Question about Aprilaire 550 Humidifier
No water to my Aprilair model 550.
It has an auto-humidistat that works off outside Temp. and is located on the cold air return. Two things are run off the 24 volt transformer, the humidifier water feed solinoid and the humidifier drain sump pump. When the blower comes on the drain sump pump gets 24 volts but the water feed solinoid does not. I do have water to the solinoid valve but it doesn't open.
Mike
  • Anonymous Nov 20, 2008
    the water inlet value is not working in the furnace Humidifier. how to fix it.
  • Anonymous Dec 04, 2008
    No water gets past the Peter Paul solonoid valve.
    Problem Solver:
  • 11 Answers
Some sump pump have a safty switch that will not let the hum. come on if the tank is full of water, I,m not sure if this is the type that you have but make sure that the pump is pumping water. Also your humidistat have an internal switch that it should be set to bypass not to power Note: some humidifier have their own power supply the 550 dose not
Posted on Feb 09, 2009
6ya staff
SOURCE:
Water and motor always run on Aprilaire 760, even when furnace is off.
Hope this solves your problem, look for the humidistat, it should be located on cold air return duct near furnace, make sure it is not set in the on position, if it is, then this is why it is staying on, please set humidistat any where from 20 to 35%, never over 40%. If the humidistat is set properly and is still running, you may have a electrical problem, humidifier circuit should only receive power(24 volts) when the indoor blower motor of furnace receives power, also if you have galvanized plumbing in your home, you may have a piece of rust or lime deposit in the humidifier solenoid valve preventing it from closing, turn water off to humidifier and disconnect water supply line entering solenoid valve inspect & clean protector screen. Good luck.
Mar 03, 2010 | Aprilaire 700 Humidifier
Our aprilaire humidifier is only 4 years old and it does not seem to be working. We have static in the house and when I did test mode it never drained water like it was supposed to. Any ideas what I can do...
Hope this helps, check and see if humidistat is set to 35% humidity and that bypass damper on humidifier is in the open position or winter position.(humidistat is usually located on cold air return duct near furnace). Next, replace humidifier media pad, remember to replace media pad (filter) annually, you also may want to clean any lime deposit out of humidifier housing with a solution of warm water and white vinegar before installing your new media filter.Remember to turn power off at side of furnace when cleaning humidifier and replacing media. Before installing new media turn power back on to furnace, set humidistat to the on position, turn furnace thermostat above room temp., and inspect humidifier to see if water is running from top,(you may want to have a bucket under humidifier when checking for water), if you see water running, turn power back off to furnace, properly install new media filter, reconnect humidifier cover & set humidistat to 35%. If you do not see water present, check water supply valve to humidifier and make sure its turned on. If water supply valve is open, then check water supply tubing for blockage.And the last things to check is to make sure all registers through out your home are open and not blocked by any objects, also make sure furnace filter is cleaned, if none of this works refer to installation manual to see if humidifier was sized and installed properly, Good luck.
Mar 03, 2010 | Aprilaire 600 Humidifier
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
My Aprilaire 560 doesn't shut off even if the blower is off.
My Aprilair 560 turns on and off repeatedly.Making a loud banging sound.Changed my water valve worked 1 day and started agin.
Dec 20, 2009 | Aprilaire 550 Humidifier
I have a 550 ...I have 3 questions. 1. Can I
1.yes you can service it yourself the 550 takes a number 10 pad I recomend the oem pads for there strength and durability. You need to clean the bottom tray of any lime scale I use a stainless scrunchie. the top tray has a sandy grit surface that should stay there, just clean away the lime scale. Then shut water valve off to the unit remove the incoming line from the solenoid valve and use a dental pick to remove the strainer,clean this out thouroughly of any debri and return it to its home and reconnect the line. Next go to the other side of the solenoid valve and remove the compression nut there blow on the tube to make sure the orifice is clear if not use a orifice drill the same size and clean it out. Return the tube and tighten the compression nut. If all nuts are tight turn water back on (if you have a needle valve which most people use even though there against code, you may need to tighten the packing nut) and check for leaks. Set humidistat till it clicks for testing(this is a manual type with numbers 15% to 45%) then turn on furnace. Depending upon which furnace you have some are tied into the circuit board others have a current sensing relay attached to a 24 volt transformer. You should here the solenoid thump when the furnace kicks in or blower starts. If not you need to check for voltage at the solenoid the 2 wires there will read 24 volts. If not you may have a faulty current sensing relay or other problems. If all work set humidistat to 35% and watch your relative humidity in the house. You may have to adjust as it gets cloder to a lower humidity
Have at it my fingers are cracked enough from cleaning humidifiers
Tinner
Sunsetmech
Dec 14, 2009 | Aprilaire 550 Humidifier
How do I know my aprilair 760 humidifier is working?
A simple check you can perform on your aprilaire 760 is the following:
1) locate the two brown wires coming out of the 760 (these wires will be wired to tell the 760 to turn on when the hvac bower is on and the humidistat is calling for moisture).
2) temprarily disconnect the two brown wires from the external wiring and then short the wires together. All you're doing here is bypassing the your thermostat and bower-on indicator.
With the 70 unit plugged in to the wall outlet and the two brown wires connected together, both the fan and the solenoid valve (water inlet valve) should both be activated.
Dec 13, 2009 | Aprilaire 700 Humidifier
Aprilair 760 Humidfier will not stop water flow to EV panel
If the water continues runs nonstop even when the heater is turned off, you might have either a bad solenoid valve or a bad humidistat. Simply disconnect one of the two low voltage wires going into the unit. If the water turns off then your problem is most likely your humidistat or the low voltage wiring. If the water continues to run even when the low voltage is disconnected you have a defective solenoid valve.
Good luck.......
Apr 09, 2009 | Aprilaire 700 Humidifier
Power is off to aprilaire 550
The Aprilair Hum. donot have a restart button. All there is there is just a 24VAC Solenoid that opens and lets the water flow throu a tube. Check your humidistat, check your wire going to the furnace control board and also your current sensing relay if you have one.
Feb 01, 2009 | Aprilaire 550 Humidifier
Honeywell he220a install
thanks for your question,
you have to install the bypass humidifier on the supply side of your heating system, (hot side) and run a bypass pipe from the return side, (cold side), it does matter which side it goes on, you do not want water vapor going directly into your furnace, as this can damage it and shorten the life of it, your humidistat is installed on the return side of your duct work, this will allow proper operation of the unit as the humidistat senses the moisture in the air and brings on and shuts down the humidifier as needed. hope that helped to answer your question, please let us know what you think, again thanks, mr.grzz
Jan 17, 2009 | Honeywell HE220A1019 Whole House...
Install HE220 HoneyWell , humidity not increasing in the house.
You can try installing the water line to your hot water if it is installed on cold line for more humidification. You should make sure your humidistat is up line 6" @least from humidifier for proper humidification measurement.
Feb 26, 2008 | Honeywell HE220A1019 Whole House...
Aprilaire 550 Humidifier Logo
429 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Doug
Level 1 Expert
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
