Question about Canon MX700 Office All-In-One InkJet Printer
Error code 6A80
Error code is displayed while trying to set up printer
  • hobsok Jan 28, 2008
    company decided to replace printer
  • Anonymous Oct 06, 2008
    I have ths same error code 6a80. I have openned it up and found nothing in the way. You said the ink is normally on the right side . Mine was on the left side when I oppened it up. Does this indicate an additional problem?
  • 11 Answers
It is because of Purge unit can be damaged or stuck. Probably you have to pulled apart the printer and check the purge unit.
Posted on Feb 04, 2008
  • Ibrahim Senyer Feb 04, 2008
    Error is technically APP position error
  • van hauwaert Jan Feb 20, 2012
    What is "the purge unit" ?
3 Suggested Answers
  • 32 Answers
SOURCE: error 6A80
Error 6A80 indicates that "an error occurred in the APP motor
during purging operation". Either the sheet feed unit, purge unit, or logic board could be at fault.
I'd recommend bringing the unit into your local canon authorized service facility for complete diagnostic and repair.
Posted on May 28, 2009
  • 8 Answers
SOURCE: Error Code 6A80 on the Canon MX700
Supply Guy,
Here is the solution.
I am going to describe 4 buttons on your printer. Then, I will tell you what to do with these buttons to resolve this error.
1. Look for the Black & White selection button (large white button w/ black diamond on it).
2. Look for small pink button (bottom left corner of your printer control panel).
3. Look for the OK button (big button in middle).
4. Look for the On/Off button (top left).
OK - here we go. With the printer turned off, do this:
1. Using four fingers, one on each of the four buttons, press them all and hold them down for 10 seconds.
2. Release the On/Off button - but keep holding the other 3.
3. After a few more seconds the printer will turn on. When it does this, you can release the other three buttons.
So, to summarize, you press all 4 buttons for 10 seconds, release the power button and wait for the printer to turn on. After it is on, let go the other 3.
Your error message should go away. If you don't hold the buttons all down simultaneously, the printer could go into Fax mode; just turn it off and try again.
Posted on Dec 29, 2009
Error code 6A80, won't print after changing ink cartridge. printhead is all the way to left. Tried moving it manually and turning off and unplugging printer.
@font-face { font-family: "Times New Roman"; }@font-face { font-family: "Verdana"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in 0in 0.0001pt; font-size: 14pt; font-family: Verdana; }table.MsoNormalTable { font-size: 10pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; }
Issue: ERROR LCD: Error Code 6A80
Solution #1: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Solution #2: Removing paper jams MX700
See very detailed description at this link:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx700#ServiceAndSupport
Jun 30, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I have a Canon MP550 and after pressing ON button in few seconfs appeares message: ERROR CODE 6A80
[6A80] & Light Blinking 12 times = APP Position Error. An error occurred in the APP motor. Maybe foreign material or paper debris around the PURGE UNIT (at the printer most right hand side) or Auto Sheet Feed area.
May 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I received an error code 6A80
Solution:
  • Switch the printer OFF
  • Press buttons 1 + 2 + 3 and 4 (simultaneously using four fingers)
  • Keep pressing this four buttons for 10 seconds
  • Release the On/Off button (number 4) (Keeping pressing the others)
  • After a few seconds (when the printer go ON), release buttons 1, 2, 3
Jan 31, 2010 | Canon PIXMA MX700 All-In-One InkJet...
How do I re-set error 6A80? on my Canon PIXMA MX700 lcd display?
6A80 is APP position error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output)
is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.Check the sheet feeder.If this not help your printer need service.
Nov 01, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Code Error 6A80
6A80 error is an APP position error. It means that an error has occured when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Oct 20, 2009 | Canon MX700 Office All-In-One InkJet...
Error 6A80
May 22, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Canon MX700 Office All-In-One InkJet Printer Logo
731 people viewed this question
old marine
old marine
