Scanner says unlock .we dont know how to unlock scanner
  • dsmitto Jan 26, 2008
    printer is a compaq a3000
    scanner says scanner motor is stalled
    President:
  • 2,351 Answers
Need the name of printer/scanner & model number in order to coninue.
Posted on Jan 26, 2008
  • Mike Peluso
    Mike Peluso Jan 27, 2008
    If this is a new all-in-one make sure all tape is removed.
    Go to page 27 in your manual for printer/scanner troubles.
    There may have been an error during install of your software. Please un-install the a3000 as shown on pg. 28
    The Scan To menu is created by your computer. If the A3000 has not been attached to a PC with the settings utility installed, the Scan To menu will be blank when you press the scan button. Otherwise, Make sure the USB cable is connected and the A3000 software has been installed. Run the A3000 settings utility. If it is already running, right-click on the icon in the system tray and shut it down before running it again.
How to unlock my screen. i press f2 on start up then i dont know how to unlock the screen
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
hope this helps
Jun 27, 2012 | Computers & Internet
The error message- Release the scanner lock- came on with the scanner UNLOCKED in the first place. I've troubleshooted and (flipped switch) unlocked scanner- several times- and turned MP830 off and...
I am not 100% sure on this but I do know that most printers and scanners when straight out of the box sometimes have tape or some foam that they use to keep the bits that move around from moving. I would check your manual from end to end and if you dont find anything in it then I would contact tech support for Canon as it may be that this is a bug of some sort that they may already have a fix for.
Jun 19, 2011 | Canon PIXMA MP830 All-In-One InkJet...
How you unlock the scannerof the samsung CLX 3160fn
The lock is the light green, slide the lock towards the front to unlock the scanner.
Mar 20, 2010 | Samsung CLX 3160fn All-In-One Printer
My Visioneer 8650 flatbed scanner with auto document feed gives a message when I try to scan a document, telling me to move the switch on the bottom from the "locked" to "unlocked" position. The lock is...
Actually a very common problem. Try the following:
1. Power down then re-power up the scanner.
2. Try slightly moving scanner. Sometimes a small change works to fix.
3. Change one of your scan setting to flatbed scan (not adf). Do a test scan under this setting. This will usually kick start scanner unit to unlock.
4. Last resort, by does also work...give it a medium slap on the side, sometimes unjams the scanner light.
5. Super last resort, power down over night, it almost always works the next day. (could be that lock up is heat related to scan lamp, dont know but just a guess).
Excellent scanner, so worth the effort to try these fixes.
May 22, 2009 | Office Equipment & Supplies
HOW TO UNLOCK THE UNLOCKED SCANNER UMAX 5600
The motor is cought thinking its locked but its not you will need to free the motor where its stuck if that dont help you then you need to get a hold of Umax and get another motor for it..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 15, 2009 | Umax Astra 4000U Flatbed Scanner
How to unlock the scanner
Shut down system and let it rest for a while. When restarted, it worked. ???
Mar 31, 2009 | Visioneer OneTouch 9220 Flatbed Scanner
Iam trying to scan a document on my flatbed xerox 4800 but it keeps saying please unlock your scanner then it gives me time to do it but i dont know where to unlock it
you might have two program trying to use the scanner at the same time & the scanner is confused.Find out what programs you are using.Hint...even printer programs may use scanner drivers. 2nd.you MUST use the EXACT scanner driver for your scanner. Windows will see the scanner "locked out"
Jan 06, 2009 | Xerox One Touch 2400 Flatbed Scanner
Scanner problem
To unlock a channel, press 'manual' & keep pressing it until you reach the channel that's locked out, then press 'L/O'. Repeat until all channels are unlocked.
To program, press 'manual' until you get to the first "empty" channel, then enter the desired frequency using the keypad, then press 'E'. Repeat as needed.
Dec 21, 2008 | Uniden BC72XLT Handheld Scanner
Just bought this scanner used and having problems with Banks 3 and 4
while the scanner is scanning press buttons 3 and 4 and they should start scanning too, if they dont then go to the first channel in bank 3 manually and press LO to unlock it, then hit manual again to go to the next channel and press LO again to unlock it( all of the channels in the bank are probably either locked out or empty(nothing programmed into them)
Sep 05, 2008 | Uniden BC80XLT Handheld Scanner
I Don't Have The Key
Darryl - lift up the top part of the scanner body (the silver part should separate from the black base) and let the kick-stand support the top part. Then look underneath the top part; there'll be a green tab sticking down from the top. If you look closely, you'll see little icons next to it that look like padlocks, one in an unlocked position and one in a locked position. Push the green tab away from you so that it lines up with the unlocked padlock, and that should do the trick.
Feb 10, 2008 | Dell A960 All-In-One InkJet Printer
Computers & Internet Logo
David Payne
David Payne
