Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Turns off after 10 minutes
47 inch projection turns off after 10 minutes or so...have to unplug to turn back on....sos shows code 1...but im not sure what to check from there....
  • 11 more comments
  • suzuki99 Jan 27, 2008
    i already bought the service manual to find out how to read the codes.....so then basically i should keep going and start testing all the stuff in the service manual till i find one thats out of whack???
    i am not an electrician but i do have the service manual now....so can i test all this or is it best to a pro????the rear is off the tv....
    hey also i noticed if i have an input connected to cable it turns off...right now its sitting there with noting plugged in but the tv is on and it still running.....how come it runs if i have nothing plugged into it for picture but it shuts off as soon as i run cable tv with a picture???
    if i put a movie on it runs 10 minutes minimum and 30 minutes max....if i dont put anything on and just leave the screen white.....it runs for ever....thats with no rca or coax even hooked....so does it sound more of a precessor issue then???
    yes i tried all the inputs on the front and back...coax and rca....i didnt try s video....but if any of them are hooked and playing it turns off after a while.....if nothing is hooked the tv stayd on for ever...
    hey i just checked the codes again and sos is 1
    the rom corr. check sum: is 8
    so im not sure what the number 8 is about....does it mean anything????
    is the processor the same as the eeprom????
  • suzuki99 Jan 31, 2008
    i bought the manual and brought the tv and manual to get looked at....the guy called tonight...in the manual it is missing a page of the schematics....it is in section 22.9...and its missing 5 of 5....but the page number is 68 then 69 and then 70.....so how can i get that schematics number 5 of 5 so he can continue to trace it???
    its in section 22.9 it starts off as 1 of 5 for the board schematics.....its number 4 of 5 that isnt there....but the page number is correct....it goes page 68 then 69 then 70...just like the page isnt supposed to be there....but anyways its section 22.9 and number 4 of 5...
    ok i just checked and its the" d" board
    ok i sent a message...thanx
  • suzuki99 Feb 01, 2008
    did u send it suzuki99@nb.sympatico.ca ????? i didnt get anything yet
    i dont think im limited...but i never received anything yet....is there a way i could download that from a site or something ????
    i got your scan....thanx a lot...im gona give it to the guy and hopefully he figure the problem with my tv....thanx again
  • Panasonic Master
  • 8,617 Answers
Code 1 is +140 volt.hich means your set is going into protection shutdown to protect the circuitry. If you have soldering skills and testing ability you may possibly be able to do the testing to repair this . It is usually a thermal problem with a trans or diode that loses tolerance when warmed up allowing voltages to increase thereby putting the set into shutdown condition. If you would like the service manual for your model you can get it for 10.99 at the following link. Hope this helps.
http://servicemanuals.vstore.ca/
Posted on Jan 26, 2008
  • 10 more comments
  • Sonny Berry
    Sonny Berry Jan 27, 2008
    Check in the start up circuitry first. chances are you will find it quicker if you check the reulators first for voltages if they are not correct it usually means a resistor or diode may be open. If they are high or non existant off theregs emmitter . Pull the regulator to see if thats open or shorted.
  • Sonny Berry
    you could have a problem in the signal circuits. when a signal is applied the set goes into shutdown. That sounds like a processor issue. If you arent sure about the diagnosis it may be wise to call in a tech. especially if it is the processor. You would need specialized equipment to diagnose.
  • Sonny Berry
    It could be as simple as some capacitors. Have you tried to imput a signal through the auxillary inputs such as ant.B ? or are the all having the same symptom?
  • Sonny Berry
    yes the eeprom is the processor They have to be reprogramed by entering codes.
  • Sonny Berry
    Sonny Berry Jan 31, 2008
    i will see if i can locate page 5 of 5 schematics for that set.I have located a set at the other site I work at however are set is 23 pages for that set. Broke down by board. Do you know which board your missing the page to, and if you post a email link I will email you that section.
  • Sonny Berry
    post your email or send me a message to slinteriors@yahoo.com and I will email you the D board schematics.
  • Sonny Berry
    I just sent you the entire manual for your set, it has all the info you should need. Hope it helps glad I could help.
  • Sonny Berry
    Sonny Berry Feb 01, 2008
    Yes I sent it about a half hr ago from the other site let me check on it again.
  • Sonny Berry
    I just checked did you get an email from service manuals at lycos? It should have been an attachment its 20 MB. Your not limited on attachment sizes are you?
  • Sonny Berry
    no they dont download they email everything, usually if the emails dont go through its because the size is too big. i will try to scan page 5 of D board and try to email that to you in a few minutes.
  • Sonny Berry
    I just sent the scanned schematics for the D Board
  • Sonny Berry
    Glad I could help.
I was watching TV it shut off and the power button flashed a bunch. I unplugged it waited for a while plugged it back in. It did not turn back on until i held down the menu button on the set.
I found the following blog on the web.
Panasonic Viera Plasma Failure Page
November 14, 2010 ·
Blink Codes and what they mean (8-13):
8 blinks Driver SOS 3 SS Board (SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG BoardDTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Boardwith IC8001
Make sure the inside of the TV is clear of DUST especially by the power supply and fins.
May 02, 2015 | Panasonic Viera Tc-p42x5 42" Inch Flat...
Blinking red power light on a Panasonic Viera 47 in. plasma
No sure how many blinks you have but here are the blink error codes and the common boards failures for each
Blinking Times Contents Check point
1 Panel SOSPanel
3 P+ 3.3V SOS A-Board
4 Power SOS P-Board
5 P+ 5V SOS A-Board
6 Driver SOS1SN-Board
7 Driver SOS2SN-Board
8 Driver SOS3SS-Board
9 Discharge Control A-Board
10 Sub 5V SOSA-Board
SN-Board
SS-Board
P-Board
12 Sound SOS A-Board
Speaker
13 Emergency SOS A-Board
Feb 01, 2014 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
Turns off by itself
you have an overheat problem somewhere on one of the pc boards and the thermosistor is sutting it downfor safety you need a pro to service it sorry
Sep 28, 2009 | Samsung HCL4715W 47" Rear Projection...
47 projection
im sorry to say but you need to have a IC replaced on the main board to fix this
Sep 02, 2008 | Panasonic PT-47WX49 47" Rear Projection...
I turn the tv on and I can hear the sound just fine. However, the picture takes about 5 or 10 minutes to show up.
Taking to shop. It was not a projection tv, just a rca 27 inch. Thanks for checking back with me.
Jul 05, 2008 | Televison & Video
Power problem
require your complete model number for the rear of the unit,please
Mar 19, 2008 | Samsung HCN473W 47" Rear Projection...
Power problem
How many blinks is it doing? It has a built in self diagnosis code that it will blink. Pause a second then blink again. Count the blinks then let me know.
Jan 17, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Tv turned off
When the tv shuts done does the power light blink? If so what number does it blink? That will tell me which circuit your problem is in. Notice the number of blinks then let me know. Also what is the model number of your set.
Jan 08, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
87 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
