Question about Logitech Premium Stereo Consumer Headset
Logitec premium stereo headset
I only have an onboard sound card and when i plug in the leads for the headset and mic i have to go into the sound manager and change the default setting from my speakers to the headset and then restart whatever i was listening to for it to take effect also the volume and mute control on the lead does not work,i have the volume on the pc settings turned up to full and it is still very quiet this is a new set that i got toda,i am running vista 64 bit and this is the only problem that i have encountered
p.s.(could all this be down to the fact i don't have a seperate sound card)
cheers for any advice in advance
shane
  • Hackles May 05, 2008
    I have just bought a brand new premium stereo headset Logitech. I made two skype calls which worked brilliantly to relatives in Australia. Just when I wanted to recall the first number the microphone status changed inexplicably to muted. No amount of patience or reconfigurin will remove this problem. I did not change any of the commands or switches on the headphones. The previous time this happened the problem seem to be intermittent and was caused by a lose connection in the on and off mechanism that comes with the headset. There is a microphone on and off switch and it seems the wires attached to this are faulty. Has any one else experienced this infuriating problem. Is the only solution to return the headphones and start again? Many thanks H
6ya staff
SOURCE:
sandrew
andrew pester
  • 2961 Answers
SOURCE: Head set problem with vista
you will need to go into the sound manager in control panel and make sure that the external mic is enabled as the default use and ensure in the sound settings that the mic is not muted, this is normally done by right clicking the speaker icon in the taskbar and selecting options and see if the mic is muted or not in the properties
Posted on May 26, 2007
Ekse
  • 13434 Answers
SOURCE: my logitech usb headset dnt work
your program is probably set to use the wrong input for the mic, check your settings.
Posted on Apr 28, 2008
Anonymous
SOURCE: trouble getting sound from Logitech spreakers/headset
Get a ******* clue!!!
Posted on Jun 19, 2008
Dragazarth
  • 8 Answers
SOURCE: mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Posted on Apr 07, 2009
Anonymous
SOURCE: USB Headset mM/N:A-0374A mic problem
I get a problem when gaming all the sound of the game is on the outside of the map and its not with the sound properly
Posted on Dec 29, 2009
I cannot set up h110 headset in my windows xp
Just connect the two connectors to your computer sound card.
Your computer should have a pink connector for the mic and a green for the speakers. You also could plug the speaker (headset) into the orange if your sound card has that colour.
Then you just adjust the volume for the headset with the sound settings of the computer.
The program you want to use the headset with, will also allow you to fine tune the set.
Jun 08, 2014 | Logitech H110 Headset - Stereo
What size earphones or headset do i need
I would go for a USB headset. Logitec makes a nice one. Don't go for earbuds--the logitec has soft headset and mic built in.
Aug 15, 2011 | HP Vs17 17" LCD Flat Panel Monitor
Headset Microphone doesn't work
Plugged in? Is it a stereo plug? does your computer allow speaker and mic on the same wire? Does the outlet say Mic or Headset of Both? Had it worked in the past.
Some computers have a place for a mic - some for headset - some might have both. On a desktop, I would expect to find separate connections. Laptop, Id have to look.
A 'stereo' plug will have a tip, ring and barrel connection.
A 'mono' plug will have a tip and barrel connection only.
A stereo plug would allow a mic and head phone connection ujsing a 'common' for the return.
A mono plug would allow either a mic or a headset, not both.
If you could peer into the jack inside your computer, you could tell if it privides for three wire (stereo) or two wire (mono) operation.
I hope this helps ... If I missed your question, please reask.
We are "paid" here by positive comments where we earn "bragging rights" If you are satisfied, please post positive comments
thanks
a
Oct 12, 2009 | Computers & Internet
I just bought a Logitech Clearchat Stereo Headset and am running Windows XP. The mic is not recognizing while plugged into the front or back plugs. Is there something wrong with my soundcard?
You should go to your Device Manager in the "System" category of the Control panel and see if indeed the driver for your mic is present. It will be listed under "Sound, Video and Gaming devices."
Sep 22, 2009 | Logitech ClearChat Stereo Headset Headset
Logitech clearchat stereo won't work on my inspiron 1545...
try uninstalling sound card from the device manager and reboot the computer.
if the mic does not return you may be missing a driver contact your laptop manufacturer or download new sound card drivers from the websight to restore mic function.
Jul 02, 2009 | Logitech ClearChat Stereo Headset Headset
Mic not working when headphone plugged in
  3. The Audio tab
Apr 07, 2009 | Logitech Premium Headset
Logitech premium usb headset 350 help me pretty please
If when you talk into your mic you hear yourself from speakers...open your volume control(windows) and check the box to mute mic. Not for sure this is a fix to your problem but from what you wrote is similar to problem seen with voice chat software.
Feb 16, 2009 | Video Game Consoles & Games
Microphone not working
maybe its a problem with your sound card. Check your microphone settings in Windows.
Dec 11, 2007 | Altec Lansing Stereo Headset with...
May 26, 2007 | Logitech Premium Stereo Consumer Headset
Logitech Premium Stereo Consumer Headset Logo
Top Logitech Radio Communications Experts
Ekse
Marvin
Marvin
Thomas F. Schneider
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
