Question about Cherokee Jeep Grand - RBB AM/FM Stereo Radio w/Cassette Player and integrated CD Changer Controls
Car radio I have a samsung radio and it cuts off after about 20 minutes of playing and it won't come back on. I have to turn it off and wait about 30 to 35 minutes and turn it on again, but it keep doing the same thing. Whether I'm playing the radio or playing my CDs.
    Problem Solver:
  • 6 Answers
Obviously there is a heating problem with it. It seems that it is getting too hot and its shutting down before it overheats and catches fire. Pull the radio out of the dash and leave the wires connected. Are there any bare wires or ones not connected good? There may be a short between the wires thats not a significant enough connection to blow the fuse. Seperate the wires from each other and turn the radio back on. Let it play till the time that it usually shuts down. If its still doing it I would suggest smashing it with a hammer.
Posted on Jan 27, 2008
  • james
    james Nov 16, 2013
    lol yes a BIG hammer...just took an axe to mine...felt sooo good to kill it..
I go to the store. Turn truck off. Go inside and come back outside and the truck won't start. Wait about 20 minutes and truck starts right up. This has happend 3 times in the last week. This morni
usually this is a cam position sensor I have found this problem many times by replaceing the camshaft position sensor I believe this will solve your problem if this is helpful please leave good feedback
Apr 13, 2013 | Ford F-150 Cars & Trucks
Radio cuts out
When it cuts out does the radio's display still work? Can you change channels but just not HEAR anything? Did you buy it from a private party or a dealer? Acura dealers may cover this under a warranty. Otherwise, time to join an Acura forum and look for answers there.
GL,
Td
Oct 01, 2012 | 2005 Acura TL
Vizio 32 Inch, turn on completely fine for about 20-30 minutes. Then sound goes out accompanied by high pitch noise and picture has varying lines or colors through it. Won't power off, have to un
Are you a decent do it yourselfer? It sounds like it is the capacitors. What happens is they get hot and expand (the top of the Capacitor). The top will be dome shaped and it will look like the top is splitting open. You can buy (about $1.50 ea.) the capacitors at your local electronics store (not Radio Shack they usually don't have a high enough amp).
You will need to take the back off and look at all of the capacitors to see which ones are bad. Usually it will be 2 or 3 of the larger ones but there could be more. Next you will need a soldering iron with a fine tip and some wicking material. How could are you at soldering and de-soldering? before I go on.
If you let me know the model # of your set I can be a little more detailed also.
Sep 24, 2012 | Vizio L32 32 in. LCD HDTV
Need torque specs for a head on a 1997 bmw 528i with a 2.8l
(29.5 lbs)40 nm and wait 20 minutes and turn 90 degree wait for 20 minutes and turn additional 90 degree for "IRON BLOCK" . "Alumn. Block" is (22.1 lbs) 30 nm wait 20 minutes and turn 90 degree, wait 20 minutes then turn additional 90 degree. DONE!
Sep 10, 2012 | Cars & Trucks
Anti-thief system cut off power to den gine an won't cut it back on
If you are dealing with the anti theft the anti theft will flash as you are trying to start the vehicle if this is the case then it is the anti theft if not then you are not dealing with a ant theft issue. You can do a 30 minute relearn procedure without a scan tool. here is how Turn ignition on without the engine reunning.attempt to start the vehicle then release the key to ON.(vehicle doest start) Observe the security light.afeter 10 minutes the security light will turn off.Turn off the ignition and wait 5 seconds.do this 3 times for 30 minutes. start the engine with the engine started the vehicle will learn the passlock key.
Feb 24, 2012 | Cars & Trucks
2001 Buick Regal cuts off while driving at times also won't start
The ignition switch on that model is rated @ 50amps. When I was driving my 2001 Regal LS (at 120,000 miles) and used the turn signal, the engine would die, when I switched the turn signal off, the engine ran. So I replaced the ignition switch, and all is well.
merkfritz@yahoo.com
Mar 24, 2009 | 2001 Buick Regal
Anti theft light comes on when driving
no cutoff switch!! try this turn key to on, do not start car. let sit for about 30 minutes, after 30 minutes, turn key off. wait 15 seconds and try to start car. this should reset anti theft system.
Feb 20, 2009 | 2000 Chevrolet Malibu
Radio code
leave the radio switched to the on position, turn your car ignition on to "accessories" and wait for about 20-30 minutes. the radio should change from ERR and offer you to enter the CODE agian. Good luck!
Jul 05, 2008 | 1993 Ford Festiva
Car Audio & Video Logo
129 people viewed this question
Top Cherokee Car Audio & Video Experts
xxxxxx xxx
chargerhp
chargerhp
Are you a Cherokee Car Audio and Video Expert? Answer questions, earn points and help others
