Question about Dell OptiPlex GX260 PC Desktop
Have a problem with my parallel port...please help
I have a software key for a cad/cam program that plugs into the parallel port, but every time try and start the program, it tells me it cant find the key. I know you can change the settings for the port in the startup settings, but I dont know which one it is and there are quite a few options. Can anybody point me in the right direction?
thanks, courtney
  • 1 more comment
  • skypirate Jan 26, 2008
    What are the three options?
  • skypirate Jan 27, 2008
    under the mode ECP, there are more options. One says " I/O Address " and the other has " DMA Channel "
    the options to pick for "I/O" are " 378h, 278h, or 3BCH "
    the options to pick for "DMA" are " off, DMA 1, or DMA 3 "
    what do i put for those rows?
  • skypirate Jan 28, 2008
    i wasnt able to get it to work, but thanks anyway
    Genius:
  • 1,554 Answers
Enter the bios at startup , F2
go to the section on the integrated peripherals
you may have to change the ports settings to one of 3 choices.
Posted on Jan 26, 2008
  • 1 more comment
  • Karl Whisenand
    Karl Whisenand Jan 26, 2008
    In the BIOS for the PC, change LPT port type from EPP to ECP, Enhanced, or Standard.
    It is likely set on epp now and the dongle needs standard.
  • Karl Whisenand
    Karl Whisenand Jan 27, 2008
    for the setting of ecp its usually 378 and dma 1
    but try the standard setting first.
  • Karl Whisenand
    Karl Whisenand Jan 28, 2008
    I was reading up on some cad dongles,
    most say to use ECP dma3 or Dma1
    the other fix was that some onboard lpt ports only have 3 volt output instead of 5.
    Thus requiring an external printer card.
    When I worked at Dell we did have some reports of this .
    I have dongles on several of my dell's and 1/3 of them are using a pci parallell card, mainly because I was running out of ports.
    So I may have accidentally fixed an issue
My computer cannot detect my scanner. Error Code: 0x0070800
The FB320P is a parallel port scanner and is having problems communicating with the computer. Are you connecting it directly to the parallel port on the computer? In that case, you may not have bi-directional communication enabled. Turn off the scanner and the computer and disconnect the data cable from the computer. Turn on the computer and enter the BIOS. (Press Esc, F1, F10, or Del repeatedly after you turn the computer. You should see a screen with the correct key to press; it varies depending on your BIOS and motherboard. If you miss the timing, shut down the computer and try again.) In the BIOS, search for the parallel port settings and see if you can enable bi-directional communication.
Not all parallel ports support bi-directional communication. If you can't enable the feature, you need a different parallel port. Try a PCI slot add-on card; just check the features and check the manual for enabling bi-directional communication.
If you are using a USB to parallel port adapter, get a different one that supports the bi-directional communication.
What OS are you using? There are a few that had ASPI driver issues; a third party app, ForceASPI, may help. See http://www.afterdawn.com/software/cd_dvd/dvd_tools/frcaspi.cfm for information.
I hope this helps. Please add more information about the configuration (cable, OS, etc) for extra ideas to solve the problem.
Sep 16, 2012 | Canon CanoScan FB320P Flatbed Scanner
Sir, i am learning embedded programming, i want to dump the program in the micro-controller through parallel port but there is no parallel port in my system. 1) if i buy usb to parallel port is it work as...
It would be better to use the USB to do this since Parallel ports are almost obsolete in today's computers. If you have an open expansion port you could put a parallel port card in the computer no problem but why would you want to? I would have to have a much better understanding of what you where trying to do to give you any other advice about Parallel vs USB vs FireWire. I have seen app's that use the serial port and parallel port as you are mentioning but these are tools for doing dead PC diagnostics and even most of those use the serial port because of the improves Bidirectional abilities for data flow.
Feb 20, 2011 | Intel DG31PR Motherboard
I have a toshiba sat 35x0360 it has usb port no parrell port. i can't print my dos program. help
Parallel ports have not been use in a very long time.
You can buy a usb to parallel adapter, just google or try amazon
Aug 21, 2010 | Toshiba Satellite A135-S2276 Notebook
Web cam
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 25, 2009 | Logitech Webcam
FUN!CAM stops working
Jan 24, 2009 | IC Intracom Manhattan FUN! CAM Webcam
Webcam problem
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Jan 11, 2009 | GE EasyCam Webcam
My Windows NX-3000 Web cam wont let my PC load
Normal 0 Did you connect the camera before installing the software program? If you did, disconnect the camera from the USB Port and reinstall the software program. When the program asks you to reconnect the printer, then plug the cable back into the USB port and it should function properly.
Hope this is of some help. Bud
Dec 26, 2008 | Microsoft LifeCam NX-3000 Personal Web...
GE MininCam Pro 98667
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Oct 22, 2008 | GE MiniCam Pro HO98656 Webcam
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Aug 03, 2008 | Computers & Internet
Logitech not working
Try reinstalling the software program.
Normal 0 Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Oct 02, 2007 | Logitech Webcam
Dell OptiPlex GX260 PC Desktop Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
