Question about JVC AV-36D502 36" TV
JVC Model AV-36D502 Blinking power light on start-up
Overnight I turn on the TV and I get a blinking power light that wont let me
(control) Power up the TV unless I Remove Plug and re-insert.
No TV function will work unless I re-move and re-insert plug.
Once this is done the light stays on normally and all functions return.
cunningham4769@sbcglobal.net
Thank-you
    Sergeant:
    Champion:
  • 241 Answers
You probably have some sort of overheating or short on the internal board - is it still on warranty? if so they will fix at no charge - if not, a local repair shop should be able to correct the problem but it may cost as much as $150
Posted on Jan 26, 2008
My jvc projection screen tv AV-48WP74 power light blinking, no picture, but wont turn off
u have to unplug it for the light to stop blinking than put new lamp and housing in and it should work just fine after that
Aug 20, 2013 | JVC Televison & Video
Will not power up
does any power indicator that blinks or no power at all?.
Oct 27, 2012 | JVC AV-36D502 36" TV
Jvc model av32s33 wont turn on and has a blinking red light
check for a shorted regulator in the power supply section and bad horizontal output transistor.
Oct 02, 2012 | JVC AV-32S33 32" TV
Want to connect my JVC AV-36D502 to my lap top computer
hi hmwpeg
• you may need a PC to TV Converter
like one of these:
http://sewelldirect.com/pc-to-tv.asp
instruction is on the web page.
• to enable on your laptop, set your JVC TV as secondary monitor.
• use the Catalyst control panel.
hope these helps
thanks for choosing Fixya for assistance
Sep 05, 2012 | JVC AV-36D502 36" TV
Jvc tv power light keep blinking but tv wont turn on model av 27720
Its power regulator section circuit ahs the fault. If you want to repair this section, you must have through knoledge in electronics and work experience. Most of the components in this section are very dangerous to touch. It is fatal for an unexpereinced one to try to repair this section.
If you are confident, download the repair manual to your set from internet and follow.
Apr 23, 2012 | JVC Televison & Video
JVC AV-36D502: Input #3 doesn't work
Good day sir, its a different issue, about the capacitor, for as long as your replacement part is correct, it will work, now, there are several things you should check, the I/O device that controls the inputs of the TV, usually an IC, check your schematic diagram to trace the fault. check also the line from the input 3 to the controller IC on your diagram. Measure the voltage across the IC Vcc to ground if the IC is getting the right power, Low voltage can be cause by faulty capacitors, on the power supply line, or the IC itself is faulty, Circuit analysis and voltage measurements are needed to trace the faulty part. hope this helps thanks.
Oct 23, 2009 | JVC AV-36D502 36" TV
RED BLINKING TIMER TV WONT TURN ON
Page 40 on the PDF link below may help - Ask me if you need further assistance.
Thanks
Len
http://resources.jvc.com/Resources/00/00/99/51798Cien.pdf
Feb 28, 2009 | JVC AV-32230 32" TV
TV turned off itself and timer light (red) keeps blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Feb 15, 2009 | JVC AV-35750 35" TV
JVC TV WENT OFF. TURNED IT ON AND THE LAMP LIGHT STARTED BLINKING
If the Fan is clogged up with dirt set will not run fan must be working.
Dec 01, 2008 | JVC AV-30W776 30" TV
JVC AV-36D502 36" TV Logo
303 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
