Question about Acer Aspire T120 PC Desktop
Audio at the moment my PC have no audio cannot listen videos, cd, radio etc
  • adam parker May 11, 2010
    do you have any speakers
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
I have the same computer and when I baught it I just when to the acer web page and clicked download and then typed the model name and number(Acer T120) and then a page will come of all the softwares needed for the computer... I got Realtek Sound manager.....
Posted on Jan 27, 2008
    Problem Solver:
  • 3 Answers
You may not have the driver installed for the audio, if you dont, you can get them here.....
http://support.acer-euro.com/drivers/desktop/aspire_t120.html
Posted on Jan 26, 2008
Why is the screen not coming on my Clarion vz401 Clarion but I have sound and everything else works
If you have a blank screen while listening to an audio source (Radio, CD, USB, etc.) the interconnecting ribbon cable that goes from the system board to the display module could be damaged/cracked and needs to be replaced.
Mar 24, 2016 | Clarion Car Audio & Video
Soundlogic XT 5 in 1 wireless headphones will not receive audio from tv; only gets radio stations.
Did you connect the base/transmitter piece to the AUDIO OUT jacks on the back of the TV ? The radio you are listening to is the built-in FM radio/tuner. You need to connect the transmitter to an audio source (TV, PC, CD/DVD player, etc.) to receive sound from that source.
Jan 04, 2015 | Audio Players & Recorders
How many wires do you need to install rodio in truck ?
Let's see.. (1) Power (switched with ignition), (1) Power (always on to hold memory & time), (8) Speaker (2 wires per speaker), Antenna (coaxial cable). Now, the two power can be always on, but you'll have to remember to shut the radio off before you get out. You could have the radio power from a switched power source, but the clock will be wrong and all the station presets will be wiped outwhen the truck is shut off (no biggie if you're only going to listen to the CD player). You could get away with 4 speaker wires - one pair for the left speaker and one pair for the right speaker. The antenna is a must - unless you're planning on listening only to the CD player.
The rest, are optional. The power output lead is handy to turn on any external amplifier or to raise and lower a power antenna. If using an amp, you might want to use phono cables to send line level audio signals to it instead of using the speaker wires to do that - maybe use the speaker wires to drive dashboard speakers directly and use the amp to drive rear or door speakers.
In any case, I'd recommend purchasing a vehicle specific wiring harness. This will allow you to simply unplug your factory radio from the vehicle wiring. After you wire the new harness to the aftermarket radio, simply plug it into the vehicle wiring as if it were a factory radio. Easy as pie. Not cutting connectors off, crossing wires, etc. Plus, you get to plug your factory radio back in when it's time to sell - and move the aftermarket radio to your new car (after you buy the harness to connect it to the new car anyway). Some vehicles have a data bus that makes the radio an important part of the electronics for sending door chimes, key in ignition signals, etc., and require some pricey harnesses - but they are worth it in the long run. Please take a moment and rate this reply - thanks.
I hope this helps - good luck!
Dec 13, 2010 | Pioneer DEH-P6500 CD Player
Yamaha rx-v1600. I am failing in my attempt to get sund out of zone 2 speakers. I have the 2nd zone speakers hooked into surround zone 2/3. In primary zone I only have center and surround back as my fronts...
After 6.5 hours, I am now listening to music outside on my patio using my rxv-1600!
Connect your speakers to the Presence Zone 2(3) output on back. Then power up amp and select zone 2 on front of amp. Nothing will happen, because as I found out, you must route an input to zone 2 or 3. Which is cool, because you can listen to something outside that is different from your inside.
You select what to route to the zone by pressing Zone Control button, just right of zone 2 and 3 button. While you see red zone light blinking, rotate input select knob to prefered input, i.e. radio/cd/aux/etc... also, you can adjust volume by pressing zone control and turning up the volume knob, only while ZONE light is blinking.
hope that helps, i know i was frustrated figuring that out!
Nov 25, 2010 | Yamaha RX-V1600 Receiver
Hi, I'm about 40 miles NW of Chicago and reception here is not great. I like to listen to AM radio. I usually use my speakers just to listen to CD's, but I decided to try my Acoustic Research receivers...
First make certain the CD player isn't on when the radio is on. CD players cause inteferance with radio's. Apart from that you will need a good aerial. If that doesn't improve it then it could be down to local conditions -hills, power lines etc, blocking the signal. Also check there's nothing around the house that might cause interferance to the signal.
Jul 14, 2010 | Audio Players & Recorders
What is the video format of the player?how many songs can i store in it?
Slim and stylish, the NWZ-S616F Walkman Video MP3 player combines a powerful digital music player with a 1.8" QVGA LCD screen for hours of multimedia entertainment. Listen to your favorite songs, view videos and photographs or listen to your favorite radio stations with the built-in FM tuner. It supports playback of MP3 and WMA DRM and non-DRM audio files downloaded from multiple sources, as well as AAC non-DRM content, so that you can enjoy your music no matter the format or download source. Weighing less than 2 ounces but with the capacity to store up to 2,300 songs, 15 hours of video or hundreds of photographs, the 4GB NWZ-S616FRED Walkman Video MP3 player delivers everything you need to take your favorite entertainment with you. Compatible with Secure Windows Media Audio MP3/WMA/AAC Audio Codec Support Utilizes 3 Clear Audio technologies to reproduce crystal clear, CD-quality audio. FM Tuner with 30 Station Presets Shuffle play among songs from a randomly selected year. Bi-directional screen display
Nov 28, 2009 | Sony Walkman NWZ-S616F MP3 Player
I WANT TO RECORD A RADIO PROGRAMME BY DOWNLOADING
Are you in the UK?
1 The easiest thing to do is to record it using a freeview box onto either a video or other recorder.
2 If that's not possible try listen again if on bbc.
3 It's difficult to record directly onto a pc without a tv capture card (and essentially doing 1 above) when you can set a timer to do it automatically.
4 if you don't have that you can connect the headphone output to the microphone input and use the Windows Sound Recorder to then recod the outpu
Nov 08, 2009 | Packard Bell Easy One Silver 2120 Notebook
How do we listen to aCD in 5 channel suround sound without having the TV on we can only get straight sound. We have a Yamaha RX-V365 av receiver.
Do you listen to audio CDs via a CD player or DVD player? Pure audio CD is only 2-channel, so either TV or the DVD player is doing the mix to 5 channels. But you can choose the sound mode via remote - there should be modes like 5ch/7ch stereo, where the same signal is going to all speakers (I you this mode for listening to radio sometimes).
Oct 27, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Sound to radio but no sound to cds or dvds
I dont know what car you've got but,You need to hook up the blue amp remote wire for the antenna, when you switch to radio the antenna signal turns your car amplifier on and you get audio and when you switch to cd/dvd it switches it off because your car is wired that way, its a common issue with Mercedes etc.
May 10, 2009 | Jensen's VM9312 Car DVD Player
Acer Aspire T120 PC Desktop Logo
76 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
