Question about Singer 2732 Mechanical Sewing Machine
The bobbin thread on sewing machine will not catch
I was hemming pants and the bobin got snagged, cleaned it up and now the thread from needle will not catch on bobbin.
My needle broke when hitting a straight pin. I changed the needle and the top thread will not catch the bobbin thread. It's not being caught by the wheel. I tried another needle with the same problem. I just boght this new sewing machine yesterday!
  • TPost Apr 06, 2008
    I have the same problem!! I don't remember breaking a needle or doing any kind of damage to the machine, it just stopped catching the bobbin thread and birdnesting like crazy! I'm taking it in tomorrow.
  • Singer Master
  • 11,493 Answers
Most likely the machine has been knocked out of time when the needle struck. Take it for service.
Posted on Sep 07, 2017
  • 1,001 Answers
Get in touch with the store!
  • 29 Answers
SOURCE: a horrible tangle
This is a bit late, could the bobbin case not be seated properly? You need to put it into place and then turn it clockwise until it seats soundly in the opening. Also, check for burrs...the needle may have left a rough mark on the plastic or metal in the bobbin area. A piece of batting, or even an old knee hi should snag on any rough areas.
Posted on Jul 14, 2007
SOURCE: the bobbin thread on sewing machine will not catch
how do you retime
Posted on Aug 13, 2008
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
Posted on Aug 16, 2009
  • 15 Answers
SOURCE: bobbin thread won't catch with needle thread
check that the needle is in the right way round i.e. with cut out on the needle facing into the machine. if this is fine then check that as the needle comes back up from the lowest point that it goes to, that the point on the bobbin case passes just above the hole in the needle, i.e. in the middle of the cut out.(if not it needs re timing) if threaded a small loop should appear at this point for the bottom bobbin to catch if not slacken the top thread and try again.
Posted on Sep 07, 2009
  • 255 Answers
SOURCE: Singer 4623 bobbin thread won't catch
Hi! Did you by chance, change your needle? If so, make sure you have the flat side of the needle shaft facing the correct direction. If the needle isn't in all the way or the flat side of the shaft facing the right way, the bobbin thread won't pick up.
Let me know if this helps, ok?
Happy Sewing!
Posted on Feb 10, 2010
Why does bobbin thread keep snagging?
increase the needle thread tension up a bit as it is too loose to pull the bobbin thread up properly
keep adjusting until both threads are at the middle of the materials being sewn
Mar 25, 2016 | White Sewing 1418 Mechanical Sewing...
Needle wont catch bobbin thread. Think timing is out.
First change your needle... it's probably bent and make sure you are using a needle FOR Denim in a size 18. Hand run the machine... if you still feel it hitting something... it is out of time. Take it in for repair.
Oct 05, 2012 | Singer 8763 Curvy
I broke a needle while sweng,now my needle hits my bobbin case on my 2030
it's very possible that when you broke the needle it caused the machine to go out of time & would have to be retimed at a sewing machine repair shop
Mar 12, 2012 | PfaFF Tiptronic 2030
My needle thread keeps breaking. I've tried different thread (top and bobbin), a new needle, and I opened up the bottom plate to clean out lint. I have also tried adjusting the thread tension.
Are you sure you have got the top thread threaded correctly including the take up lever? Start at the thread spool and follow the thread all the way through the thread path checking that it is not snagging on anything enroute and that the thread is correctly through the tension device. Also tension dial should be on 4-5, if its higher this could be breaking the thread. YOu should not need to adjust top thread tension more than a half increment at any time.
Other possibility is that the bobbin holder under the needle plate has moved out of alignment and then the top thread is catching there as it goes around the hook.
If you check your manual it should give you instructions on removing the needle plate (2 screws need to come out), then you can lift the bobbin case out towards you, clean underneath with your little brush, then reinsert it. There are two little red marks on the right side of the bobbin case and a stopper, these need to be lined up. Then put in bobbin and rethread into tension spring, replace needle plate, bobbin cover, and test stitch.
Hopefully one of the above is causing the thread to break.
Aug 02, 2011 | Janome Memorycraft 6500P Computerized...
The bobbine thread is not catching and I'm trying to fix it and I am not sure were to start.
start by removing the bobbin, and reinstalling, make sure the thread runs through the bobin tension plate, the little plate that puts pressure on bobbin thread to keep it tight, also look at thread and needle, if thread insn't thread through the needle, it won't catch, feelfree to call me if you need better help, devin 239-895-4845, Quality Auto Trim Inc 239-849-0015
Mar 12, 2010 | Sewing Machines
Top thread wont catch bobin thread
Try cleaning out the bobbin casing. I had this prob earlier today and there was thread trapped that I got out with tweezers and loads of lint and dirt (it's a second-hand one someone gave me that I haven't used much).
Be careful though as I seem to have knocked the timing out cos the needle is hitting metal now!! Any ideas?
Mar 09, 2010 | Singer 2732 Mechanical Sewing Machine
You do need an oiling and cleaning. Also, try adjusting on the bobbin cover by turning th little screw with a small screwdriver. Keep adjusting and testing until you get the loops just as you want them...
Aug 05, 2009 | Sewing Machines
Not catching stitches / bobbin correctly
When you broke the needle I think you have moved the shaft that brings the needle down ,you can adjust it !
Oct 05, 2008 | Bernina Bernette Deco 600
Singer 2732 Mechanical Sewing Machine Logo
278 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
