Question about Video Cameras
Camera freezes when insert sd card
Just freezes when the sd card is inserted cant turn it off the picture functions everything freezes the only way to start it is take sd card out then it functions fine
  • 49 Answers
SOURCE: SD card
Try formatting the card first. You can use another camera, or a computer with card reader for this. On a pc right-click on the card in My Computer and choose format. On a Mac, hold control and click on the card in Finder and choose format. Try it in the camcorder again. Also, some card speeds or sizes might not work in your camera. ie - 1gig or higher. Try a smaller card. Check your manual, check the manufacturer's web site, or go to google groups.
Posted on Sep 14, 2007
  • 205 Answers
SOURCE: Memory card
When you use an SD card in mulitple cameras, each camera creates it's own folder beneath the DCIM folder. I'm not sure if you have a program that automatically opens when you insert the SD card in your reader, but perhaps you can try double clicking on "My Computer" and locating your reader/SD card and opening that folder manually. Once you're there, open the DCIM folder and see if there are multiple folders inside. Open each one to see if you can locate your pictures.
If you have a program that opens automatically when you insert the SD card you'll need to figure out how to tell it to look in other folders.
Posted on Dec 28, 2007
  • 14 Answers
SOURCE: Can not detect sd card
Make sure your card is NOT an SDHC. the HX470x only reads standard SD cards. The largest that I have found is 4GB SD (not SDHC)
Posted on Apr 10, 2008
SOURCE: Saying Insert SD Card When Its Inserted
well i had the same problem so i took it to tmobile and the guy on the register inserted a new SD card and he said that my old SD card was ful. so i ask him how can i clear it out and he showed me this lil usb SD card reader that they sell at the store and it was 9.99. but other then that basiclly it means that your SD card us full and you just hook it up to the usb SD card reader and plug it to any computer and go back and clean your files and re-use it again. thats about it. hope that help! : )
Posted on May 25, 2009
  • 5 Answers
SOURCE: "please insert memory card in GZ-MG130U CAMACORDER
You need to tell it in the settings menu that you want to record to the hard drive instead of the SD card.
Posted on Oct 15, 2009
Camera says insert an sd card when I already have one. will not let me take pictures
maybe the problem is in your SD card, try to used another SD card. and check if it works.
Feb 14, 2014 | mid M9100 9" Dual Camera Android 4.0 ICSOS...
SD Card states error card when inserting and turning it on.
you need to go into the settings on the camera and ask it to format
May 30, 2013 | Vivitar Cameras
When i turn on my camera it says Meomory card unusable insert new memory card
Try formating the memory card using the camera's Menu - select format memory card.
Feb 27, 2013 | Kodak EasyShare Z710 Digital Camera
I have a Pentax OPTIO S6, recently all camera function freezes whenever i insert an SD card, the screen turns on and I could see an image but ALL buttons do not work including the shutter! When I remove...
Does a different card work in the camera?
Can you read the card on your computer with a card reader?
and...check the little slider thingy on the side of the SD card, flick it up, try it, flick it down...try again.
check the SD slot on the camera, anything stuck in there? lint? dust? sand?
Blow it out with canned air.
Eliminate the card as a problem...hope it's the card then worry about the camera.
Good luck
TickMagnet
Aug 17, 2011 | Pentax Optio S6 Digital Camera
When I turn on my Vivitar DVR 410,it says:Memory Full! Please insert an SD Memory Card.Then when I insert my card, it still says Memory Full! Please insert an SD Memory Card.It wont let me take a...
Remove the SD memory card from the camera, go into menu and locate "format" follow the prompt to remove all photo's from the internal memory, when completed install the SD card back in the camera to resume normal operation.
May 28, 2011 | Cameras
I have a vivicam 7025, when i insert the SD card says card inserted but then says its going back to internal memory so i cant take no pictures
I also have a vivicam 7025, with the same problem, when I insert the SD card, first it recognises that a card has been inserted but then it says its going back to internal memory. I can't take any photo's and am VERY frustrated!!! Did you find out how to sort yours out?
Dec 21, 2010 | Vivitar Cameras
Nikon coolpix 4100
I've heard the camera "STALLS" when any sd card larger than 256 is installed, how big is your card?
Feb 21, 2008 | Nikon Coolpix 4100 Digital Camera
Transfer picture from internal memory to sd card
insert memory card turn camera on press menu function , press ok to copy to card cilck on execute. hope it helps
Aug 25, 2007 | Vivitar ViviCam 4100 Digital Camera
Open Questions:
My Hitachi VM H710A plays just fine, and the picture looks fine. But when it playsback footage or records footage, five to ten seconds later, it stops abruptly, and flashes the word "TAPE". First thing I must add, is that I was using a prerecorded videotape, and was testing it from the beginning of the cassette and the middle of the cassette. I thought maybe the heads were dirty, and so I cleaned them using a cotton swab and rubbing alcohol. I cleaned the head drum with a piece of paper soaked with rubbing alcohol so that I wouldn't get any fibres in the heads. I waited for it to dry and then I put a cleaning cassette inside. To which, it still stopped abruptly five to ten seconds in during playback. I then decided to look at the manual of the camcorder and see the symptom. It says that due to temperature changes that it might cause this symptom. I placed it in a cool room and left it there all day and checked on it, and the camcorder is still doing the same thing as before hand. Then another cause said that it might sense some moisture. I made sure that the camcorder was dry externally and internally, and yet still, same problem. Thats when I decided to take it apart and look inside to see if there was anything odd inside the camcorder causing it to function the way it does. The belt seemed to be working fine, and there was no missing parts. The tracking poles and path alignment was fine, and not loose. Everything simply seemed just fine. So I am unsure as to why my camcorder is operating like this.
Sep 17, 2018 | Hitachi Video Cameras
Video Cameras Logo
97 people viewed this question
Top Video Cameras Experts
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
