Washer possibly locked
My whirlpool frontload model number ghw9400pLo is just making a hum sound possibly locked i cant find the manuel i belive this happen before
    President:
  • 1,294 Answers
Click on 'washing machines'(below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you hv your manual on line, if available! And dont forget to rate me, on this great site. Possible your belt is off.
Posted on Jan 27, 2008
Light continuously blinking and washer does not start on whirlpool frontload washer
need more info model # or picture of data tags\
sound like door lock
Nov 25, 2016 | Whirlpool Washing Machines
Will not spin out, just hums
Probably a capacitor problem, see Amazon.
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums
? 6:42
https://www.youtube.com/watch?v=WMvHOtTaTZ4
Feb 26, 2014 - Uploaded by canyonman1963
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums - Testing ..... It does not do this every time but about every 3 outof 5 times.
Kenmore Washer Diagnostic - Hums, Will Not Run After ...
? 3:34
https://www.youtube.com/watch?v=C5F-_U0_hYw
Jun 29, 2013 - Uploaded by ApplianceVideo.com
Repair your own Kenmore Washer with these following problems:Hums, Will Not Run After Filling Only at ... Find out why. Close ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums- Testing Capacitor, Waterpump ...
Dec 10, 2015 | Kenmore Washing Machines
Whirlpool duet dryer model number gga9200lw2 says control lock how to fix problem
follow this steps and fix it. God bless you
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Oct 05, 2012 | Washing Machines
What causes a DL F code on a whirlpool washer model ghw9400plo?
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Apr 11, 2011 | Kitchen Ranges
Possible electrical problem
The DL code is door lock. The manufacture explanation of the code is here then my comments follow.
A Door Lock Error occurs if the door cannot be locked. It
will try to lock it six times before displaying the error code.
Possible Causes / Procedure
■ Door lock mechanism is broken or removed from door.
■ Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/
lock unit and Central Control Unit (CCU).
Phil's comments------>
It it almost always a failure of the door latch mechanism. The part number is 8182634 and cost around $45.00
Here is a parts break down to show you where the component is located it is part #7 in this drawing. Sorry about all the trouble you are having, it is usually a good machine and I have one at home myself.
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0111040-00002.png
Apr 19, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My front load duet dryer (whirlpool) has a control locked lite on
look closey at the panle i belive the far right bottm button is the "cntrol lock" button, hold it in for 3-5 secs to unlock
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GHW9400PLO
The "Fdl" code is a Door Latch Lock error. Inspect the door latch for obstructions that may be preventing it from locking and doublecheck the wire harness to ensure all the connectors are intact. If the latch is defective, use the following link for advice on how to replace it:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Another method of replacing the latch is to remove the top panel and work form the top down behind the front panel. Due to limited space, this may not be desireable to some.
Replacement latches can be purchased on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. Use your model number for your search criteria. These sites have great service and offer competitive pricing. Check out all three for the best savings.
I hope this information helps you. Let me know if you need further assistance.
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door Lock does not lock
1 o 2 issues either a bad door lock, or the machine control board located under the main top is malfunctioning.
Feb 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock light on, won't go off.
i need your correct model number to help refer to you owners manuel how to come off control lock press and hold turns it on not off
Dec 30, 2007 | Whirlpool 24 in. DU930PWP Built-in...
Washing Machines Logo
91 people viewed this question
Top Washing Machines Experts
