Question about Zanussi FJS1225W Front Load Washer
Zanussi aquacycle 1000 xc washer
Plumbed in - electricity connected - water supply fine.
all lights working everything seems ok but no water going into machine can you help
  • Anonymous Mar 14, 2008
    Lights on,cycle will not start ie no water going in, tried blue solution - nothing
  • robert0320 Jul 14, 2008
    pushed orange power button; lights on first three settings; pushed triangle shapped button. Machine seems to start, but doesn't load water as usual.
    removed some clothes; checked door - shut firmly and nothing stuck in door.
    Reset program. Error 10 appears
  • 54 Answers
Faulty fill valve. or tap not switched on correctly if it has the blue tap remove the top of the tap and use pliers to switch it on
Posted on Feb 14, 2008
Washer pump stay's running all the time won't shut off so it can fill with water
Could be a blocked pressure chamber not allowing the pressure switch to drop out. More likely (depending on the model) the flood safety in the base has been activate, pull the machine forward and then tip it towards you and see if any water runs out from underneath. If it does and once all the water has been cleared from the base the machine should work ok, but you will need to trace the leak or it will activate again, likely faults are a tear in the door gasket, leaky inlet valve or hose, leaky plumbing behind the machine or a leaky dispenser.
hope this helps
Mar 22, 2013 | Bosch Washing Machines
New fill valve streams water out the top nozzle
Hello llettieri,
You did NOT include ANY NOMENCLATURE...
(make, model)
of or relating to your new or old valves...
So all you are going to get is YES...
GENERICALLY... there are SMALL tube
configurations where there is a controlled water
port that is open toward the BACK of the tank...
(other than the main supply)
No... NOT DEFECTIVE.
In every CASE where I have seen them...
The NEW VALVE INCLUDED a hose & clip
to shoot that water down the tank overflow.
Since the toilet is essentially UNUSABLE with that port open...
SCAMPERING back down to the PLUMBER'S SUPPLY
and your receipt seems to be your only OPTION.
If possible... I would recommend the UPGRADE
as... (in my opinion) it makes for a cleaner & fresher
TOILET BOWL.. (it does cost a wee bit more water).
or ALTERNATIVELY explain why you prefer to
scrub more often... and go for the EXACT VALVE
you previously "enjoyed".
Hope this helped
Barnett Supplies for the Commercial Contractor Plumbing Electrical HVAC...
Fluidmaster 400CRP14 Toilet Fill Valve and Flapper Repair Kit Faucet Trim...
Fluidmaster 400A Anti Siphon Toilet Tank Fill Valve Toilet Water Tanks...
Carnac the Magnificent
Jun 24, 2017 | Home
GE Profile Dishwasher about 7 years old. everything seems to work door locks the machine trys to pump water in but it can't. I put water in thhe bottom of the machine and it does work a little but verry...
The washer doesn't pump water in--plumbing water pressure forces it in when the water inlet solenoid opens the valve. Check the water inlet solenoid--they are a common failure point. Look under the front of the washer behind the panel to find it--just trace the water inlet line. It connects directly to it. The valve can be stuck shut or, more commonly, the plastic coil form of the solenoid disintegrates. In any case, just replace it. Don't forget to shut off the water supply valve under the sink before you start work. Hope this helps!
Jan 07, 2011 | GE Dishwashers
Drum fills withe water when machine is not in use
Can you turn off water to machine? The water seleniod needs to be replaced this lets water in the switch sounds like it's stuck open.
Jul 26, 2010 | Zanussi ZWF1420W Front Load Washer
Water coming out of hose at home plumbing
Hello.Maybe the drain is blocked.it sounds like your machine is working ok to me,if you can hang the hose over the edge of a laundry tub & make sure the plug is out,see if the water drains away,otherwise it sounds like a plumbing problem not the machine.it started only after you moved houses so more likely the plumbing.hope i helped.
May 28, 2010 | Maytag HAV2557 Top Load Washer
Bosch dishwasher was started when water supply was off
You could have a blockage in the pump solinoid..if there was some plumbing done in the house...you can get small pieces of copper that come from cutting the pipes stuck in side of smaller water lines such as dish washers and ice makers... its a little bit of work but you'll have to remove the dish machine and double check that the water is in deed getting to the dish machine... if it is then you'll start by checking that nothing is clogging the pump...normally the punp is located right where the water connects to the machine...good luck
Apr 04, 2010 | Bosch Dishwashers
Have just plumbed in machine. No water going into machine. Electrics all fine.
check if the water valve is opened, also you can check the check the solenoid connections and the probe. also you can put a bucket or two of water directly in the dish washer to check if the probe and ather parts is ok.
Feb 21, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
Dec 31, 2009 | Zanussi ZWF1230W Front Load Washer
I HAVE A ZANUSSI XC AQUACYCLE 1000 FRONT DOOR
broken circuit in printed circuit board
Aug 11, 2009 | Zanussi Washing Machines
Zanussi FJS1225W Front Load Washer Logo
585 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
