Question about Dynex DX-E401 Router
No connection I have a Dynex - DX - E402 wired router connected to my pc. I'm using it to connect my PS3 and computer to the internet. It was working fine but then stopped. Before I was able to connect to the internet with my computer and use my PS3 to play online games, then it just stpped working. I can't connect to the internet with either system, I tried resetting the modem, router, PS3 and computer but still nothing works. If I plug the modem directly into the computer I can use the internet. Pleas help me ?
  • 2 more comments
  • legerdavid Jan 27, 2008
    Tried that didn't help!
  • legerdavid Jan 28, 2008
    Nothing wrong with the router. Nothing wrong with the modem
  • jhoiu116 Feb 14, 2008
    two computers and a ps2 were working fine off my dynex dx-e401 router. then everything stopped. now only one computer works directly from the modem. nothing works through the router, and the other computer and ps2 don't work directly from the modem. any ideas?
    i just poseted about only one computer working while it is directly plugged into the modem. i shoud have noted that when i plug in my router my computer shows an internet connection, but i cannot access the internet. any ideas?
  • 1,554 Answers
Try resetting the router to factory , should have a button on the back to do this .
you will have to log back into it with the default factory password
see their site for more info.
Posted on Jan 26, 2008
  • Karl Whisenand
    Karl Whisenand Jan 27, 2008
    The router may be fried , the front panel lights should give you some indication if it is working at all,
    I assume you have the wan on router connected to the wan on modem.
  • Karl Whisenand
    And a side note don't just push the reset on router , push and hold it at least 20 seconds.
After connecting my Dynex DX-E402 wifi router to my desktop computer and running the Quick Setup on the router website I still cannot connect to the internet nor will my Netflix-ready DVD player connect to...
Typically wireless routers have one port labeled WAN and four additional standard network ports. The WAN port should be connected to your broadband device, typically a cable modem or DSL modem. You can configure your router with a direct connection to any of the standard ports connected to your computer. Your router must be configured to DHCP automatically with its connection to the modem through the WAN port. So to repeat, outside world to MODEM, then WAN port on router, the wired or wireless connection to your computer.
Nov 03, 2017 | Dynex DX-E402 Router
How to connect a dynex (dx-e402)router to linksys (befsr41) router
Configure the dynex on another computer that is not connected to the linksys router.
Assuming that your linksys is currently setup as
Turn off DHCP on the dynex and setup the IP to subnet mask gateway
use a cross over cable and plug each ends to the LAN port on port routers.
you should now be able to ping (dynex router) from your other computers on the linksys router network.
any computer that is connected to the dynex should be able to get a dhcp address from the linksys router.
Mar 01, 2011 | Dynex 4-Port Ethernet Broadband Router...
When i connect my modem directly to my computer i get internet access. when i connect to my dynex router, i get no access on my computer or xbox
You can go here and download the quick setup guide and manual for your router which will walk you through the setup.
The most common reason it won't connect is that you must have the router's IP number (the one listed as default IP in the manual) set as the GATEWAY address on your computer network settings and your xbox settings, otherwise they can not talk to the router.
Feb 18, 2011 | Dynex DX-E402 Router
I'm trying to get a dynex DX-E402 to join my airport express
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 01, 2010 | Dynex DX-E402 Router
I hook it up the way the guide says to but it never lets me connect to the internet but if i unhook it the internet work fine what im i doing wrong
So that means if you connect the computer to the modem, it works but the router doesnot work.
You will need to check the settings of the router. If necessary then reconfigure the router.
Click Here for more info
Oct 25, 2009 | Dynex DX-E402 Router
Cannot connect to internet using Dynex Wired Router
First, power down all equipment.
Second, plug in power to modem, let all the lights come on and boot up
Third, plug in the router power and let that boot up and the lights come on
Fourth, Plug in each pc to the ports labeled 1-4
The WAN port should be connected to the Modem also.
Mar 19, 2009 | Dynex 4-Port Ethernet Broadband Router...
Can  Dynex 4 Port Router DX-E402 be used to connect internet on a notebook without using cable to notebook?? i.e. Can it be used like a wireless g router??
Unfortunately, the DX-E402 is not a wireless router, so it can not transmit its signal without a physical cable connecting the router to your computer. If you want a wireless router that can also connect to your ISP, check out the Dynex Enhanced Wireless G Router:
Nov 28, 2008 | Dynex 4-Port Ethernet Broadband Router...
No internet connection threw Dynex DX-E402
  1. Go to Control Panel on your computer. Then Click on Network Connections. Look for Local Area connection. RIght click on it and click properties.
  2. Look for Internet protocol TCP/IP. Select it and click Properties. Make sure that Obtain IP address automatically and Obtain DNS servers automatically.
  3. Then, check the IP address of your computer by doing a right click on Local area connection again, but this time click on Status then click support. The IP address that your computer should have is in the range of 192.168.1.x
  4. You may also check if the Ethernet light on your router is on for your computer's connection.
Hope this helps!
Nov 15, 2008 | Dynex 4-Port Ethernet Broadband Router...
Computers & Internet Logo
162 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
