Sony VCR Belt Replacement
How do I replace the belt on my Sony SLV-N51 VCR, and where do I find a replacement belt? I've taken off the top and front of the case, but I can't see where the belt goes. Please help.
  • csratcliff Jan 27, 2008
    Thanks for your response. Sony wanted to charge me over $40 to repair or replace my VCR, and the only local person I could find thus far who repairs VCRs wanted to charge me a $10 diagnostic fee that would go toward whatever was needed to repair the machine, which after much coaxing, he would only guess could cost between $30 and $60. So, in the end, I just bought myself a used VCR in good condition through craigslist.com. Not too bad, but I still have a broken VCR that otherwise was a very fine machine. If I find a local repair service that will fix it for under $30, I might still consider doing so.
  • Anonymous May 11, 2010
    There are more than one belts in a VCR you have the idler belt, the elevator belt, the idler itself which is a rubber tire. I suggest you either get a repair manual or take this to a pro. The belts are easy to get Sony sells them as well as most small electronics stores. most people fixing VCR's now are hungry for work and with DVD players at low prices and VCR's at even lower prices won't gouge you.
My experience in replacing the drive belt - the most common problem in VCRs - is that if it is a Consumer model it is a horrible task.
The whole mechanism needs to be removed, to replace a $3.00 part. Turn around time about 2 hours - with much cursing.
With the Indistrial models, turn it over and remove the small panel, replace with the $3.00 part. Turn around about 30 minutes - no problem.
Posted on Jun 06, 2008
6ya staff
SOURCE:
When recording some V H S tapes it says to check the lower left hand side of the tape I'm not sure what to look for
this is recording lock for the tape. you must remove it. asquare hole with plastic in the middle... remove it
Jun 02, 2011 | Sony SLV-N51 VHS VCR
I have a Sony VCR. Model SLV-N51. I record a lot of television shows on new Sony VHS tapes and when I play back the tape the picture scrambles every so often. When I rewind it back to where the...
First of all I want you to check the tape inside it's case as soon as the problem occurs. Stop it and eject. You'll find a button on the side of the VHS tape, press it and you should be able to lift the flap. Look at the tape it should be smooth and shiny. If it is there's nothing causing damage. If you see any damage then the mechnism is causing it.
If that is good (which I think it will be) I want you to take off the top cover of the VCR and with some Servisol Video 40 spray, blast all the surfaces that the tape comes into contact with. You can wipe them too with cotton buds. Give the heads special attention. Once done leave for 30 mins and try it out.
I think the problem might be dirt that the head cleaner tape couldn't shift. The sound dipping being the hi-fi sound dropping out reverting back to the mono sound head. When you rewind the video tape acts like a cloth for an instance, hence the better performance.
Sep 11, 2010 | Sony Televison & Video
Vcr tape ejects when i want to record
One possibilty is the record sensor that pushes against the tab on the video tape (the bit you break off to prevent a tape being recorded on) has bent out of shape and the video therefore thinks ALL tapes are pre-recorded or protected and rejects them.
Aug 30, 2010 | Sony SLV-N51 VHS VCR
Vcr ejects tape when i try to record.
is the erase protection tab removed from the cassette?
if yes there is a square hole on the back of the tape visible when you insert it.
put a piece of sticky tape over this hole and make shure it does not come loose.
it should record fine now when you insert it again.
Sony SLV-D100 DVD Player / VCR Combo Remote not working.
Try a universal remote to determine if it is your remote or you combos IR reciever.
Jul 22, 2010 | Sony SLV-D100 DVD Player/VCR
One piece was found lose in the sony vcr (sony slv-n51)
My best advice is you should look for the service manual for the model. I would try Manuals in PDF for this, though they do charge, I have used them and they are a good company. Though you could try a web search to see if you can get it free first.
The reason I recomend you get one is not just that you will be able to identify the part straight away, but rather I suspect that the mechanism may have gone out of sync with the damage. And if it has you will have a hell of a job setting the mode switch without a the manual. And if that is not set right then all sorts will go wrong!
May 10, 2010 | Sony SLV-N50 VHS VCR
Sony model# SLV-D500P: The casset loading motor does not stop
Hi, thats is a mode switch and mechanism
alignement problem;;; if you turn manually
loading motor belt vcr unpluged until the cassette
housing is in loading position dont put a tape in,,
plug it again the cassette housing should go back in eject position thats is a good way to verify the mechanism. then try first to replace the loading belt
the idler wheel and the capstan belt then try to insert
a tape in if it doesnt work you wil have to clean the mode switch and verify the mechanism alignement
if you not sure or not familiar about this process
you can hask a friend who you know he is familiar whit this or see a repair shop its a 30 minute job
hope that will help you
have a nice day
Apr 09, 2010 | Sanyo VWM-700 VCR
Sony VCR rewind and counter problem
The belts are slipping. Every 5 years is about right for replacing them all.
Jan 24, 2008 | Televison & Video
Televison & Video Logo
1,370 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
