Question about Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine
Bobbin tension My almost new machine was sewing fine when I broke a needle, on a pin, I think. I replaced with a similar needle, made no other changes, but when I began sewing again, the top stitching was fine but the bottom (bobbin) side was a mess. I was using the stretch stitch, so I changed to a straight and with the same tension, top looked good but there was no tension on the bobbin. I tried increasing and decreasing without any good result. I rethreaded, filled a new bobbin, put that in and out of the holder and my bobbin stitching still is awful. I can't see any way to change bobbin tension--and when would I have changed it? It was sewing fine before. Also, my new needle has the flat side to the back and is up as far as it will go. I am at my wit's end.
  • meader3 Jan 29, 2008
    I had my top tension at 6. I raised and lowered it and the bobbin sewing was different but not better.
  • meader3 Feb 08, 2008
    I adjusted the tension on top and sewed for a while and the bobbin sewing smoothed out. As I kept working, the thread kept breaking so I eased back on the tension. But it still kept breaking. When I got back to #4, the bobbin was messed up again. So I took the needle out, reinserted, rethreaded, etc. I pushed the tension up again and it is working okay now. A friend told me to possibly replace the needle, that often they are "too sharp", even when they are new. So I'll work with it for a while as it is. Then replace if necessary. The machine seems to have a mind of its own. Don't think I'd ever get another Kenmore.
  • Kenmore Master
  • 1,388 Answers
If the looping is happening on the underside, it is your top tension that is to blame, conversely looping on top is bobbin tension.........take a look HERE for detail on cleaning lint buildup.
Top tension should be set around the middle of the range, usually 4 - 6.
I would not advise playing with bobbin tensions, however, you can take the needle plate off to clean the hook race area (where bobbin case sits) ...this is good housekeeping, my wife does this every time she replaces the bobbin....just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint, if there appears to be fine dirty deposits, a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit will do the trick.
Bargainbox
Posted on Jan 27, 2008
  • Hassy
    Hassy Jan 29, 2008
    OK, it seems likely that you will need to adjust the bobbin case.......first check there is no lint trapped in the metal spring where the thread is tensioned. Drop-in Bobbin case will look similar to this image and the tension screw is in the middle of the metalwork...
    ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
    When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance....test and adjust the bobbin tension screw very little at a time, perhaps 1/16 of a turn.
    Try using good quality thread of contrasting colours so you can more easily spot the changes.
    You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is, and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or small hands at work)
    Bargain Box
Thanks for the above solution(Jan 27th). My bobbin tension was a mess and I simply took your advice and adjusted the top tension and now it's perfect.
Posted on Feb 20, 2008
Brand new machine, do I need to oil it? singer talent 3321 is suppose to be EASY...needle broke, now it will not sew, seems to be stuck and bobbin seems to not work.
1. You need to remove the bobbin case and adjust the tension. The tension should allow the thread to move with a slight tension. Clean the area with a qtip. The bobbin case sits in a an area that is called the race. The race needs one drop of oil. Replace everything.
2. Replace the needle. Make sure it is in the right direction. Thread the top while the foot is up. If the thread gets stuck while threading there is a problem. The thread should move easily while the foot is up. After you thread the machine except the needle you can put the foot down. Now pull on the thread. It should give you a slight amount of tension. Usually four is a good number. If the tension is too tight you can adjust as needed. Now, thread the needle. Hold the thread under the foot while you turn the hand wheel. The bobbin thread should come up.
3. Give your machine a try with a slow speed.
Mar 25, 2017 | Singer Sewing Machines
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
Singer 7430, Needle hits the bottom of the bobbin case.
when the needle breaks on a pin that can cause a
problem with the timing, the machine needs to be serviced
Dec 11, 2012 | Singer 7430 Sewing Machine
I was sewing just fine then the needle broke ... I replaced it only to find that the next needle broke too. It seems that the needle just hits the rotating metal below the bobbin each time it goes...
First make sure there are not bits of needle left in the needle holder, or down in the bobbin area. Take out the bobbin, take the bobbin carrier out. Take off the foot. You need to see.
Look carefully at the shuttle while rotating the hand wheel in the direction of sewing until the needle is at it's lowest position. Where is the shuttle's Point? (past the needle? or way behind the needle?)
I think your machine is out of time. You may need to take it in for timing.
Nov 10, 2012 | Sewing Machines
My kenmore is about 30yrs old .Never had a problem till now. I was sewing and stitched over a pin, broke needle,replaced needle. Now the problem is that the top thread bunches up underneath,also after i...
Sounds like the timing adjustment of the bobbin case has been upset. Have that checked, it involves an adjustment on the gear that drives the bobbin case.
Feb 22, 2011 | Kenmore Sewing Machines
Sewing machine won't raise the bobbin thread
Hi. The two main reasons why the top thread doesn't pick up the bobbin thread is either the needle is inserted wrong or the needle is bent. Since your machine was sewing properly until the thread broke, I'd be inclined to think the needle may have gotten bent. Sometimes this can happen if you sew over a pin.
Change the needle (making sure the flat side of the needle shank is inserted properly for your machine) and see if that solves the problem. Let me know if it helps, ok?
Robbie
Jun 07, 2010 | Singer Sewing Machines
Thread keeps breaking
Have you checked any edge the thread might contact for knicks which should be files or sanded down? Also, I had to replace my bobbin case after a number of years as it had kind of stretched out and allowed my bobbin to pop around and consequently broke many threads.
Feb 07, 2010 | Janome Memory Craft 9000 Computerized...
Problems with lower thread tension
Did you bend the throat plate? I have done that and it was a nightmare. I took it off and gently hit it from the backside with a towel over it to bend it back the way it was. It worked fine.
Jun 15, 2009 | Husqvarna Viking 1
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
3,056 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
