Question about Hotpoint TDC32 Electric Dryer
No Water After several loads of drying i still have no water in the water container, does anyone know where it might be going?
  • 2 more comments
  • nad123 Jan 27, 2008
    Yes, it also keeps triping my mains fuse.
    the make is Hotpoint Aquarius condensor dryer TDC32P,its not new as i have had it for a few years, and i bought it second hand,the water tank use to fill up after every second load but for some reason there has been no water now for nearly 3 weeks! cant understand why?
  • Gary Davd
    Gary Davd May 11, 2010
    Please post the Model and Make of your unit off the tag inside the door
  • Gary Davd
    is this a condensing dryer??
  • 770 Answers
One other thing some of the water in in a coils so if the dryer is new it will take some time to prime and fil the tank dont worry it wont heat when the tank is full and will tell you to empty the tank when it needs it ..hope this helps
Posted on Jan 27, 2008
  • Gary Davd
    Gary Davd Jan 27, 2008
    Why are you worried about the water like i said it will tell you when it needs to be emptied if it working leave it alone some of the water evaprates during the drying process..if it is not leaking onto your floor leave it alone.
Water not draining to container,leaking.
Undu the hose or pipe at highest level and make sure it is not clogged
Aug 08, 2017 | Miele Dryers
How do i fix my phone that got water on the scree
Wipe off all water with a dry cloth. If water got inside your iphone, then submerge the entire iphone in a container of dry, uncooked rice for 24 hours which can absorb any remaining water in your iphone. If water got into your headphone jack, then your warranty is likely void because there is a material in the headphone jack that changes color after getting wet alerting anyone who looks at your iphone that it got water damage.
Nov 11, 2013 | Apple Cell Phones
After drying a load of rather damp clothes, the 'emty out container' light keeps coming on (there is a loud peeping noise and the dryer stops) even though the container is empty. The container is not...
This may help you. Please give the person who answered this thread credit if this helps.
http://www.fixya.com/support/t277592-bosch_classixx_condenser_drier
Apr 07, 2011 | Dryers
Lenses on my 96 merc Sable are so cloudy headlight power is severely diminished. Can these be cleaned?
You'll need the following. Painter's tape or Masking tape, 2000, 2500, 3000 grit sandpaper, bucket of water, headlight polish (PlastX, etc) and microfiber cloths
Mask off around the light so you don't have to worry about sanding your paint if your hand slips.
Soak the sand papers for at least 15 minutes. The more water the better Using the lowest grit, start sanding in ONE DIRECTION ONLY,(side to side). Keep the sandpaper wet and dip it in your bucket of water frequently. Now dry the headlight and it should look all hazy
Switch to the next finer grit, and repeat the step above, but this time go in the OPPOSITE DIRECTION (up and down). Keep using water
Dry it again, and it will look better than the first time.
Repeat the process again with your finest grit. Again, OPPOSITE DIRECTION with plenty of water. Dry it off. It should look relatively new at this point. Remove the tape as it will contain bits of grit from the sandpaper.
Generously apply the headlight polish in a circular motion to the headlight
Using your microfiber cloth, rub off .. repeat several times with FRESH rags until the polish is dry and gone.
Now the headlight will look like new
Nov 09, 2009 | 1998 Mercury Sable
My hoover steamvac turbopower 5000ls will not spray for hand tool
my turbo 5200 will not pick up the moister into container to dry does anyone know what the problem may be
Sep 12, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Add water
There is a floating magnet in the side of the water fill container. Make sure the magnet is floating. That is how the Keurig determines whether there is water in the container or not. If it isn't floating, the machine thinks the water container is empty. If it is not working properly your only option is replacing the water container (or rigging the magnet and being very careful to make sure the reservoir never runs dry).
Mar 28, 2009 | Keurig Special Edition B60 Coffee Maker
I need to know how to clean my filters on Hunter Humidifier Model # 33222. I have misplaced my instructions.
The instruction manual suggests using the water vinegar solution.
The following is from the manual.
1. Turn the humidifier ‘OFF’ and unplug the unit.
2. Lift the main housing and remove the water dispersion tray and the PermaWick™ Filters. The motor is attached to the main housing. Do not place the motor near water. Do not use a wet towel on the motor or motor housing as electrical shock may occur.
3. The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
4. After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
5. Remove the water tank from the base and empty any water that is left in the tank. Soak the base in a mixture of one (1) gallon of water and eight (8) ounces of vinegar for 20 minutes.
6. After soaking, wipe the base with a soft cloth or sponge to remove any mineral build up. Rinse with clean water several times. If you are planning on storing the humidifier, be sure the base is completely dry.
7. Fill the water tank with one (1) gallon of water and eight ounces of undiluted white vinegar. Replace the tank cap and shake the tank vigorously until all interior surfaces of the tank have been exposed to the water/vinegar mixture.
8. Empty the tank of the water/vinegar mixture. Rinse it several times with clean water and then replace the tank cap. If you are planning on storing the humidifier, dry it inside and out, leaving the cap off to allow the tank to completely dry. Continue to clean the other parts of your humidifier.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes. 41553-01 01/03/2008 6 © 2008 Hunter Fan Company
Rinse well and reinstall the water diffuser cap. Do not expose motor or other electrical components to water.
10. Wipe the surfaces of the main housing with a soft cloth.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location.
Dec 18, 2008 | Hunter CareFree Plus 33222 Humidifier
Bleach and softener dispensers filled with water at end of cycle
what u need to do is take the soap drawer out totally u need to put under the hot tap pull the containers out of the soap drawer and clean out everywhere what happens is the containers have small slits underneath them and when these get blocked it doesnt let the water run out using hot water and a brush to clean everywhere will sort this problem out this is a problem for all washers
Feb 10, 2008 | Washing Machines
BUNN BX-B Coffee Maker Leaking
is it the water container that leaking the best thing to do is open it maybe is a loose pipe or dry pipe connected to water container and if it the water container use 5 or 1minute epoxy cheers
Jan 29, 2008 | Hamilton Beach BrewStation Deluxe 47474...
Condenser Dryer Still Filling Room With Moisture
all dryers produce moisture. thats what hapens when you heat wet cloths up. the dryers job is to remove the moisture to dry. thats how the automai]tic cycles work by deteting the moisture in the exhaust. i will say there is nothing wrong with your dryer. only thing i dont understand is the containers of water?
May 13, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Hotpoint TDC32 Electric Dryer Logo
160 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
