Question about Irons
Problem My iron will not heat up. The light on the side goes on when pluged in and you can hear the clicking sound like it has alwaysmade when initially pluged in but it will not heat up. Please Help. I am desperate. I have not even been able to find a small repair shop to take it to.  It is a Rowenta Precision Iron Model DM580 Thanks.
  • 1 more comment
  • Anonymous Dec 29, 2008
    My Rowenta advancer iron it stopped working, the lights are on but it doesn't heat up. While I was using it and it stopped working,very unusuall.
  • joyceluther Dec 31, 2008
    Rowenta DE-871
  • Anonymous Mar 05, 2009
    iron will not heat up more than lukewarm, the light is on
  • 105 Answers
There is most likely something wrong with the heating element you need to take it apart to find out what is going on with the unit. you could alternatively try to turn the dial up and down to see if you can maybe get it to work for the time being.
option 1 - take it back to the store you bought it at and get a new one
option 2 - call rowenta and see if it is still covered by warranty
option 3 - take it to a small appliance shop <-- not much of an option it seems like
hope that helps.
Posted on Jan 26, 2008
Hi Ihave a Bosch B25L steam generator iron and it has stopped steaming completely. Any ideas?
Yousaf/Tony, Either the switch is defective or the heat element has gone bad, probably not cost effective to repair.
May 25, 2014 | Bosch sensixx TDA 8333 Iron
Heat element light comes on (so there is power) but the iron will not hear up
The Delonghi Pro300 has two thermostats that contact the boiler. One is a low temperature thermostat that allows the boiler to heat up to 145 degrees (F). The other turns off the boiler when the temperature reaches 180 degrees. It sounds like your low temperature thermostat has failed. The part can be ordered on line. You need to have good basic mechanical skills and the proper sized star screwdriver to replace it.
Apr 24, 2014 | DeLonghi Stiromeglio Compact PRO 300 Iron
My oreck cord-free is a JP8100c series. I have had this iron for years and really like it. just recently it will heat for a second or so than the light goes off, I tried holding the reset button and I...
Good news and bad news.
The good news is I found a website with your iron model and the parts, however, the bad news is that the manufacturer decided to discontinue the base the part that heats up your iron. But, if you would like to purchase another one, eBay and Amazon have some great deals. Just in case you want to contact the website I previously mentioned the # is 877-346-4811. Or you can go to ReplacementParts.com. I hope that you find what you're looking for.
Sep 26, 2017 | Oreck Cordless Speed JP8100CA Iron
Iron does not heat light goes on but does not get warm
Here is a tip that will help you to troubleshoot our iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Mar 21, 2010 | Krups V70 Iron
Switch light goes on when pressed but goes off if not pressed
Switch light goes on when pressed but goes off if... OR iron does not heat at all even pressing the button to turn it on continually.
Don't understand which one question you are asking
But if there is no heat at all after switching it on, it needs to go to iron heaven but be sure to cut the plug of the end, Saftey reasons at the dump. BUT if lights are coming on the iron is working. the large dial on the water filler is temperature control. Turn this around to cotton or linen.
The light will come on and off while in use, it allows you to know that the iron has cooled and is going back to your select temperature( on the large dial)
Make sure that you use water in the iron as it will aid your ironing and make it quicker. Make sure that the iron temperature dial on the water filler is at the correct temperature for the item that you are ironing.
Hope this helps
Sep 17, 2009 | Black & Decker Steam Xpress AS250 Iron...
When i plug in the iron it does not heat up
heating elements is out then have change the parts
Aug 18, 2009 | Rowenta Irons
Why isn't my Iron heating up? Just finished filling my Krups V65 iron with water. Was ironing linen shirt on linen setting, all of a sudden, heat dropped all the way down to light one (very low heat) and...
I do believe the thermostat is defective.All the iron have a small thermastat top control the temperature and is working like a switch.If the switch don`t work get stuck on the same position.Unfortunatly sometimes is better get a new one themn fix an old one but this is The Market and nothing i can do personally.Also make sure the thermostat knob is working properly.If you hear a click when you turn is ok.
Good Luck
Jun 12, 2008 | Irons
Its gone off!
The green light indicates the unit thinks it is out of water. Take of rewervoir; make sure the inlets are not plugged. Open the little plug on side, clean tank w/ clear water only, and shake out all water completely. Put it all back together, but leave reservoir off. Turn on and run unit "dry". Your should hear a "flutter" sound as the unit trys to pump water from missing reservoir, the heater/steamer should be sizzling hot & pressurizing. THEN the green light if ome ON, asking you to switch it off, refill & install the water reservoir. If things don't happen in that sequence, you should be able to determine what is wrong.
Dec 27, 2007 | Rowenta Perfect Iron
New rowenta effective iron that doesn't heat and steam correctly
Don't use distilled water-I had same problem. It was built to use regular water. Solved problem
Nov 29, 2007 | Irons
Irons Logo
586 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
