Question about GE Advantium 120 Convection/Microwave Oven
Advantium 120 Keeps running
Anyone ever have a problem with this microwave?  When you close the door,  the interior light stays on, the cooling fan operates and the turntable continues to turn.  All this when the microwave is not being used.  All you can do is disconnect the plug to turn it off. The microwave is not functioning at this point.   This has happened twice so far and they just replaced some boards the first time and the second is still being worked on.  Please advise if you ever got the problem fixed permanently.  thanks
Linda
  • 4 more comments
  • Bryan2244 Feb 10, 2008
    Light blew out and now fan runs and turntable turns while plugged. Any Fix?
  • abivac Apr 11, 2008
    I also have the GE Advantium 120 with the "keeps running problem". Does anyone know how to replace the relay and where to get a replacement? I have to unplug it every night and I have to reset the clock everytime I use it the for the first time the next day. I don't want to keep it plugged in because the interior light really gets hot.
  • thursdaymoon Apr 21, 2008
    Same thing here. Used it one day, closed the microwave door, and the thing started up again with lights, fan, turntable, etc. We have to leave the door open to keep it from running.
  • thursdaymoon Apr 24, 2008
    Called GE, they said to have it repaired. Repair man asked if both prongs on door were intact, mine are; he said he needed to order the part. Not sure what part; when I find out I'll update. Cost of repair: $250, that includes part, labor, and service call fee.
    We continued using microwave, just leaving door open when not in use. (ie: did not unplug and just wait for repair) Last night, microwave stopped having the "always on unless opened" problem!! Working fine now!! NO repair done yet.
  • Anonymous May 02, 2008
    Light Stays on some of the time. Oven is less than 3 months old.
  • abivac May 11, 2010
    Does anyone know if this relay is available? Or is job for professionals only?
How do I replace the door latch assembly inside the door. Its a small 5 inch part with hooks on each end and includes a spring? It's not very obvious how to remove the plastic door panels that cober the latch.
Posted on Apr 19, 2008
    Problem Solver:
  • 4 Answers
I've got this problem also.
The interior light on the oven died. We replaced it. Since replacing it the light stays on and the turn table turns.
Looking at the diagram, the "main relay" is what powers both. My guess is that it's stuck in the "on" position. Solution will be replace the relay.
Long term fix may be bigger relay.
Posted on Jan 27, 2008
6ya staff
SOURCE:
Interior light stays on
Need a bit more information here. Does it still cook when told to do so? If not, you may have a problem with the door close switch. Perhaps it is as simple as using a screwdriver to finesce the actuator back into position. The inside edge of the door has a metal latch and often times a slightly shorter pin or tab that actuates the door open switch. This not only enables the light in the microwave to turn on when the door is open it also tells the cooking circuits to disable until the door is properly closed. If the switch itself is bad you'll have to take the microwave apart to get it out. RepairClinic.com has a huge assortment of parts that are easy to search and find.
Feb 28, 2015 | GE Advantium 120 Convection/Microwave Oven
Advantium 120 interior light won't go out
door switch is bad or out of adjustment I have a dometic that does this sometimes I just slam it a little harder
Jan 29, 2014 | GE Advantium 120 Convection/Microwave Oven
Fan runs when door is closed and no time set.
Some GE units were starting on their own. I would definitely unplug this oven and call GE to make sure yours wasn't one of the ones being re-called.
Feb 14, 2013 | GE Advantium 120 Convection/Microwave Oven
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Interior light always on Ge advantium 120
I bet by now your microwave is no longer working....did the bottom or top "hook" finally break off? I found that mine had cracked and started coming loose and so when it closed it was no placing enough pressure on the internal safety switch that tells the oven the door is shut. I was able to use a sturdy plastic glue to solve the problem but finally after about 2 years of fixing it I can no longer get it to bond. Now, I'm looking for a new part. Who makes a product this expensive with plastic parts!!?!??!?!? So frustrating.
Apr 13, 2009 | GE Advantium 120 Convection/Microwave Oven
Advantium 120 fan and tray keep running
Looking at the service manual here, I'd bet that relay number RY6 is shorted on the "sub PC" relay circuit board, or its driver transistor on the main "smart" board is shorted.
Unless your technician does component-level repair, he'll probably want to just sell you a new sub board, or main ("smart") board, or both.
They list for $64.78 and $109.83 respectively here. Hard to tell what they'll mark them up to.
Then add about $150-200 for the labor.
On the other hand, we regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
Or you can tell your technician about our services.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Jan 07, 2009 | GE Advantium 120 Convection/Microwave Oven
Kenmore Elite Advantum 120 Model # 363-63694302 INTERIOR Light not working
I would suggest you look over this excellent tutorial.
If this is not close enough to your oven to help, please reply back.
Oct 05, 2008 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
671 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
William Miller
William Miller
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
