Question about Shuttle ak32vn Motherboard
USB functionality turned off in BIOS
I went to use my AK32VN system recently and at startup BIOS stalled at what looks like a dianostic screen with a blinking cursor. After using this system for more than a couple years this was the first time I'd seen this screen. It listed all the vital specs of my machine but BIOS stopped there. It did not respond to any keystrokes and I eventually had to reboot.
Going into the BIOS menus I found that if I enabled USB functionality under Integrated Peripherals it caused BIOS to stall at this particular screen. If I disabled the functionality then startup works as it should, Window2K boots and everything is fine, except that I no longer can use my USB devises.
I'm a graphic artist so I can't do without my Wacom and scanner. I haven't installed any new devises or made any modifications so I'm puzzled as to what casued this switch in settings. Is this a sign of age? Is there a workaround that I can use to enable USB and make the system boot as normal? Or is it time to replace the old girl?
    Novelist:
  • 113 Answers
I had this same type of problem - and it turns out it was my fault. In my case I have a Dell 24" ultrasharp monitor, which has a USB hub and 4 ports, as well a a number of media reader slots. I had taken some pictures, then plugged the flash SD card into it's slot - and forgot to download the pictures. So I shut down for the evening, and when I tryed to boot the next day, the machine stuck at the bios screen.
I went so far as to swap out my mobo, but when the problem reoccured, I knew it had to be something else. Then I noticed the flash card, removed it, and the boot went fine.
So, do you have anything new plugged into any USB ports?
Worst case, though, if the machine boots properly when some or all USB devices are not connected, you can still connect them after the machine boots, and they should still function.
Posted on Jan 26, 2008
    Genius:
  • 1,554 Answers
Disconnect any usb devices first.
does the error go away?
I recently replaced a Hdd on a PC and downloaded an op system to a usb and all I get is this screen,is there something I'm doing wrong or missing something?
Try to make sure that the installation that you put on the flash drive is bootable. Use pendrive Linux http://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/
I personally use it as it is very easy to make bootable flash drives
Apr 02, 2015 | Microsoft Computers & Internet
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
How to enable function key?
Generally Function key can be enabled from BIOS settings. BIOS settings can be accessed by pressing DEL, F10 or F2 key at system startup (depending on the laptop u have), which is prompted at screen at startup.
Give it a try
Jul 27, 2013 | Samsung RV511A01 Notebook
I have a dell optiplex gx280, got error:"inmountable boot volume" after restarting will not reboot and I dont have startup disc, please help
Sounds like there is problem with the hard dive file structure, or OS image.
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Dec 04, 2012 | Dell Computers & Internet
Add boot option and change boot to usb
You need to change boot options in BIOS. Press required F key during boot. Look on the screen since Function keys vary with systems. In boot options make USB 1st. Save and reboot.
Note: Some systems have an boot option during startup. Thus eliminating the need for BIOS change. Again, look on the screen for F key.
Oct 28, 2012 | ASUS U46ERAL5 Notebook
No operating system found can't boot from usb there is no boot from usb option
Did you try pressing F8 key at boot up?
  • 1
    Turn on your laptop and look at the first screen that comes up as soon as it is on. This screen will tell you "Press x key to enter setup", replacing "x" with the actual BIOS access key. It's usually "Del" or "F2" on Toshiba systems.
  • 2
    Press the key firmly and quickly before the screen goes away. If you do not react quickly enough, you will miss the window of opportunity to enter the BIOS. On Toshiba systems, this window of opportunity is somewhere between two to five seconds.
  • 3
    Navigate your BIOS configuration screen to the "Boot" tab. It is usually just before "Exit."
  • 4
    As the first boot device, select "USB," or "USB HDD." If you have a "USB ZIP" option, you might be able to boot from it, so select that if you have no other choice.
  • 5
    Press the button for "Save and Exit" in your BIOS. The correct button is usually F10.
  • Read more: How Do I Get My Toshiba to Boot From a USB? ' eHow.com http://www.ehow.com/how_5970005_do-toshiba-boot-usb_.html#ixzz1hrx9qZ3j
    Dec 28, 2011 | Toshiba Computers & Internet
    SCREEN WENT BLANK THEN WINDOWS COULD NOT START BECAUSE THE FOLLOWING FILE IS MISSING OR CORRUPTWINDOWSSYSTEM32CONFIGSYSTEM\r CAME ON THE SCREEN TRIED TO GET INTO BIOS BUT ONLY COMING UP WITH PLEASE WAIT
    Dear user,
    if you are trying to access bios for setup of CD ROM as a first boot device and having problem to access the bios then here is an advice for you.
    most of notebooks or systems have a special key assigned to select the boot device at startup without entering in bios setup. therefore please hit function keys at startup like F9,F11,F12 when you start system. F9 and F12 keys are most commonly used for boot device selection.
    hopefully you will understand my advice.
    Please dont forget to RAte my solution
    Sep 09, 2009 | Acer Aspire 3000 Notebook
    Update my Intel D845GVSR Bios Version to VA84510A.86A.0056.P20, then my USB driver is not working at all.
    I followed the suggestion of changing the BIOS configuration to the recovery mode, however one thing was missing - it required a startup disk and I didn't have one. I then changed the BIOS configuration to the config (pins 2 & 3) mode, booted up and went to the BIOS/CMOS setup and a new menu tab appeared called "maintenance". I went to the advance tab and selected USB configuration and, instead of a blank screen, there appeared a selection for USB support and it showed disabled. I changed the setting to enabled and three more lines of information regarding USB came up, but required not further changes. I went to F10 and saved and exited and I now have me USB capability back.
    Mar 10, 2008 | Intel D845GVSR Motherboard
    MS Keyboard Update Update
    Have you tried enabling usb legacy support in the BIOS?
    Feb 06, 2008 | Microsoft Natural Ergonomic 4000
    MS Keyboaeds
    Go to bios in motherboard configuration, sometimes called peripherals in bios find legacy support and enable it. It will help us to know which Dell do you have.
    Shuttle ak32vn Motherboard Logo
    108 people viewed this question
    Top Shuttle Computers & Internet Experts
    Iqbal Husain
    Iqbal Husain
    David
    David
    Alun Cox
    Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
