Question about Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control
Wiring- The ceilling has a black and it looks like a tan wire coming out the same place, The green wire is coming out and connected to a screw. The new fan has a blue white and and black coming out. What colors go together? Our model number is CA52. Other number on back of fan is 0013543. Can you help us? We bought a floor model and it didn't come with instructions. Thank You Laura
  • Proskpper Jan 29, 2008
  • 86 Answers
The fans blue and black wire can be connected to the black wire coming from the ceiling, white to white. The black line from the fan is controlling fan power and the blue is light. They are like that so you can wire the fan and light separate.
Posted on Jan 26, 2008
  • 1,554 Answers
The ceiling has Black and white (dirty I expect) ,
black is hot , white is neutral
the green is ground ( the fan will ground through the mounting screws)
so connect the black to black (hot)
as you have only one choice left that is the blue/white to white.
I assume you have a strong bracket and a fan was existing previously in this spot. If not you have to install a new fan support and wiring box.
Black wire, white wire, and tan wire coming from ceiling. New fan has blue, black, white wire and green wire on the bracket how does it hook up
1. Have on hand either wire connectors or electrical tape
2. Look at the wires coming from your ceiling fan. The black wire from the ceiling fan is the hot wire that runs the motor and turns the fan blades. The white wire is neutral and completes the fan circuit. The blue wire is the hot wire for the ceiling fan light fixture. The ceiling fan motor does not have a ground wire.
3. Find the short green wire or the green ground screw on your ceiling fan hanging bracket. Attach the bare copper wire from your electrical box to the short green wire by twisting and orange wire connector to the two wires. If you only have a green ground screw, wrap the bare copper wire around this screw and tighten the screw against the bracket to secure the wire.
4. Match the end of the white insulated wire from the ceiling fan to the end of the white wire from your electrical box. Twist a wire connector onto the two wires to complete the neutral circuit.
5. Connect the black insulated wire from the ceiling fan to the black insulated wire from the electrical box. If you do not have a separate toggle switch on the wall to operate the ceiling fan and light separately, grab the blue wire and place it with the black wire from the fan motor and the black insulated wire from the electrical box. Twist a wire connector to all three wires. If you have the additional toggle switch, connect the two black wires together with an orange wire connector, and then match the blue wire and the red wire together. Twist another orange wire connector on the red and blue wires
Nov 11, 2017 | Dryers
Ca't remove green ground screw on dryer
The green wire from the cord connects to the frame of the dryer. If you make some other connection, be sure it is to the frame, not some othe part.
Mar 23, 2014 | Frigidaire GLER331A Electric Dryer
I need to replace the cord and plug for a consew 105. Which wires go to what. New cord/plug has white black and green. The old plig had black and tan. Any help would be appreciated.
The new black will go to the old black, the new white will go to the old tan, the green will hook to the frame (case) or a screw there by the area where the new wires go into the case.
Sep 12, 2011 | Sewing Machines
I have a light switch with 3 wires that have to be hooked to it.3 black wires 3 white wires and 3 ground wires.The light switch has 1 place for the black 1 place for white and 1 place for ground.
You have 3 cables entering the box.
Each cable has black and white and ground wire.
You have a single pole switch.
The switch has 2 brass-colored screws and 1 green-colored screw.
1) One thing is certain: all the ground wires connect together and then connect to green screw on switch.
2) After that, we are guessing without more information.
Add a comment.
3) What does the switch control?
4) If the switch controls a hallway light, and there is another switch for the same light: then you have wrong switch. You need 3-way switch. Buy 3-way switch and re-post question at fixya.
5) If switch controls a bath fan-light combo, repost question at fixya.
6) If the switch controls a regular light, and no other switch is involved: then the following information might work. Or you need to do testing and re-post another question at fixya.
-White wires probably connect together and are covered with a wire nut.
-Then two black wires connect to one brass screw and 1 black wire connects to other brass screw.
-But which black wire?
-Only one of the black wires has power from circuit breaker. That is hot wire.
-Hot wire connects to 1st brass screw on switch. Either screw.
-And then connect one of the other black wires to 2nd brass screw. Turn on power and see if light turns on.
-Try other black wire same way.
-The black wire(s) that turn on lights on should be left connected to 2nd brass screw.
-If one black wire did not turn on lights, then that wire probably connects to 1st brass screw along with hot wire.
Aug 29, 2011 | Electrical Supplies
How to install the ceiling fan, asahi brand, i just want to know how to install my ceiling fan without any technechians help
If one switch works fan and light put the black wire and the blue wire together on the fan and connect to black wire coming from cieling and connect white wire from fan to white wire from ceilling
Jun 21, 2011 | Heating & Cooling
Changing pig tail from three prong to 4 prong on maytag dryer where do i put the red black white and green wires on the pig tail connection on the dryer
the red black and white wire go in the same place as the other wires and the green wire gets screwed to the green ground screw.
the white wire goes in the middle red to the left and black to the right.or just look att he wires and match them
Mar 09, 2010 | Dryers
Wire Hayward Super Pump for 115
If you look closely, you should see a small arrow on the black plastic piece on the terminal block(jumper). That arrow lines up with either the 115 or 230 mark on the white terminal board. Make sure it is aligned with the 115.
Then put you two line wires on. It does not matter which wire goes to line 1 and line 2, just be sure you DO NOT put them both on the same terminal. A plastic divider usually seperates the two line connection terminals.
Jun 13, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
Replace electric cord
First,follow manufacturers instructions if possible.
If you need a 4-wire cord you will attach the black wire to one of the gold or brass colored screws on the dryer hookup and the red wire to the other brass or gold screw. The white wire will connect to the silver screw and the green wire will connect to the green screw or to a screw that is connected to the frame of the dryer.
If you need a 3 wire cord you will place the two outside wires (if looking at the cord if laying flat), one on each brass or gold screw.Next there should be a metal strip or jumper that you will place to connect the green screw connected to the frame of the dryer and the silver or white screw together. Then place the white, or center wire, on the silver or white screw.
Instructions that came with the dryer should show you how to do this.
Make sure the cord is unplugged before unhooking the hold cord or installing the new one.
If you see something different that what i describe or need anything else just write.
Apr 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
The tan is probably a worn white, age will turn it that color. Since you don't have separate switches for the light and fan, then the black (hot for fan) and blue (hot for light kit) go twisted together and hooked to the black from the box in ceiling with a wire nut. The white goes to the other white, it's the neutral wire in the schematic, which if you took apart your breaker box, is attached to the grounding clamp. There should be a green wire that will attach to the extension pole right at the ball on a ball and socket mounting or the motor casing on a flush mount. This should be attached to the green or bare wire coming out of ceiling box. Hope this helps.
Jan 26, 2008 | Hampton Bay 52 In. Cameron II Plus Ceiling...
Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control Logo
190 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
