Question about ASUS A8V Deluxe Motherboard
Asus a8v fail
I use this matherboard about 1 year and it was good but now it don´t start the led power on(green) and the hd led bright but no start nothing.what is wrong?
  • Anonymous Oct 11, 2008
    I have the same problem. After being switched off at the wall if I try and power up the computer the power led and HDD led both come on but the hard disks fail to spin up and there is no action on the screen. If I leave the PC powered up for 5 minutes and then push the reset button it will usually start. If I leave it turned on at the wall and just use the power button to shut it down. I can usually start it again.
    I presume either the CMOS battery is failing but I don't see why it fails this way or there are some capacitors on the motherboard that are getting past there useful life.
    PC is ASUS A8V delux motherboard, AMD 64 Athlon, 1G memory, XP Pro. Has worked well for past 2 1/2 years. (The PC is 3 1/2 years old but the motherboard was replaced under warranty when it failed after 11 months)
    Any suggestions would be welcome.
  • Claudio Pereira
    Claudio Pereira May 11, 2010
    hi Moreira,
    possibly you're portuguese, but here it goes:
    open the pc and check if the led's cable is connected, wich comes from the front side.
    if it is, I'll need more information about any possible changes made as the graphics board, for example.
Ok, the fan run when I switched on and the video card is good and all power connectors & data cables are connected and hard drive is good .
the bios not start and the led power is lighted and the hd led is lighted all the time (isn´t normal), could you tell me What electronic component can cause this problem ?.
Thanks Moreira (Brazilian from Fortaleza Ce.)
Posted on Jan 31, 2008
    President:
  • 2,351 Answers
Did you plug in the ATX 12v 4pin power plug. Page 2-27 of your manual? Recheck all power connectors & data cables.
Still have your manual? If not click here. Great board. http://support.asus.com/download/download.aspx?SLanguage=en-us
Fill in the 3 windows & GO.
Rock N' Roll!
Please vote...
Posted on Jan 27, 2008
    Genius:
  • 1,554 Answers
Does the power supply fan run when switched on.
does the hard drive spin up .
Have you reseated the video card.
Asus A8V-E Deluxe dead, need expert help !!
If there is a system error, you will hear a beep code.
Nov 30, 2017 | Computers & Internet
Green led power light comes on then power goes off and comes back on repeatedly. It never posts.
Your motherboard was manufactured in late 2009. The green LED on the MB supplies DC power to the BIOS. This is known as standby. This is a relay is built into the MB maintaining the required 3 volt. When you power up the MB the power supply maintains the
3 volt DC to the BIOS. So the relay is not working. Suggest you contact Asus. All Asus MB's carry a three year warranty. Your board will need to be replaced by Asus. Call Asus at; 1-812-282-2787. (Asus Tech IL EST) M-F 8:00 to 5:00PM) There is a sticker on the LPT printer port. Write down the serial number, you'll need this when you make the call.
Mike
Jul 27, 2010 | ASUS P7P55D PRO Motherboard
Failed A8V-VM SE Bios update attempt.
ASUS has a marvelous BIOS upgrade utility that runs from Windows,Download the correct one from the ASUS web site
http://support.asus.com/download/download_item.aspx?product=1&model=A8V-VM
Dont forget to rate the advice.
http://www.aa1consulting.com
Aug 03, 2009 | ASUS A8V-VM Motherboard
Asus A8V-E not start
Looking at this post, I think your Motherboard is bad.
Have you tried a different Video Card?
My other thought is the CPU is overheating due to incorrect seating of the FAN and heat sink.
Try cleaning the CPU off, and put new paste on the CPU, then re-seat the heat sink.
Be careful to make sure the anchors are pushed all the way down by slightly twisting or wiggling the heat sink.
Check for looseness.
Push down on all memory sticks to ensure they are seated all the way in.
They should click on both sides.
If it still gives you a red light, then contact the website of the manufacturer, and get an RMA number for a replacement.
Jul 24, 2009 | ASUS A8V-E Deluxe Motherboard
ASUS A8JP Will Not Power On
"When the charger is connected to an AC source, the green LED shines steady and bright."
are you talking about the led on the AC-adaptor? cause if its that led that dims down, its a defective ac-adapter (even tho you still might not believe me). replace it and try again.
how would you know that the battery is fully charged?
please rate my solution after you have tested if it works out for you :)
May 19, 2009 | ASUS A8Jp Notebook
When i switch on my computer the power led just blinks and nothing happens
try removing the cmos battery for about an hour , make sure the power is out of the computer before removing
Dec 31, 2008 | ASUS A8V-MX Motherboard
Raid complaint
hi! Download the pdf manual of your motherboard A8X-MX in this website (www.asus.com), just be patient searching it. Have a nice day!
Dec 28, 2008 | ASUS A8V-MX Motherboard
Can't start bios
Hi dariel6167, Asus does cover their boards for three years. Your board came out in 2006. The error message you received (Over clocking Failed) is a normal error message when there is an issue with the bios. You can try to flash the bios with a newer bios file. (This may fix the bios). Download the bios file 1001 & bios- utilities from this Asus link.
http://support.asus.com/download/download.aspx?modelname=P5V-VM%20DH&SLanguage=en-us
When contacting Asus please write down the number found on a white sticker located on the pink LPT port. You will need to open your case & look at the LPT port to see the white sticker. If flashing the bios fails you can still buy an updated bios chip through Asus online E-store at this link: http://estore.asus.com/shop/
You do not pay Asus for repairs or replacement, only shipping to Asus is on you.
Mike
Aug 13, 2008 | Computers & Internet
ASUS A8V Deluxe Motherboard Logo
192 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
