Question about Hampton Bay 52 In. Cameron II Plus Ceiling Fan, Brushed Steel & Cobalt Blue Finish
Wiring The wires coming out of the ceiling are tan black and then green on aseperate screw. Colors on fan are blue black and white. What go together? Laura
    Scholar:
  • 72 Answers
The tan is probably a worn white, age will turn it that color. Since you don't have separate switches for the light and fan, then the black (hot for fan) and blue (hot for light kit) go twisted together and hooked to the black from the box in ceiling with a wire nut. The white goes to the other white, it's the neutral wire in the schematic, which if you took apart your breaker box, is attached to the grounding clamp. There should be a green wire that will attach to the extension pole right at the ball on a ball and socket mounting or the motor casing on a flush mount. This should be attached to the green or bare wire coming out of ceiling box. Hope this helps.
Posted on Jan 27, 2008
Black wire, white wire, and tan wire coming from ceiling. New fan has blue, black, white wire and green wire on the bracket how does it hook up
1. Have on hand either wire connectors or electrical tape
2. Look at the wires coming from your ceiling fan. The black wire from the ceiling fan is the hot wire that runs the motor and turns the fan blades. The white wire is neutral and completes the fan circuit. The blue wire is the hot wire for the ceiling fan light fixture. The ceiling fan motor does not have a ground wire.
3. Find the short green wire or the green ground screw on your ceiling fan hanging bracket. Attach the bare copper wire from your electrical box to the short green wire by twisting and orange wire connector to the two wires. If you only have a green ground screw, wrap the bare copper wire around this screw and tighten the screw against the bracket to secure the wire.
4. Match the end of the white insulated wire from the ceiling fan to the end of the white wire from your electrical box. Twist a wire connector onto the two wires to complete the neutral circuit.
5. Connect the black insulated wire from the ceiling fan to the black insulated wire from the electrical box. If you do not have a separate toggle switch on the wall to operate the ceiling fan and light separately, grab the blue wire and place it with the black wire from the fan motor and the black insulated wire from the electrical box. Twist a wire connector to all three wires. If you have the additional toggle switch, connect the two black wires together with an orange wire connector, and then match the blue wire and the red wire together. Twist another orange wire connector on the red and blue wires
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jamie_580d75bd3bb6d659
Nov 11, 2017 | Dryers
How wiring a new ceiling fan in a 1995 mobile home that is controled by a wall switch and controls 2 fans
Should be Bk &Blue(wirenut togerher) - bk, white - Wh, Green - green
Aug 28, 2014 | Dryers
I have 3 black, 1 tan, 1 gray wireing from ceiling. I have a wall switch that controls 2 ceiling fans in a mobile home . i want to connect a new ceiling fan that has 1 black, 1 white, 1 blue wireing.
The gray tan and the other wires usually have plug on the end and the plug into the fan unit when it's put together . The part the mounts to the ceiling should be blue black and white
Aug 28, 2014 | Cars & Trucks
Wiring diagram for harbor breeze celing fan
The colors of the wires in the Harbor Breeze ceiling fan kits tell you what their functions are. The black wire is hot for the fan, the white is a common wire for both the fan and the light kit, green is ground and blue is hot for the light kit. locate the black and blue wires from the ceiling fan and connect them to the black wire inside the electrical junction box by twisting an orange wire connector onto all three wires. Locate the white wire from the ceiling fan and the white wire from the junction box and attach the two wires together with a wire connector. Connect the bare copper wire onto the green wire from the ceiling fan mounting bracket by twisting an orange wire connector onto the two wires. Push all wiring inside the electrical box. good-day !
Nov 26, 2011 | Hunter 52" Ceiling Fan With Light And...
I have a used ceiling fan that I want to install. I see only three wires coming out of the top; a black, a white, and a blue. The fixture has the fan and 4 lights attached. Can you tell me how to...
Black is the hot wire, white is the neutral, and blue is the hot wire for the lights. If you only have a black, white and green(ground) coming from the electric box in the ceiling, you will have to wire the blue and black together coming from the fan and connect them both to the black coming from the box. The white will connect to the white coming from the box in the ceiling. You should have a ground wire off of the fan. If not look for a ground screw on the fan down rod. The ground is for safety.
Apr 08, 2011 | Heating & Cooling
Ceiling Fan
Green is always equiptment ground. It goes to the green wire ,if you have one in the electric outlet box,or mounted to the box itself itf you have not the green in the box.
Green always  to green White to white. Nutural wire. Orange to black if their is no black in the box. Orange =Black
I am also thinking that you blue will is also the positive for the fan. I woudl hook it to your orange also .  .
Jan 05, 2009 | Hampton Bay 24002 Ceiling Fan
Wiring connection ceiling fan
copper to green , white to white , seperate the black and the black with th white tracer you wired together connect the black to the black and the black with white tracer to the red in ceiling , without looking this is my best advise ,good lk
Mar 24, 2008 | Hunter 20531 Vista Brushed Nickel Ceiling...
Wiring-
The ceiling has Black and white (dirty I expect) ,
black is hot , white is neutral
the green is ground ( the fan will ground through the mounting screws)
so connect the black to black (hot)
as you have only one choice left that is the blue/white to white.
I assume you have a strong bracket and a fan was existing previously in this spot. If not you have to install a new fan support and wiring box.
Jan 26, 2008 | Universal Remote Control Hampton Bay...
Ceiling fan
OK, the wires coming from the top of the fan are going to go into the junction box in your ceiling. Out of the ceiling, you should have a white wire, a black wire, and a green or bare copper ground wire. Make sure your power is off at the fan. Your wires coming out of the fan should be white, black, blue, and a green ground wire. Pull the wires through the top of your fan, and connect the white to the white in the ceiling, the black and blue wires from the fan to the black wire in the ceiling, and then connect your ground wires together. Make sure you use wire nuts and twist them firmly onto the ends of the wires. If you happen to have a red wire coming out of the ceiling as well, just put a wire nut on it and stuff it back into the ceiling box. The blue wire is what works your light kit, and the black is for the fan. Hope this helps you!
Jan 05, 2008 | Casablanca Fan 3245T Ceiling
Hampton Bay 52 In. Cameron II Plus Ceiling Fan, Brushed Steel & Cobalt Blue Finish Logo
246 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
