Question about Aprilaire 600 Humidifier
Aprilaire 600 I,ve installed an aprilaire 600 humidifier and I can not seem to get any results when it is on. It seems like it is not doing any thing but wasting water. I would appreciate any suggestions that might help.
    Problem Solver:
  • 7 Answers
If the water is always on make shure the 24 volts is hooked up to 24 volts only when the blower is on. Some furnaces have a HUM terminal but make shure it is 24 volts some are 120 volts you must use the transfomer with the AP 600. You may may use a RP50 relay. The setting 5 or 6 is about the avg setting slowly turn down to see if it shuts off .Also make shure the damper is in the winter setting. Hope this helps
Posted on Feb 05, 2008
Coating from water panel pad clogging furnace filter
I know of no answer to this except to remove the coating manually to prevent it clogging you filter.
Jun 22, 2017 | Aprilaire 600 Humidifier
My aprilaire mod. 300 seems to release an excess amount of water through the drain tube. it waste a lot of there a fix?
This is typical especially if there is not much air flow across the humidifier. Make sure the fan is running in the humidiifier and the core does not need to be replaced. Sometimes I have had to turn the water valve back a little to cause less water to go through to conserve that wasted water.
Apr 09, 2011 | Aprilaire 700 Humidifier
Does anyone know where i can find a wiring diagram for a model 600 aprilaire humidifier.
I hope this helps.
Scroll down towards bottom of page. I looked under the heading "CURRENT RESIDENTIAL MANUALS", and clicked on "Humidifier Model 600 Series Safety and Installation Instructions Template with Model 60".
Dec 19, 2010 | Aprilaire 600 Humidifier
Water does not seem to be going through the unit
With the heat on, turn control knob back&fourth from test.U should here a click each time.If no click check hum transformer power.If it clicks flush out water supply pipe poss cloged.
Feb 27, 2010 | Aprilaire 600 Humidifier
Aprilaire 600 humidier: water continuously runs
sounds like you may have it wired to a continuous power source vs one that shuts off with the furnace. The most common wiring is red to C & white to W
Jan 08, 2010 | Aprilaire 600 Humidifier
Is there a url that compares all the whole house humidifiers?
go for the Aprilaire 600 but make sure they install the outdoor sensor and set it up for AUTO operation
Oct 01, 2009 | Aprilaire 600 Humidifier
Aprilaire #224 celinoid not opening, water not flowing
it may be kickin on but you dont get water there is an metering device {little piece of plastic with hole} that cuts down on waste water it may be clogged to see if it is opening take a screwdriver and see if when humidastat is trying to work that you have a slight magnetic pull on the opposite end where water lines go
Feb 05, 2009 | Aprilaire 600 Humidifier
The water flow valve doesn't seem to be letting water through to Read page thirteen and there is a inlet water filter that may be cloggeed. Let me know if you need anything else.
Jan 11, 2009 | Aprilaire 600 Humidifier
Aprilaire 400 - Mesh Screen not wet
Not happy either. I bought 3 Aprilaire 400 for my house (3 zones). I picked this style since I have attic installation and did not want to run drains. The first night I expected a major air quality improvement but no change in humidity. I have installed humidifiers before so I know the drastic improvement they make. So I watched for a season and still no humidity improvement. Absolutely nothing at all. Same exact observation as you all described. Only the bottom of the media was wet. I'm dissatisfied with Aprilaire 400. Do not buy! Since I installed humidifiers before and understand them I am converting the Aprilaire 400 to work like a Aprilaire 600. I simply unwired the float sensors, removed the floats/lid and using a knife cut some of the plastic cups so the water would drain well. I also cut open the plastic exit port some too so it wont clog from dust globs. I obviously added drains. HUGE RESULTS. On the very first cycle on the humidity in that zone went from 25 to 48. I am watching carefully. -GK
Dec 31, 2007 | Aprilaire 400 Humidifier
Aprilaire 600 humidifier solonoid valve chattering in sync with d10 led
I fixed my problem by ordering a new control unit (model 56) from IAQSOURCE. Installing the control unit took a few mintues, and once the new control module was installed, I've had no more problems. The URL is as follows:
Oct 12, 2007 | Aprilaire 600 Humidifier
Aprilaire 600 Humidifier Logo
140 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
