Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Hoover WindTunnel Canister: Roller brush motor not turning
Hoover WindTunnel Canister model S3639: I replaced the belt for the roller brush but the motor that powers it doesn't appear to working. The motor's spindle doesn't turn (and there's no smoke or burning smell). The power cord from the handle to the power nozzle is plugged in tightly because the light in the power nozzle works. Does this model have a record of faulty roller brush motors? I'm not about to start replacing parts unless I know what the problem is. Jim, New Bern NC
  • 7 more comments
  • fantanman Jan 27, 2008
    Domvac, thanks for the information. Is this a fuse that I could replace. BTW, the shaft of the motor does turn easily.
    fantanman
    fantanman
    Domvac, thanks again for your helpful information -- delivered so promptly! It sounds like this problem is more than I want to tackle, so I'm left with two options: 1) Find a Hoover repair facility and pay big bucks, or 2) Just remove the roller brush altogether and continue using the machine. After all, the brush doesn't affect the suction power (does it?) and the old vacuums didn't even have roller brushes. I think option 2 is my choice.
    Thanks again.
    fantanman
  • WEDNESDAY08 Feb 06, 2008
    I have a Hoover self-propelled Windtunnel. While using the vac, I changed from carpet to bare floor and then back to carpet. When I did this the brushes would not turn. I cleaned the brushes and checked both belts to see if they slipped. They were both still connected and looked fine. I tried to switch the button from carpet to bare floor a couple times, but nothing. Any idea. Is this a major problem?
  • PMBM Mar 15, 2008
    I have a Hoover Windtunnel Bagged Upright self propelled. The brush/roller has stopped working. I replaced the brush/roller belt (agitator belt) but that did not help. Both belts seem to be fine. Any thoughts? Do I have a fuse problem too?
    Thanks.
  • Anonymous Mar 19, 2014
    brush not working green light flickering
  • Anonymous Mar 25, 2014
    Roller Brush not turning
  • Anonymous Mar 26, 2014
    brush not turning
  • Anonymous Mar 30, 2014
    Have removed all screws, motor filter, brushes and belt but cannot get motor cover off
  • 126 Answers
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
  • Ray Sabourin Jan 27, 2008
    I have replaced them before, but the fuse is actually attatched to the field and is not considered replaceable. If you take the top cover off the motor (remove the four screws) you can see the fuse attached on one of the windings. The black wire that comes from the motor is attached to it and then it is attached to the field. Check the fuse with an ohm meter. Also, check the carbon brushes. They don't use very long brushes and they can wear out pretty fast. None of these parts are available from Hoover. If a motor needs brushes, I have made them to fit and the fuse is available from most electronic parts houses. You can just take it out and wire direct but then you wouldn't have the protection of a fuse if something should happen.
How do you replace the beater bar belt on the hoover u 6626-900
It is not a "Beater Bar". Hoovers have brush rollers and are easy to replace. Turn the machine over and remove the 4 screws which hold the cover on, over the brush. Remove the brush roller. Slide the new roller through the small belt (self propelled models) and secure into slots (note: slots are different, match roller sides to correct slot.
Sep 20, 2011 | Hoover U6630-900 WindTunnel Bagless...
Hoover windtunnel t series belt is loose- roller brush doesnt turn. Its brand new belt is slipping. we bough new belts and putthem on same problem. Can not find solutio in manual. Is the belt supposed to...
I also have a loose belt and have bought additional belts but have the same problem. I put the it around the metal rotor and around the brush roller a shown by he Hoover video, and it is loose.
Nov 28, 2010 | Hoover S3765-040 WindTunnel Bagless...
My daughter's S3765 bagless canister has good
That means that you need to replace the belt. Here is the belt you need for your model.
Hoover Windtunnel Canister Belt
Dec 20, 2009 | Hoover S3765-040 WindTunnel Bagless...
The bottom of the hoover wont work. its not picking anything up and not spinning round.
You most likely will need to replace the belt on this model. There are 4 screws in the corners of the bottom power nozzle. DO NOT remove the 3 that are grouped together (these are the motor screws). once the top is removed then remove 3 roller cover screws. replce belt and reassemble in reverse order.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 28, 2009 | Hoover S3639 WindTunnel Bagged Canister...
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at www.vacbelts.com.
Here's the pages:
http://www.vacbelts.com/hoover-40201160-belt.htm
http://www.vacbelts.com/hoover-38528033-belt.htm
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
Belt will not stay on hoover windtunnel s3765
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
May 23, 2009 | Hoover S3765-040 WindTunnel Bagless...
Roller Belt Keeps Slipping Off
You could try contacting Hoover for parts availability. If it's and older WindTunnel and Hoover no longer has the part, try eBay.
May 14, 2017 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6434-900 WindTunnel Bagged Supreme
R U SURE THAT IT IS NOT JUST A SAFETY CUT OUT SWITCH , SOME MODELS HAVE A BLACK BUTTON BEHIND THE BRUSH HEAD DIFFICULT TO SEE SOMETIMES
Aug 17, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Belt Stretched on my Hoover Windtunnel Farrington upright model U6431-900
hi, In order to to replace the V belt the one that turns the brush, One must take off the bigger belt " drive belt" that goes over that hugh wheel towards the back. When a belt gets stretched they will not turn the brush very well. If you have bought replacement belts the bigger belt Drive comes 2 in a package. Then you have your little V belt that helps turn your roller brush over. Yes the belts don't last long on my hoover. For kpatr22101 When you rpelace that V belt it goes over the roller brush into a little groove on the brush and then over a plastic round wheel then you must put on that bigger drive belt that must fit over that hugh wheel towards back and smaller on in front. Yes it is hard to get on. the I hope this helps. Cindy G.
Jul 17, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush on vac
I don't know how old your machine is, but the belt should be changed at least once a year and you should check to make sure the roller spins freely. There are bearings at either end of the roller and they will become contaminated with dirt and hair after a while and will need to be serviced. A new belt will help, but won't last if the roller is in need of service.
Dec 02, 2007 | Hoover U5753-900 WindTunnel Bagless...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
2,538 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
