Question about ASUS P5LD2-VM Motherboard
ASUS P5LD2-VM Chassis Intrude
After rebuilding the chassis into another system I always get the message "chassis intruded, system haltet". I cannot enter the bion to disable this function and the switch, which needs to be placed in the jumper set for chassis intruced function is broken. so how can I deactivate to jump over this section while booting ? cheers Lutz
  • Peeter6666 Jan 26, 2008
    I hope I had now jumpered them and could bypass by f1, then I disabled system halt on errors, so it's fine now. However I feel this function itself as completely nonsense.
    thanks for help
    Genius:
  • 1,554 Answers
Do you mean the pins for the chassis intrusion on the board are broken off?
if not broken then just jumper them and bypass the switch.
Posted on Jan 26, 2008
  • Karl Whisenand
    Karl Whisenand Jan 26, 2008
    It came from the days that folks would go into a desktop and leave only enough memory to boot system and sell the rest.
    User didn't realize it until it was pointed out to them.
    Damn thieves.
  • mihaimargine
    mihaimargine Jan 23, 2013
    I have the same problem, i've tryed all the ways but nothing. i don't know what to do.
Chassis intruder,fatal error system halt on asus p5pe-vm.how can i fix it
Hello, you can download a manual here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Please select your windows version.
Select manual and click on global for download.
Unzip the file before installation.
And remove the cable on the mainboard for the contact on the chassis.
When that is done enter the bios and set the setting for the chassis intruder to off
Read about that in the manual.
The chassis intruder is used by admins to see if the case have been opened
when the case is opened the bios will block the system from booting until the setting in the bios
is set back to normal.
Oct 06, 2011 | ASUS P5PE-VM Motherboard
When I turn on my pc a message will appear: "Please enter Setup to recover Bios settings. Chassis intruded. fatal error... system halted"
First, turn off your computer, disconnect all cables.
Then, find the manual for this particular motherboard - locate in it where the "chassis intruder jumper" is. Then move the plastic jumper from pins 1 and 2 (left) to 2 and 3 (right). Keep them there for 10 seconds, then move the plastic piece back to pins 1 and 2. This should fix the problem.
Hope that helps! :)
Mar 01, 2011 | ASUS P5LD2 Deluxe Motherboard
The system intruded , chassis opened or tempered before
Some computer display this message when the case has been opened. After installing components in your computer and closing the case/cover then go into the BIOS setting and reset the chassis intruder detector.
Feb 01, 2011 | ASUS P4B533-VM Motherboard
P5p800 my mother boad model it is giving fatal error known by chassis intruded. plz help
Hi
When the computer boots, press <Delete> to enter the BIOS then BOOT>Case Open Warning>Disabled
then F10 and restart
Aug 23, 2010 | ASUS P5LD2-VM Motherboard
Chassis intruded ! fatal error.....system halted
Some cases have a switch that activates if the case has not been closed fully.
This sounds like the type of error report this problem causes.
Make sure that your pc case is fully closed and has not been damaged
Jul 11, 2010 | ASUS P5LD2-VM Motherboard
Chassis error pops up all the time
Hi JJCEO, please open your motherboard manual to page 1-33. Add a two pin jumper as noted. This should stop the chassis error issue. If you do ot have your manual. You can download it from Asus by clicking on this link; http://support.asus.com/download/download.aspx?modelname=P5LD2-VM&SLanguage=en-us
Mike
Sep 12, 2008 | ASUS P5LD2-VM Motherboard
Chasis intrded fetal error system halted problem plz hep me
somewhere on the motherboard there should be a switch or jumper to turn it off look for directions either on case somewhere or on motherboard
Jul 30, 2008 | ASUS SiS Chipset P5S-VM Motherboard
Tower change
1. Restart your machine
2. Enter BIOS by pressing F2
3. Scroll down to 'System Security'
4. Press Enter
5. Scroll down to Chassis Detection
6. Arrow over to 'Disabled'
7. Press Escape
8. Save changes and exit.
In some bios is in bios in the section BOOT and BOOT SETTING CONFIGURATION and disable CASE CHASSIS WARNING.
Your bios may be slightly different from the above. check inside the settings and find the case chassis warning option.
Regards
Mar 29, 2008 | ASUS NVIDIA nForce Chipset A7N266-VM...
Chassis intruded
Try disabling this feature in the BIOS. Here is a link to the manual.
Best of Luck,
Spare head 2
Jan 04, 2008 | ASUS P5S800-VM Motherboard
ASUS P5LD2-VM Motherboard Logo
1,360 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
