Question about Whirlpool LER5636P Electric Dryer
Whirlpool Dryer My dryer heating element turns on and then shuts off after about 2 min. The rest of the cycle, it doesn't turn back on - HELP?!
  • 770 Answers
Remove your vent from the back of the dryer and run a load if it works ok you need to clean out your vent thats going to the outside
Posted on Jan 26, 2008
6ya staff
SOURCE:
Why does my Whirlpool electric dryer - model SEDS800JQ0, shut off after 2 minutes?
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Aug 09, 2014 | Whirlpool Dryers
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Whirlpool dryer shuts off at the end of cycle, but timer continues to tick. It ticks through the next cycle and stops ticking at that cycles off?
follow this steps and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it.
Oct 01, 2013 | Whirlpool Dryers
I have a Whirlpool electric dryer M/ WEP5300o that will not heat. I have replaced the Cycling Thermostat, High limit thermostat, Thermal fuse and heating element. It still doesn't heat. There are
If you have fuses on your electric panel it normally uses 2 fuses, 1 for electric power 1 for heat. The same may be true on the circuit board panel check this to eliminate this possibility
Feb 02, 2013 | Whirlpool Dryers
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
Dec 11, 2012 | Whirlpool Dryers
My dryer takes 2 to 3 cycles to dry my clothes.
Check the following areas to combat this issue. in most cases, this will be a Venting issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Element heats, dryer tumbles, no heat in drum, never shuts off
Hi, If the dryer heats but will not advance in either time or auto cycles, you need to change the timer.
You can test to see if the timer is getting voltage. Remove the top rear panel and locate the two wires going to the timer motor. There should be 120V when the dryer is running in time dry.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Gold Electric Dryer.
Hope your sitting down. There is not just heating elements in the dryer there are thermal switches that turn heating elements off & on like your house thermostat clicks off & on. Also there are overheating thermal switches to keep the elements from setting the dryer, clothes on fire. More than likely you overheating thermal switch has tripped, from lent in vent or pinched vent tube or normal failure. Some of these switches can be reset, others replaced. If you can not trouble shoot electrical circuits leave it to repairman. Switch $20.00 to $42.00 Labor service call cheaper to buy cheap new dryer. Could be heating element but most use only one with different inputs for heat. If your getting some heat not likely element.
Mar 08, 2009 | Dryers
Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Jan 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Whirlpool LER5636P Electric Dryer Logo
54 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
