Question about Technics SA-AX540 Receiver
Can't hear any sound from the large left or right speakers
I recently moved and upon reconnecting my Technics stereo, I can't hear any sound from either the left or right speakers. What could be causing this? I tried new speaker wire but still no sound.
Tape monitor switched in??
Posted on May 28, 2008
  • 1,067 Answers
Is sterio in a ch ? not b or is it in b and not a when u hooked it back up
Posted on Jan 26, 2008
Why is my centre speaker not working on my stereo setting on phono?
Records are binaural only. There are only two channels of information, left and right. There is no signal available for a center channel.
Aug 29, 2014 | Technics SA-AX730 Receiver
Poor sound quality from a technics SL-D210
Generally either a faulty connection to a lead or cartridge. Or a faulty Cartridge. If you switch the left and right channels of the phono leads the missing sound should move to the left and the right come to life. If it does not then there's a fault in the magnetic cartridge pre-amp in your amp.
Mar 29, 2013 | Technics Audio Players & Recorders
I have 2 technic sl1200s and the right table has noise coming out of the speaker when i moved the tonearm. when music plays, it sounds like the treble and volume of the right speaker is weaker help...
If your left technics sounds good, maybe the problem is the cartridge. Try to interchange the cartridges, right table cartridge by the left one, and listen. If now the bad sound comes from the left table, it´s time to get a new cartridge or stylus. If the problem continues there is something else to look for. Hope this will help. Flavio/Brazil.
Sep 17, 2010 | Technics SL-1210 Turntable
One of my DJ turntables = only left side stereo sound
need to narrow it down, using 1 turn table ONLY with the mixer on channel 1 (the chanel that is working) to test reciever is working properly and sound working on both side of the speakers, this eliminate the first turn table. Next, disconnect the working turn table (1) and connect your second turn table to the same chanel and see if you getting the sound coming chanel 1 just as your first turn table did. If you getting sound coming out from turn table on ch1 than is not the turn table issue. It will be you mixer having problems. You cant solve the problems having everything connected. Testing one turn table at a time using working chanel on the mixer to see if both turn table working properly. If you use the same chanel testing both turn table and the second one does not work than it will be one of your turn table is faulty. Note: if you find and test both of your turn table is working properly than it will be your mixer. good luck and hope that help..
Aug 06, 2009 | Technics SL-1200MK2 Turntable
I don't now what settings to use on my technics stereo system it has 5.1 surround sound. My prob is I don't now what levals to set the speakers at for best results in the book it says I should hear bullets...
switch off pro logic/switch on supper suround/press button twice it will say MOVE:/
switch on Supper suround EQ then Vertual Rear suround then Multi Rear suround then Seat Position.they should be lit GREEN exsept Vertual Rear & center focus.
Seat Position should flash when it does move the curser in the middle of the jog dial.......... i.e UP:DOWN :LEFT :RIGHT .let go & it will set itself. then switch on the Supper s woofer on the amp to MID.
Jun 10, 2009 | Technics SC-DV290 System
Only hearing sound out of left side of headphones
i think the problem is in the jack of your sound blaster. since you have already tried different headphones and the problem still persist, and when you use speakers it works fine. i conclude it is the jack of your sound blaster card.
Dec 22, 2008 | Creative Labs Sound Blaster Live! 5.1...
Technics SUV500 Amplifier
check volume balance between right and left-then change inter connection between sound source and amplifier with new cabel(i prefer gold plated type connectors)(see radio shack).
after that if the problem excit your fault in output transistors or output stereo ic depend on circuit design.
Feb 17, 2008 | Technics SUV500 2-Channel Amplifier
No speaker sound
check the 2 buttons under the source selector knob they are labeled A and B check to make sure both are not pressed in just the one you have your front speakers hooked up to
Sep 10, 2007 | JVC RX-770V Receiver
Technics SA-AX720
Look for lossing solders points or bad conections. Start to look on those components of hi wattage and components to get hot alot, those are the most common to have weak solders spots.
Also some equipment need to be clean because the dust can make problems.
good luk.
May 21, 2007 | Technics SA-AX720 Receiver
Technics SA-AX540 Receiver Logo
181 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
