Question about NetGear WGT624 Wireless Router
Adding computer to wireless router
Newbie here.
I set up a new NetGear WGT 624 wireless G router (connecter to TimeWarner cable modem) to work with a new Toshiba Satellite Laptop A215 which came with an internal card.
Now I'd like to add a (donated) GigaFast Wireless G USB 2.0 Adapter WF747-UI to my Sony PC (running XP). I have the CD for this & tried an install, which seemed to take. The PC "sees" the NetGear router with very good signal strength, but can't connect.
I can't resolve this using the Windows wizard. I suspect I have to approach this from a different direction..... Where do I start?
  • unclemarty Jan 26, 2008
    Thanks guys! I'm so new to this wireless issue I don't even have milk teeth.
    It will take me some time to work through dkennedy1 's suggestion.
    I blazed through the NetGear set up and seem to remember enabling encryption, but changed nothing from the factory defaults. (& yes Coldcut, only one router -Thanks!).
    The Gigafast install gave me problems ..... Think I should uninstall and start over once I have my encryption key in hand? ...
    New to fixya, will try to leave positives for both of ya!
    Thanks again
  • dkennedy1 May 11, 2010
    Do you have encryption enabled on the NetGear? If so, log into the router and write down the excryption key that you set up and the SSID. Also see if you are broadcasting 802.11B, 802.11G, or both.
    Once you have this, log onto the Sony and open the wireless connection manager. Maske sure that the wireless network it sees it yours, should be trying to connect to the SSID you wrote down, make sure the card is configured to work on the right channel, 802.11B or 802.11G, and enter the correct encryption key. Keys ARE case sensitive so make sure you enter it exactly as you wrote don including any spaces that you used.
    Once you do that, try to connect to the router. If you still have a problem, log back into the router and turn off the encryption. Try again to connect to the router. If this works, then you know you have an issue with encryption. If it still does not work, try a different card. Once you resolve this make sure to enable encryption on the router ans you do not want to have a wide open network.
    Genius:
  • 1,554 Answers
1st reset the router and it will go to factory defaults.
button on the back.
no passwords..etc.
is this the only router you have connected to the modem?
if not then set this router for no dhcp.
Posted on Jan 26, 2008
Download smart wizard instalation assistany wgt 624
Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 25, 2013 | NetGear WGR614 Router
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
Need to update firmware on netgear wgt 624 v4 router
Hi ckane47,
You can download and read about problems and solutions for this model HERE.
Goo Luck,
And don't forget to leave a rating.
Thanks
Mark
Oct 07, 2009 | NetGear WGT624 Wireless Router
Password key for my wireless router netgear WGT 624
To access your router's software and programming, go to your internet address bar and type 192.168.1.1
If it asks you for username and password, type admin for both. Change settings from here.
Sep 13, 2009 | NetGear WGT624 Wireless Router
I cannot connect to the internet when I use the netgear router.
If I am understanding you correctly, you are removing the cable from the modem, then connecting it to the router. This is your first mistake. Once you've completed the connecting wizard on the CD that came with the router, you should take the cable that is connected from your modem to your PC, and disconnect it from the PC and connect it to the "WAN" port on the router. Then take a second CAT5 cable, and connect it to port 1 on the router, then to your PC where the first cable was connected. If this does not solve your issue, please respond.
Mar 30, 2009 | NetGear SUPER-G WGT624 Wireless Router...
Works for short time then all lights blink
u ned to make sure router has been properly configured.u may give a try by logging into the router webinterface using 192.168.1.1/routerlogin.com
once u have opnd the router page clik on "basic settings-no and apply the settings",then clik on "router status" and check for ip address internet port(should not be o.o.o.o),if it has some numbers(perfect),then clik on "wireless settings" under "setup" and do all the wireless settings as per requirements
i hope u will try to do all these steps
Jan 10, 2009 | NetGear WGT624 Wireless Router
Attempting to connect netgear 624 to modem with desk top computer
first call comcast that you'll use a router with the modem.
then connect the cable modem to the router.
then connect the desktop to the router and use the supplied cd.
Dec 12, 2008 | Computers & Internet
D-Link connect to comcast
connect the the ethernet cable to the WAN port of the modem.
the connection should be:
One end of the cable is connected to the modem and the other should be connected at the WAN port of the modem.
Now use another Ethernet cable plug it in on the LAN port1 and the other end to your computer.
Access the configuration page of your router and set the wireless setting inside your DI-624 router.
Dec 10, 2008 | D-Link DIR-625 (790069292637) Wireless...
Setting Up the Netgear WGT624 as a bridge
Just disable the DHCP function of the Netgear router. Connect them from LAN port of 2wire to LAN port of Netgear.
Nov 25, 2008 | NetGear WGT624 Wireless Router
NetGear WGT624 Wireless Router Logo
186 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
