen case and be sure that you did not knock the cables loose from the cd drive. go to the back of cd 2 cables follow to board and be certain they are seated well.
Dell dimension 8200 help
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 09, 2014 | Dell Dimension 8200 PC Desktop
My Dell Desktop Dimension 5150 does not start sometimes
loose connect or mother board problem (is your os & HDD is OK ?)
Jun 24, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
PC will NOT turn on;flashing amber lights
The power LED Flashing AMBER indicates the power supply in the tower has failed and needs replacement.
You can get a replacement here:
Dec 20, 2009 | Dell Dimension 5150 Intel Pentium 4 w/HT...
Start button blinks amber - cannot start pc
Press and hold the start button for more than 10 seconds continuouly. then try to switch on after 10 seconds. your system should start now without any problem. I hope this is helpful to you
Nov 07, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
CD-rom can not read or burn, but DVD-reader in
Try to ship it back where you purchase that device cause the hardware device has the problem maybe a factory defect then you should ship it back. Try to used light scribe utility program on your writer cause it will help your dvd/cd device read properly.
Jun 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 automatically turns off
That flashing amber light is usually a sign the power supply is failed or is failing. I would suspect the power supply is the problem in yours. It is the better of the two problems connected with the flashing amber light..the other is motherboard is failing. Arrrr!
hope this helps (it takes a standard- oh say 350 watt 20-24 pin power supply unit.)
Hope an answer helps.
Please leave rating, thankyou
May 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 will not boot. Flashes amber light
I had the same issue with my Dell Dimension 5150 and I replaced the front I/O USB Audio Panel and it booted right up.
Feb 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 cd-rom stopped working
Open your tower and reseat all the cables that are running to the CD ROM (generally a flat white cable). Also reseat the other end of the cable to the motherboard too.
Ensure that CD Drive is enabled in BIOS (Press F2 as the system boots up to enter into BIOS) Please get back if you need any further help.
Jan 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My dimension 5150 has had problems switching on for a few weeks. the power button light is flashing an amber colour...
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged. Here’s a link to the service manual for your model:
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Dec 06, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dvd drive in dell does not work
depending on the drive it can be your upper and lower registry filters, use this link at your own risk and whenever you work in regedit, make sure you create a recovery point before hand!
Apr 03, 2008 | Computers & Internet
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
1,745 people viewed this question
Alun Cox
