Question about Sanyo DS31520 31" TV
Sanyo DS32920 Prior to by picture going out, there was a lot of green background. Now, I have no picture on my tv, but I have good sound. What do I do to get it repaired.
  • 281 Answers
Your base socket is blown, most probably from what you have said. That is the socket that is soldered to a board that you plug to the rear end of the crt. Buy a new one and get exactly the same type.
Posted on Feb 01, 2008
6ya staff
SOURCE:
Sanyo lcd32k30td tv has blue screen , get sound no picture , cannot change channels or use any controls on remote or side of tv.
switch it off for 10 seconds .. then press button TV/AV
its probably due to power fluctuation ..
if the problem occurs check for local warranty service or service center
Mar 29, 2011 | Sanyo DS32920 32" TV
Tip
Sanyo DS32920 Manual Download
Download Sanyo DS32920 TV Manual
Have you misplaced your Sanyo DS32920 TV Owners Manual?
Would you like a digital, searchable, pdf version of the Sanyo DS32920 TV Users Guide?
Follow this link
(& click FREE) to download a pdf version of the operations manual.
I hope that helps.
on Apr 30, 2010 | Televison & Video
Tip
Follow this link
I hope that helps.
on Apr 26, 2010 | Sanyo DS32920 32" TV
My sanyo tv screen keeps disappearing with green lines on thris
Green retrace lines could me two things, the green gun in the CRT is shorting out and that is the picture tube, and it is not worth fixing. Another thing that it could be is a bad neck board and the green driver transistor is shorting, but that would be green all the time, I would say it is the picture tube, and buy a new TV.
Feb 23, 2011 | Sanyo DS32920 32" TV
Green light comes on no picmor sound
Hello Afox5, hi, make sure that there are no user controls or setup that are out of order. as a backgrounder, TV of this type mostly has two boards, power supply and main board. On the power supply board, this has two section, primary that deals with mains voltage and secondary that deals with TV supply current requirements, if you see green light mean that power on the secondary section of the power supply board of your TV is working, but it does not mean that the power supplied to the main board is correct, the supplied current produced by the power supply section to the main board that controls sound and picture needs to be checked, so voltages are needed to be checked and loose wiring, or screws needs tightening, are a common trouble, but some go to extremes like replacement of any boards.
Aug 31, 2010 | Sanyo DP42746 42 in. Plasma Television
Intermittent pixel scrambling on screen (have AT&T u-verse/ Sanyo DS32920 Flat panel 32" TV)
Usually the result of a weak or interruption of the signal. If it occurs on all channels, look into getting an inline amplifier. If you have several splitters going to different tv's or a multiple splitter, the signal is degraded each time the signal is split. You can test this be temporarily making a direct link to the TV from the cable source. If it clears up, then you know you need to amplify the signal.
Feb 24, 2010 | Sanyo DS32920 32" TV
Blue screen no picture but still has audio
replace flyback,or,horz.output transistor
Feb 13, 2010 | Sanyo DS32920 32" TV
My 32" sanyo picture goes green
needs resoldering, in the heated areas, such as, crt socket board, power area, and high voltage area....it will be back to normal...
Oct 20, 2009 | Sanyo DS32920 32" TV
Sanyo mts stereo tv purchase in 1998
Must have original remote with Sanyo. Go online for search to Sanyo customer support
Dec 24, 2007 | Sanyo DS32920 32" TV
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Sanyo DS31520 31" TV Logo
27 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
