Question about Sony PlayStation 2 (PS2) Console
Missing file When I purchased my new computer I had the business move the files from the old one to the new one. Now, when I boot up the old computer it says there is a missing file and the mouse will not work. I was advised to just keep trying to re-install windows 98, however I have done this at least 3 times and it still gives me the message to attach a mouse. There is a mouse attached, I can get booted up into the safe mode but still cannot do anything because the mouse won't work. The business that transferred my files can't seem to be helpful either. I don't want to take the old computer in to see if they can fix it because I don't want the expense, however I do know someone that would like to have my old computer to start learning on. My old computer brand is Seanex, which seems to be unusual. Would be grateful if you can be of any assistance.
  • 105 Answers
You are probably going to need a driver to install.
find the brand of mouse go to their website and download the drivers then install those drivers on windows. this could also be hardware failure or 10 other things without the computer it would be difficult to debug.
Posted on Jan 26, 2008
Missing Boot INI File when starting a Dual Boot Machine , Win 7 64 bit and Win 10 64 Bit
Windows 10 is the default and will be looking for a EFI file that is probably not set up on your old hdd. Change the format of the old hdd to accommodate the new type of boot file.
Sep 29, 2015 | Computers & Internet
Hi, i have a problem in my personal computer showing in the starting windows (1801 MISSING OR INVALID PROCESSOR MICROCODE UPDATE) please help me in this problem thanks
Try to boot first in safe mode then re-start your PC back in a normal boot. Otherwise, In this case try to download an update for your firmware available based on the model of your PC..
Sep 28, 2010 | HP Compaq Business d530 PC Desktop
File: \Windows\system32\drivers\wdf01000.sys status: 0xc0000098 info
Boot up from the DVD drive with a windows bootup DVD, or boot up in recovery console, Ok, rename the file Wdf01000.sys to Wdf01000.old and copy new file from the Vista CD back to local drivers folder. then you will be back in business.
May 19, 2010 | Acer Aspire 3680 Laptop
Computer does not boot
you have to installed a new Windows xp but when he ask the repair and new installation the go for the repair you got the old files as it is
Apr 15, 2009 | Sony VAIO (PCWA-A200)
Windows system 32 hal.dll error after restoring e-machine
There's actually a number of reasons why these annoying little DLL errors happen, but the most common, is caused when new programs are installed over all old ones and the old ones are not completely uninstalled 100%, causing registry pile ups and of course, getting a .DLL error messages.
Another reason, is damage that's been done by malware/spyware/adware programs, attaching themselves to your PC and wrecking havoc, deleting crucial DLL files from your PC.
The hal.dll file is created during install from 5 other dlls. HAL is the Hardware Abstraction Layer and it's the interface between the system drivers and the actual hardware.
Copying hal.dll will not resolve the problem.
A lot of times the file will be reported missing due to corruption of the boot sector or of the file system
Causes of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll file or a hal.dll file that has been deleted or moved from its intended location.
Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged HDD.
Suggested remodies-
1. Restart the PC. The hal.dll error could be a fluke.
2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
6. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
7. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
8. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Important: If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
9. Replace the hard drive. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
10. Perform a new installation of Windows XP after installing the new hard drive.
I have not tried it - but HERE is a free program purporting to fix the error.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Apr 10, 2009 | E-Machines eMachines Desktop PC
Outlook 2007 - address book
Right click on the contacts folder and check the box show my contact in address book
Jun 19, 2008 | Microsoft Office Professional 2007 Full...
Error message\system32\ntskrnl.exe.
you need to repair or repair your operating system. but first you need to purchase this windows xp in order for you to repair this. yes you have a corrupted file in your system. the cause of this is the improper shut down, or a virus that infected a system folder
Apr 29, 2008 | Syntax SV266M Motherboard
Winxp cannot boot - missing files message
probably corrupted operating system files. i'd suggest doing a fresh reinstall of windows xp. if the problem continues then get a new hard drive.
Dec 27, 2007 | Computers & Internet
Just make sure you get these files on your computer.
Download hal.dll from here:
http://www.dll-files.com/dllindex/dll-files.shtml?hal
Place it in windows\system32 folder.
Now go to the drive you have windows installed in (C:/ for example), and then create a new file, name it boot.ini.
Open boot.ini with notepad, and enter this:
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS /usepmtimer
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Save boot.ini now, and try booting your computer, it should work.
Nov 17, 2007 | Computers & Internet
Sony PlayStation 2 (PS2) Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
