Question about Alpine CDA-7998 CD Player
Nothin will work
I hooked the unit to my car and nothing at all happens, I'm getting power to the unit and all the fuses are good, the face will not even come out. no power
  • Anonymous Apr 26, 2008
    try hooking the red wire and the yellow wire at the same time it should work
This unit is a "dead head" which means that their are no amplifiers to drive speakers inside of this unit. you need an amplifier to drive the speakers.
Hope that helps...
Posted on Jul 26, 2008
If you've got 12v constant on the yellow, 12v switched on the red, and chassis ground to black, your fuses are good the radio is powered properly.
When you plug the harness into the back of the radio you should hear the CD transport cycle. That's telling you the radio's getting power. Hit the reset button (pin-hole switch on front panel) and hold the small square open/close button for 2-3 seconds.
If still nothing, the radio needs service. I'd send that model to Alpine in CA for repair.
Posted on Feb 06, 2008
I have a pioneer avic-n3(cpn213 and I dident have it in a car for a little while and when I went to put it back in it wouldent power up everthing was hooked up right with the red,yellow,and black and I get...
is the fuse in the back of the unit good? replace if blown. if not, get a continuity tester from local stereo shop or retail store (target/walmart/etc) for around 10 bucks. one lead goes on a good ground and the other lead to the red or yellow wire to check for power.
Jul 24, 2011 | Car Audio & Video
JVC KD -S680 needs help
maybe short circuit or similiar problem inside since its geting hot, probably not a problem with the faceplate I would remove the cd player from your car and take it to a professional for a diagnosis / repair estimate. Can't solve this one with text only.
Jun 18, 2008 | JVC KD-S680 CD Player
Im hooking a cd player into my 93 toyota pickup ive got the ground and the power hooked up but nothings happening what the deal
A fuse may be blown inside the unit. Before you install it, check its' operation with an external power source (12 Volts DC) to make sure it works first. If it doesn't power-up, check the fuse inside.
Nov 02, 2010 | Pioneer DEH-15 CD Player
Basically my rear speakers wont work i put new ons in but still nothin. FUSE? WIRE?
You answwered your own questions. Easy to check fuse on amp, just pull it out. Replace it with EXACTLY the same type of fuse you took out. Make sure you have the fader adjusted to the rear, check wiring at head unit, make sure connectionc are good and are for the speaker you are hooking up. (not getting R/L wires mixed up)
Apr 02, 2010 | Rockford Fosgate Car Audio & Video
Just bought cobra 19 dx and wont even turn on
if you hooked it up backwards first, you blew the protection diodes in the radio. they need to be replaces.
You need to unsolder the old one and put in a new one.
You need to make sure you don't hook it up backwards ever.
Check fuse too!
Open the bottom cover, watch the wires from the speaker as not to pull them out.
Look towards the back right of the radio for a black diode that is burned up. If you have 1 that is burnt, then go to radio shack and get a diode 1n4007. then replace it with that.
And, be careful next time you hook it up.
Jun 12, 2009 | Cobra 19 DX IV CB Radio
Clarion M5675 won't turn on
Take the stereo all the way out and hook the black wire to the negative terminal and the yellow and the red wire to the positive terminal on a charged car battey. If it still does not turn on you may have fuse in the back of the deck. If not it's probably fried.
Apr 19, 2009 | Clarion M5675-RET CD Player
Kenwood KDC-MP438U acts as if there is no power to it,dead nothin
The speaker wires are very sensitive. You need to make sure that they are not grounding out. Once the unit senses this it will shut off. Pull the plug out of the back and start over.
Dec 30, 2008 | Kenwood KDC-MP438U Car CD/ MP3 Player
Not working
maybe you should use 4 awg wire
Jun 24, 2008 | Rockford Fosgate Punch P5002 Car Audio...
My dryers not working
If one of the lines is lost (230v circuits have to hot lines) the light only works on 1 line check your connections. There is also a thermal fuse that shuts the machine down when its overheating. If there is 230v at terminal block. The fuse is what i check next, well doorswitch too make sure the switch isnt broken (upper right of door). PLEASE RATE MY HELP
Oct 02, 2007 | Dryers
Face plate wont move
First check the power fuse as well as the stanby or always on fuse. then if that does not work Try to disconnect the power and standby line and let the unit reset . This should be done for at least an hour or so.. Good Luck
Jul 25, 2006 | Kenwood KDC-7009
Alpine CDA-7998 CD Player Logo
141 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
