Question about Sony KP-48S75 48" Rear Projection Television
Red and green off
Just the red and green are off on left side about half way to the top...by off i mean not centered and lines are wavy just on left side i have tried the conv. adjustment and i can see the lines move but not line up like they need to go over about an half inch more...anything i can do? thanks
    Genius:
  • 1,139 Answers
Hello nroxxhard,
It sounds like your convergence amplifiers are malfunctioning. These can be replaced, but I always like to troubleshoot to figure out why they went bad in the first place. That is why my suggestion to you would be to have the TV checked by a qualified TV technician. There are many sites that tell you how to replace the amplifiers yourself, however it has been my experience, in having to do re-work on sets people have tried to replace parts themselves without proper knowledge. So if you want to do this yourself: (I suggest that you not), locate the two STK circuit modules (black six sided IC module) connected to a Heat Sink, then unscrew the screws holding the modules to the heat sink. Using your schematic diagram locate and note all of the biasing resistors connected to the convergence amplifiers, you will need to replace these. Once that is done, de-solder the convergence amplifiers and the biasing resistors, Replace them with the new components, re-solder them and then check the solder connections to make sure you have not created any shorts, and this end the replacement of the parts in question. That's the process.
I hope this helps,
Thank you,
Shuttle83
Posted on Jan 26, 2008
What will cause a wavy blue lines running left to right from the top down
That is knon as a convergence failure. Its real common an a failry easy DIY fix. You can read more about how to fix it here in this video and on the fixya tips page below.
07e70208-1f08-4826-857e-065c46e4dbb8.pngFixya Tip Page
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 15, 2013 | Philips Televison & Video
In Word 2007 I get a blue wavy line under most of the text like the green wavy line for grammar and the red wavy line for spelling. I think it is to do with formatting but I cannot find how to get rid of...
Hi dtennant
Blue lines indicate that Word has auto-corrected a word. To undo the change move the cursor over the blue line and left click the lightning bolt. Select 'Change back to'. Or to stop Word correcting that word again select 'Stop Automatically Correcting'
Does this help?
May 13, 2009 | Microsoft Computers & Internet
Wavy Red lines
hi there,
if you are familiar with electronics you can do this :adjust voltage at hight voltage block it has screen and focus written on it and comes from flyback transformer,but be careful cause it can be to dangerous if you touch something else,ah,ah adjust only the one that says screen and has a R on top,that means red,ok,thanks.
Jun 19, 2008 | JVC AV-48WP30 48" Rear Projection...
Did you ever get an answer on what is wrong with your tv
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 09, 2008 | Philips 55PW9363 55" Rear Projection...
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
Three colors line up on some spots but not others
Jan 06, 2008 | Zenith IQB50M90W 50" Rear Projection...
Long power up time, wavy "static" lines, and red/orange problems
part of it sounds like your coax cable is not connecting properly. pull it out and make sure the pin at both ends of the coax cable is straight if bent replace coax cable.
Dec 28, 2007 | Hitachi 32UDX10S 32" TV
Red line across top half of screen
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Dec 02, 2007 | Gateway MX6438 Notebook
I am told my Hitachi 61SDX01B (UltraVision/Ultrascan) has "Green Geometry"
Sounds like a convergence promblem.
Here are some of the most common symptoms of a convergence problem.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Oct 15, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Sony KP-48S75 48" Rear Projection Television Logo
42 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
