Question about Kenmore 22422 Top Load Washer
Maytag Performa Washer spins fine but stops instantly
My washer fills, agitates, spins, etc just fine, but when the spin cycle is over it comes to s sudden stop. It does not slow down, just screaches to an instant halt. Any help?
  • 770 Answers
Check the unit next time it is in the spin open the lid up does it do the same thing?? if so it is working ok that is the Brake in the unit doing it Job but if it is really loud it maybe going out??
Posted on Jan 27, 2008
Maytag performa stops during agitate or spin
All washers have a safety switch on the on lid. There is usually a slot that a plastic pin goes into to activate the switch. These switches are high failure parts. The switch is located on the underside of the top deck. It should check 0 ohms when closed. You can also jump it but then it would NOT stop when the lid is open ie; during agitation or spin cycle ( a safety hazard).
Sep 01, 2012 | Maytag Washing Machines
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Jul 27, 2009 | Maytag Performa PAV3200
"jackhammer" sound coming from my washer
# Balance the load
# Level the machine
# Inspect the water pump for a blockage
# Inspect the coupling
# Inspect the transmission
# Adjust the drive belt tension
# Check the motor bearings
# Check the drum brakes
Jan 09, 2009 | Washing Machines
Maytag washer not agitating and not spinning fully
Pr obably a coupling between the motor and gear box, Take motor off and coupling will come out, re place it and it should be fine
Dec 03, 2008 | Maytag MAV4755 Top Load Washer
Agitation issues. Everything else appears/works normally.
I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
Jul 03, 2008 | Maytag Performa PAV2200
Does not spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Sep 24, 2007 | Maytag PAV2300 Top Load Washer
Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Aug 15, 2007 | Maytag Performa PAV2200
Kenmore 22422 Top Load Washer Logo
71 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
