Question about Nikon D40x Digital Camera
Need fast shutter speed
I'm shooting basketball action shots and I'm needing a fast shutter speed on rapid fire. Everytime I try to crank up the shutter it tells me subject too dark even with the slave flash on. Is there any good settings I can plug in?
  • 33 Answers
First, the flash on your camera is completely useless for taking shots from the distance you are probably shooting at (>20 feet, right?).  So, just put the flash down and forget about it for now.  There are several ways of addressing your problem.
Your camera is trying to tell you that you don't have enough light.  This is true, since the faster the shutter speed, the less light is allowed to reach the sensor.  You can either increase the light reaching it or change the settings to allow it to make do with less.
The ways to increase the light that hits the sensor are:  Open the lens' aperture to a wider (lower f-stop) setting, turn the lights up in the place you are photographing, use a slow shutter speed.  I'm assuming you don't want the last one, you probably can't do the second and you have the lens as wide as it will go.  So the only real way for you to do that is to buy a faster lens.  Unfortunately, by buying the D40X you can't use the vast majority of Nikon lenses - only AFS lenses work on that camera because Nikon saved the $50 or so it cost to put the auto-focus motor in the camera.  This by the way is the reason you should never have bought this camera.  The choices for fast AFS lenses are few, and generally expensive.  (I use an 85mm f-1.8 which I got used for just over $100 quite often for this kind of thing, you can't do that.)
Okay, enough of this, on to the last way to solve your problem - changing the settings to allow your camera to make do with less light.  The ISO setting is essentially the gain of the sensor - like the volume knob on a radio.  While listening to music on your radio, if particular passage is soft, you can turn up the volume to make what comes out of the speakers reasonably loud.  The same can be done with your camera.  Find the ISO setting and change that from what it is (probably 200 or 400) to something higher - 800 as a start.  If you were set at 200, this is now a 4 times higher gain setting, so you can use a 4 times faster shutter speed, or shoot with 4 times less light, etc.
Of course, as with the volume knob on the radio there are two problems with this.  First, you have probably noticed that soft music with the volume cranked up results in "noise" in the background.  Same thing with your pictures.  Second, on that radio if you forget to turn the volume back down when the music level rises, then you will get all kinds of distortion from the "clipping" and the same will happen if you leave the ISO setting turned up when you go outside into the Sun.
In general, the ISO "noise" will look worse if you use a high saturation setting, so if you adjust the image saturation settings down, it will be MUCH less noticeable.  In fact, if you turn down as far as it will go, and then convert the images to B&W, you can probably use the 1600 ISO and have it look just fine.
Good luck.
Posted on Jan 27, 2008
  • 667 Answers
I would use 1/250 on either shutter priority 'S' or manual 'M' Set the f-stop to match your combined flash output. f4 to f5.6 should get you good results regardless of what the camera tells you. It has no way of knowing that you are using a slave strobe. Shoot some shots during a practice time and bracket the fstops to get an idea.
Action photos blurred using the zoom lens.
When shooting pictures, always check the length of the lens. Take the length in mm to decide how fast your shutter speed should be. When shooting 200 mm, the shutter speed should be at least 1/200 of a second. For a 400 mm it should be 1/400 of a second, and so on. With indoors sport, you need a lens with a huge aperture like 2,8 or better and a high ISO setting, to reach the speed needed for a long lens.
Modern lenses can have vibration reduction, and with these sometimes you can shoot 3 to 4 full stops sower.
A 200 mm lens with vibration reduction can be used then at 1/25 or even 1/15 of a second and still don't need to worry about motion blur.
Mar 07, 2015 | Cameras
What setting is for sports
That depends on the sport, the location, and what you want the pictures to say to the viewer. You won't necessarily shoot a daytime football game outdoors the same way as a basketball game indoors.
In general you're going to want a fast shutter speed to freeze the action. To get the fastest shutter speed possible, use the Aperture Priority mode by turning the mode dial to "A" then select the largest aperture by using cursor-up/down to get the smallest f/number.
Having said that, sometimes you might want a slower shutter speed to convey a sense of motion. Select Shutter Priority by turning the mode dial to "S" and use cursor-up/down to select the desired shutter speed.
Feb 03, 2014 | FUJIFILM FinePix S4000 / S4050 Digital...
I have a Nikon d200 and need to take sports photos in a basketball court The sport is very fast moving. What should I set the camera to. Lately the photos are dark and or blurry
You want the fastest shutter speed you can get and the largest aperture possible.
If you're close enough and it's allowed, use the flash. The flash will freeze the action. However, it's likely to give you a dark background instead of a blurry background.
If not, use the Aperture Priority mode. Open the lens to its maximum aperture (smallest f/number). This will give you the fastest shutter speed for the existing lighting conditions. The fast shutter speed will freeze the action and the large aperture will blur the background, though the amount of freezing may be limited if the lighting is relatively dark, as in a high school gym.
Be aware that if you're shooting indoors you're going up against the laws of physics. The human eye can adapt much better than any camera. A high school gym will appear light enough once you've been inside for a few minutes, but it is much, much darker than a bright day outdoors.
Apr 28, 2012 | Nikon D200 Digital Camera with 18-200mm...
Shoot at speed
The sports mode on a DSLR just picks high ISO and fast shutter speeds for you. Go Karts are very fast subject to focus on, so there are two techniques you can try.
One is to set your focus to manual mode and pre focus a point where the car will pass through. Set the camera to multi shot mode and just before the kart gets to the pre-determined point, hit the shutter button. The camera will fire off a few shots, then review later on a computer to chooset the best one out of the sequence.
Another way is set your focus mode for AI-Servo or Focus Tracking mode, this will enable the lens to track moving subjects (as single shot mode is way to slow to keep up with karts). Go to the slowest part of the track to get more sucess.
One problem you maybe having is that the shutter speed is too slow for karts. Being indoors the lighting will be very poor, so a super high ISO rating will need to be used to get faster shutter speeds. Having a lens with a very wide aperture (like f2 of f2.8 or even less) will enable you to get faster shutter speeds because they let in more light.
Good luck.
Jan 17, 2010 | Pentax K110D Digital Camera
Canon rebel xsi, using 75-300 lens, taking photos of basketball game, pictures are blurry, especially the ones in "action" using the sports mode. also tried my 18-55 IS lens, same thing happening, using...
That's a big lens and for sports photography you are going to need a lot of light to ensure you can use a fast shutter speed to capture the action. Sports mode may do too much for you and you might want to try switching to a more manual mode. Try switching to Tv mode which gives shutter speed priority. Set the shutter speed to something around 1/150 or higher (1/200) which should be fast enough to freeze the action. Make sure the ISO is set to 200 or 400 for best results and see how you get on. This should stop any action based blur which would leave you with focus problems if the pictures are still blurry. Check out for info on what this camera can really do for you
Jul 28, 2009 | Canon EOS Rebel XSi Digital Camera
Shutter Speed too slow on indoor sports for Nikon D60
Maybe. Assuming you can't add more light, you can either increase the ISO and/or open up the aperture. Try going to A (Aperture) mode and opening up the lens all the way. This will give you the fastest shutter speed possible under the conditions. That may or may not be fast enough.
Nov 02, 2008 | Nikon D40x Digital Camera
Wet olympus E-500
PLease take the camera to a service station before the whole things shutsdown due to liquid damage .... normally it does not show immediately but in the long run it will give probs...
Oct 12, 2008 | Olympus EVOLT E-500 Digital Camera
Action shots
Action shots generally require a fast shutter speed -- to freeze the motion. So you need plenty of light or a "fast" lens. A fast lens is one in which the aperture opens further to let in more of light. The smaller the number of the maximum aperture, the faster the lens, so a 28-105mm f/3.5-4.5 lens is "faster" than a 28-105mm f/4.0-5.6 lens. But usually, faster lenses cost more.
For the settings on the camera, the Rebel K2 has a Sports image mode (silhouette of a runner) on the control dial which should get you appropriate settings for most action shots.
If you want to set the shutter speed yourself use the Tv mode, and with a fixed shutter speed, the camera will set the correct aperture. Watch in the viewfinder -- if the aperture value is flashing, it means the shot will be underexposed. You will have to select a slower shutter speed.
Another way to get action shots with limited light or a "slower" lens is to use film with higher ISO/ASA. ISO 100 film is good for daylight shots, but for inside shots or evening shots, use ISO 400 film. Higher ISO film is "grainier", so enlargements will show less detail.
May 07, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Blurred motion photos
Sorry, I didn't get those pages. You can set the shutter speeds for the higher settings using the M or S mode on the camera. You can also adjust the ISO settings to increase the light sensitivity for proper exposure at the higher shutter speeds. I would shoot a few test shots before the action starts to see if any adjustments are required.
The built in flash on the camera won't be of much help in a large room like a gym. It only has a effective range of about 10 feet.
I laugh every time I see the flashes going off at a large sporting event with folks in the upper seats firing away....
Feb 11, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Nikon D40x Digital Camera Logo
264 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
