Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Brush won't spin when position of handle changes
When we release the handle and let it fall all the way back, the vacuum brush rotates as normal. When we lift the handle to the normal vacuuming position, the brush stops rotating or rotates a little bit and then stops. There isn't as much rotational force when the handle is moved to the normal vacuuming position.
The clutch roller seems to move freely and is in the correct position when the handle is released.
We have replaced both belts already and that did not solve the problem.
Any thoughts?
  • 7 more comments
  • malboeuf Jan 27, 2008
    I tried a second belt (both are the same part number) and no go with the brush. The wheel is still on the tension arm and it moves freely. Is there a switch or some other activation device, other than the plastic piece that moves the tensioner arm, that allows the brush to rotate? I can feel something "click" when the handle is allowed to drop all the way back.
  • Anonymous Feb 04, 2008
    Domvac - I think I have the same problem. How do you access the accuator arm to repair it.
  • Rbrucec Feb 13, 2008
    I have the same problem. I replaced the belts, the brush roll rotates freely- no binding, but the brush roll stops at any carpet setting when it comes in contact with the carpet
  • jmdizon Feb 17, 2008
    I have the same problem except in my case it has a burnt smell. I have already replaced the 2 belts and still no go.  My vacumn cleaner is only 2 years old.
  • Anonymous Mar 01, 2008
    I have a different model U6474-900 and it has the same problem. I replaced both belts. Ours came with extra bags and belts so it should be the correct ones. The end bearings on the brush seem to spin ok. The tension pulley looks ok and appears to be functioning but even it I put additional tension on the belt by pulling up on the pulley with my finger I can easy rotate the brush with my hand. It looks to me that if the small belt was just a little shorter it would be ok. The little belt is 38528-034 both the one that came on the sweeper and the extra. But the model tag on the body of the sweeper has 38528-035 as the belt number.
  • malboeuf Apr 18, 2008
    The message from domvac on January 27 was the ultimate culprit for the problem. The brush roller "seemed" to rotate okay, but upon further review, it needed cleaning and lubrication. Seems that there was too much friction and the belts would slip a bit, then the rubber from the belts would leave deposits in the grooves making the belt slip even more. The total solution was to clean and lubricate the brush roller and clean the grooves for the belt. Thanks for the ideas
  • Anonymous Mar 20, 2014
    brush roller make noise
    brush roll makes a loud noise when i go to vacuum.
    roller brush makes loud noise when operating
  • 126 Answers
The belt for this machine is very specific and only one size fits. It is not uncommon for vac shops to sell the wrong belt because the proper belt is not available from normal supply houses, so they will substitute something they think will work.
Also, assuming you do have the right belt, check the tension arm that drops down on the v-belt when the handle is brought back. This arm has a wheel/bearing with a plastic "tire" or trim that rolls on the belt to tighten it. Sometimes, this tire cracks and falls off and then the remaining bearing won't have the necessary tension to tighten up the belt.
Posted on Jan 27, 2008
  • 1 more comment
  • Ray Sabourin Jan 27, 2008
    There is a switch on the hood of the machine that will allow you to turn the roller off when used on bare floor surfaces. It is located next to the height adjustment, but I am assuming that you already know this. An important fact, You should only adjust this mechanism when the handle is in the upright position. If you attempt to change the position of this switch when the handle is back, the actuator arm on the underside of the knob will be damaged or even break off when the handle is returned to the upright position. I have seen this numerous times and in one case, the plastic piece that broke off fell down into the tensioner arm and would not allow it to fully engage the belt drive. This could be where your trouble is.
    One other thing. I assume that you have checked the brush roll to make sure that it rotates freely. There is a bearing at either end of the roller that will get bound up with hair and dirt and these occasionally require cleaning and re-greasing. If the roller is in need of servicing, the belts will wear quickly and the roll will turn sluggishly if at all. The plastic caps on the ends will unscrew for bearing inspection. Pay particular attention to how the bearing is situated and replace in the same position.
  • Ngoshe8r Dec 16, 2010
    Try looking at the floor height adjustment as well, I just discovered that mine was not operating and causing the burnt smell, which is because the brush at its low cannot do carpet well.
    Flip the Vacuum over and the little set of wheels should get raised and lowered when you change the level on the head, if not this could be the issue. For me the wheels stayed in the same place and when i looked the part that was supposed to alter the level didnt even touch the other part.
The vacuum cleaner is designed for the brush to rotate only when the handle is released for safety resons. I have two of these vacuums and they both operate this way.
Posted on Feb 17, 2008
Brush will not spin
The brush will not spin in the handle is in the upright position. Release the handle and see if it works. If you have a carpet floor switch you might want to check that and make sure it is on carpet.
Sep 09, 2014 | Eureka Vacuums
My brush bar keeps falling down. We replaced motor but now the brushes don't spin.
Hi! If you've replaced the turbine & gear assembly and the brushes are still not spinning, a replacement brush-block assembly may be needed. The brushes counter rotate and need each other to spin. If a single brush is falling out, the brush assembly is broken. If the whole brush assembly keeps falling out, the drive pin shaft may be damaged. To order a replacement brush-block follow the link below.
Search Results
Hope this helps!
Jun 03, 2014 | Hoover F7425-900 SteamVac V2 Widepath...
Left hand brush won't spin
sounds like its sticking and the sharp turn releases the catch properly try lubricating it with either oil or wd40 should ease it hopefully this helps
Apr 01, 2014 | Hoover Floormax F5300 Upright Vacuum
Hi Janet. Thank you for asking this question. Your vacuum wasn't designed with a brush on/off switch so having the brush continually spin is normal for your vacuum.
Jun 29, 2013 | Bissell 3576 CleanView II Bagless Upright...
The brush will not rotate. I thought this was a direct drive system.
Note: The brush will not rotate when the machine is locked in the upright position, because an internal micro-switch turns the brush motor off.
- Check the belt through the clear brush cover. If this appears damaged or broken, please take your machine to a local BISSELL Authorized Service Center to have this replaced. If the belt is intact, please continue checking the following:
- Ensure both power switches are turned on when you check for brush rotation.
- Unplug the power cord and remove the handle completely. Slide handle back into the lower section of handle, ensuring the screw is in tight. If the handle is not aligned properly, this will affect the power of the brush motor.
- Look for debris wrapped around the brush (i.e. string, hair, fibers, etc.). When the machine is unplugged, cut away any visible hair, fibers or debris from the brush roller. This brush is NOT removable from the machine.
- If something has become lodged in the foot and the brush shuts off, turn off the vacuum and unplug this from the outlet. You can now remove the obstruction. The brush will automatically reset when the vacuum is plugged in and turned back on.
If you continue to experience difficulty with this, please take your machine to the following Service Center in your area. The warranty on this machine is five years.
Aug 12, 2010 | Bissell Healthy Home HEPA Bagless Upright...
The rotator brush stopped turning. it turns fine
The brush roll will only spin when your handle is not in the locked upright position, once the handle goes upright - the brushroll de-activates
Dec 22, 2009 | Kenmore Progressive Bagless Upright with...
When I turn on mt dyson is sounds normal. once I
With the DC14 in its upright position, and looking from the back, there is an access hatch just to the right and bottom of the dust canister. Remove this and check for any obstruction. With the hatch still removed, tilt the handle back (as if vacuuming a floor), and you should spot that the mechanism in to which the access hatch fits changes over from one hole to another. This is how suction is transfreered from the telescopic arm to the brush bar when the unit is taken out of the upright position.
With the handle tilted back, the hole you can see is one end of a flexible pipe that leads to the brush bar. Check for any blockage and/or foriegn objects. If there is no obvious problem, you'll need to check the other end of the pipe. You can do this by removing the toe plate on the bottom of the brush bar area. The plate is held by 3 or 4 half turn fasterners - a 5 pence piece is ideal for undoing these.
If still no joy, the only other thing it might be is that the brush bar isnt spinning - this isnt actually lack of suction, but without brush rotation any upright hoover is far less effieicnt at picking up bits from the floor. Brushes not spinning on a DC14 is quiet a difficult thing to fix on a DC14 as there are two separate rubber belts, one of which is hidden under a plastic cover. There is also a clutch mechanism between the belts that can cause problems some times.
Oct 09, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Install New Belt
Lift the headlight and rotate the thumb dial to release the carpet head. It will spin to the side. Rotate the square handle at the front of the vac fully to the left.
Remove the carpet head and open it from the bottom side. Observe which side had a little block below the LED belt indicator when you rotate the brush. The brush must go back in this way. The blocks at the end of the brush are color coded for height adjustment. Remove the brush, slide a genuine belt onto the center and close the bottom cover of the housing. make sure the brush spins freely, now look into the belt opening, round hole at the side. Using the square dial at the front of the head, rotate the hook into the belt to twist the belt and open it for installation onto the motor shaft.
Reinstall the head onto the vac, using the thumb dial to lock into place and rotate the square handle again . This will release the belt tension onto the motor shaft. Raise the vac up two knotches with the pedal before lower onto the carpet.
Sep 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kenmore Beltless Vacuum brush will not spin. Everything else works.
there is a reset button on the side of the lower base of the machine, plug in the unit turn on the switch to the brush and vacuum are both engaged hit the reset button, remember the roller will not engage when the handle is in the upright position, release the handle and your ready to go.let me know if that helped you . thanks renevacdoc
Jul 23, 2009 | Vacuums
No suction
Are you saying that the motor runs but there is no brush rotation ?
If yes then firstly switch machine on then when you pull handle back as if to vacuum the carpet the clutch drive dial must turn to (drive, start, on,) position if it is stuck on (park, off. Stop, p,) position rotate it to drive etc as you pull handle back providing the clutch & both drive belts are ok the brush will spin.
The clutch drive dial knob is situated looking from the front of machine lower left hand side approx 50mm or 2” in diameter.
Please do this test & let me know results
Regards Chris..
Sep 28, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
496 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
