Since I changed ink in my pixma mp 600, paper gets stuck in both feeders. I can not get it to print.
    President:
  • 2,351 Answers
Go here. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=13800#SupportDetailAct
Click on the Service & Support tab. Type in the search window: Paper does not feed through printer. Click search. Typed in Red you'll see, "Paper does not feed through printer". Click this link & follow the instructions.
Posted on Jan 27, 2008
I have a Canon Pixma MP 240 printer. It's been out of black ink. I installed a new ink cartridge. Now, there's an "E3" flashing on the screen. And it won't print anything.
Error E3 indicates that there is a paper jam.
Firstly remove the ink cartridge you have just installed and check to see if there are any bits of paper underneath that.
Secondly check the rest of the printer for any jams paying careful attention to any rollers as small bits of paper can get stuck to them.
Dec 17, 2010 | Canon PIXMA MP240 All-In-One InkJet...
How topaper load cannon mp 160 pixma
Loading Paper into your Canon MP 160 Pixma.
A) Loading Paper :
Follow this procedure:
1) Open the Paper Support, then pull out the Paper Support Extension.
2) Place a stack of paper (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Set the Paper ThicknessLever to the correct position for the paper.
Note : Set the Lever to the left for most paper. When the Lever is set to the right, the confirmation message appears before the machine starts printing.
Important : Make sure the stack does not exceed the Load Limit Mark.
B) Loading Envelopes
Follow the following steps:
2) Prepare the envelopes for loading.
Important : * Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
* Remove any curling by holding the edges diagonally and bending them gently.
* If the edges of the envelopes are inflated or curled, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
* Ensure that no curl or puff exceeds 1/8 in. (3mm).
3) Place the stack of envelopes (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Load the envelopes in the Auto Sheet Feeder with the short side down.
* Set the Paper Thickness Lever to the right.
Important : Make sure that the stack does not exceed the Load Limit Mark.
Hope this helps. PLease rate my response.
Thanks
Have a good day.
Dec 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Pixma 600, yellow won't print
...maybe your yellow nozzle is dirt...full of frozen yellow ink...try to cleaning the nozzles by put a thick paper and run the cleaning program from the printer properties...
Jul 09, 2009 | Canon Pixma MP600 Printer
PIXMA MP 600 PRINTER EVERTNING PRINTS GREEN
Usually I see that when you put in photo magenta when it should be plain magenta.Otherwise you need a new printhead.
Jul 03, 2009 | Canon Pixma MP600 Printer
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
I have PIXMA MP 600 PRINTER that has a paper jam as I fed used paper back into it /ink was still wet and apparently paper has stuck together and jammed. How do I clear
clear the jam paper
1) pull slowlly the jam paper back as possible as you can, usually the jam paper could be broken as pulling
2) open the cartridge area find the paper pull slowlly forword paper direction as possible as you can and try to take out any pieces paper behide the cartridge (between paper input roller and ink cartridge
Jan 24, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I have a Canon PIXMA MP 600. The paper doesn't feed properly anymore. Everytime I get an error: Auto sheet feeder. There is no paper load paper. I checked everything and there is no paper jammed. Is it...
Greetings,
If your are not loading from the ADF, check the settings and see if it is set to get paper from the Auto-Sheet Feeder.
Sometimes having an equipment repaired costs more than buying a new one.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 20, 2008 | Canon Office Equipment & Supplies
Canon mp 600r dvd printing
IT is easy once you have done it...it works a treat  but you do have to check all the correct boxes. (1) use cd label print that comes with the mp 600 ( i have a 600 not a 600 r)  design the label and then hit print (2) in paper size choose (cd r tray F ) (3) under the paper size box  choose (quality and media) (4) in media type choose ( printable disk recomended) (5) in paper source choose (disk tray) (6) hit print
make sure you have the cd loaded in the disk tray ready with the arrows lined up
good luck
Mar 25, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma mp 160
HI this is happening to me right now too-- try this-- I'm not sure if it's going to work-- but it's worth a shot.
On your computer, go to a print menu to print a document.
click on properties
go to maintenance tab
try the quiet/sleep mode
also, try going to custom and slow down the printing allowing for a little extra dry time.
reason I suggest it: my printer is doing the same, it's almost like the auto sheet feeder (only on the right side--why paper is grabbing weird) is grabbing too quickly. When in sleep mode, it seems to slow it down a little. I've also been printing 1 page at a time. I'm not saying this is a permanent fix, but at $50 for a pack of ink-- hopefully if you can't fix it-- it can get you to use up the last of the ink you have incase you decide to get a new printer.
Dec 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
