Question about HP Compaq FP5315 15" LCD Monitor
Compaq FP 5315 monitor-Replacement of Power board
My power board is faulty. There is a clear burning mark of one diode. Some other components may be faulty. the fuse link is ok. Can I have a new power board. Please help.
Ashutosh
  • 22 Answers
There are also 5 or 6 bad Capacitors on on top but as far as i know the only way to fix these power boards is to replace the componets themselves as you can not buy a power board.
Posted on Mar 03, 2008
Hi,.. I was given a compaq FP 7317 with the tower, key board,...monitor keeps saying "going to sleep" when I finally got it all pluged in. HELP. HOW TO GET OUT OF GOING TO SLEEP?
To disable sleep mode in vista follow the steps
Go to start and type in the search box Power Options hit the enter button
On the Left side there is a panel Click Change when the computer sleeps
Click the drop-down box which says Put the computer to sleep and select Never
Click Save changes
Jun 28, 2011 | HP Compaq FP 7317 17" Flat Panel LCD...
Compaq FP-5315 won't turn on goes to sleep every time
More likely to have bad caps with bulging top in the power supply, that is the first place to look for the monitor this old, see example of failed monitos due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you se sowe help you more.
Mar 04, 2010 | HP Compaq FP5315 15" LCD Monitor
Samsung SyncMaster 213T monitor after power failure the on light is on but the monitor will not do anything, no menu or anything just the black screen with the on light on.
This may be the power supply board.
the rectifier chip or diodes may have been fried by a surge of power when the power came back on.
If the monitor was not plug into a surge protector this may have damaged the power regulator the main board of the the monitor. The primary side of the board should be tested for faulty components.
Dec 02, 2009 | Computers & Internet
My monitor, once i start my computer then monitor start to flick and became black screen, what is the problem please let me konw any thing i can do for my monitor. modle no- compaq fp 5315
its a risky for you to open the monitor and repair its power supply, coz its your monitor's power supply prob..
please contact with warranty providers.
good luck
shafky
Jun 19, 2009 | HP Compaq FP5315 15" LCD Monitor
Yuraku LCD TFT Monitor MA7BBA Wont power up
I've had the diods problem on such a monitor recently. To fix it I had to change the fuse and two 1N4007 diods as you can see on the following page:
http://tux12.free.fr/MA7BBA-recovery.html
You will notice I mounted the replacement diods on the solder side ( second hand components with too short leads) and that only 3 diod locations are seen on the component side; the fourth is hidden under the transformer on the top side.
Hope this can still be of any help.
Apr 28, 2009 | Computers & Internet
Compaq FP 5315
Yeah just replace it with a regular 7.5 volt zener diode.
Oct 02, 2008 | Computers & Internet
Will not power up
Try and replace the three Elite 16V 1000µF caps, especially if they are swollen.
Worked for a "Power on-then off" monitor of a friend of mine recently. Case easy to open, gotta find hidden screws to drop base. Let me know if it worked
Jun 25, 2008 | Compaq FP 7317 17" LCD Monitor
HP Compaq FP5315 15" LCD Monitor dead
yeah replace the caps and sometimes the 7.5v zener diode burns up too. I have been replacing the surface mount ones with just a regular through diode
Jun 11, 2008 | HP Compaq FP5315 15" LCD Monitor
Monitor blinks
your monitor haveing power supply problume it is not swtiching properly
ashok
Jan 21, 2008 | HP Compaq FP5315 15" LCD Monitor
Compaq FP 5315 Monitor Disassembly
This is how I did it.
1- Remove the four screws in the back of the monitor. Two are in the bottom corners and two more near the bottom center ( these hold the stand in place).
2- Remove the stand.
3-The case back is held on by the four screws and a number of plastic pressure clips. After removing the screws: using a fairly wide flat bladed screw driver; insert the blade in either of the two slots on the bottom edge of the case and twist with medium force. This begins the seperation of the back from the rest of the monitor. As the crack widens, begin moving the blade of the screw driver along the widening crack (around the case edge) and twisting gently. This releases each pressure clip in turn. Separate the case back from the rest of the monitor.
I did this this way with my monitor. It works.
Good luck.
Bill
Dec 02, 2006 | Compaq FP 5017 15" Flat Panel LCD Monitor
HP Compaq FP5315 15" LCD Monitor Logo
153 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
