Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Washer Washer will fill but will not spin. Buzz on spin setting sounds like motor or switch malfunction. Belt is fine.
  • Anonymous Jan 27, 2008
    Washer will fill but will not spin. Buzz on spin. Belt is fine. Spin cycle will start if you rotate the main gear that turns the tub at the bottom of washer.
    Washer will fill but will not spin. Buzz on spin. Belt is fine. Spin cycle will start when I rotate the main gear that moves the tub underneath the washer.
  • 96 Answers
Buzzing sound may be weak motor windings not getting enough power without extra help.
Posted on Feb 26, 2008
  • 770 Answers
Sound like you have something stuck in the pump check the hose going into from the tub
Posted on Jan 27, 2008
Washer buzzes and won't agitate or spin. Only will fill with water.
Almost certainly with that sound, the motor start capacitor has failed. It will be located either behind the control panel, or underneath next to the motor.
Dec 17, 2013 | Maytag Parts Washing Machines
LSE7806A Top Load
The belt is still attached to the transmission right?? It sounds like the brakes may be stuck. Or are both belts off and the motor still trips out?
Dec 05, 2007 | Maytag LSE7806A Top Load Stacked...
Washer makes grinding/loud sound and will not agitate-spins fine
Look under the washer. Is there a little pile of black rubber shavings? This sounds like the basket coupler between the motor and the drum. If the coupler is the problem it is inexpensive to fix. Some also call this part the "clutch". It kind of looks like a hockey puck with six holes in it... three for the motor, three for the clothes drum. In your case, I suspect that the holes are intact in the direction of spin, but as soon as it reverses for agitation, it breaks out through the back of the holes.
Jul 09, 2017 | Maytag Atlantis MAV6260AWW Top Load Washer
Hi, I have a Maytag Alantis Washer (model: MAV
Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
Regards,Richard
Nov 07, 2011 | Maytag Washing Machines
My portable top load kenmore washer model 110.42722200 won't spin. It drains water and all the light functions work, but it only makes a humming sound like it is stuck when it gets to a spin cycle and does...
I just repaired this exact model this weekend. If the machine will drain but doesn't agitate or spin (you have to put a screwdriver in the lid switch to see), it's usually a loose belt. This time I replaced the belt, but it still would not agitate or spin, and the motor was not turning, just a "buzz, buzz, buzz" when the washer attempted to supply power to the motor. The start capacitor for the motor was bad. Part number 3429938 which runs about $60. Not hard to access once you tip the washer over slightly, just DISCHARGE THE OLD CAPACITOR so you don't get a nasty shock.
Aug 05, 2010 | Washing Machines
Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Matag Atlantis MAVT634 will not agitate
Does the motor start and run for agitation with the belt connected?
Jan 29, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Agitater does not spin
the transmission needs to be replaced
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer fills up, motor hums, but no spin.
sounds like the drive belt is broken these models have pump belt and a drive belt
Oct 16, 2008 | Maytag LAT2300 Top Load Washer
Does not agitate or spin - fills and drains - checked belt & pulleys seems fine
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
155 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
